Question about Gateway FPD2275W LCD Monitor
Monitor problem The screen is completely black. Blue light at bottom is on. Can hear music when screen usually comes on, but still black.
  • getts Jun 12, 2008
    Thank you, but I finally replaced the faulty monitor with my old one, and it worked fine. So I returned the Envision monitor to the store, they tested it and
    said it couldn't be repaired. So they gave me a new one.
    Thanks you for responding.
    Janet Lambertson
I have the same problem , so after the p.c. is turned on and gone through it;s startup procedure, i wiggle my mouse and press the last button to my right on my monitor , and there you go, hope this helps?
Posted on Jun 09, 2008
Hp touchsmart 520 when i press the power button the blue light come on sound like it turning on but a blank black screen done this from new
Let it power on. If it plays the normal windows music then look very carefully at the screen. You may need a flash light. If you see a faint image then your inverter board or back light have burnt out. It will a small board 1 x 2 inches usually and have a small wire coming from the power supply and one going to the bottom or top of the screen.
Dec 29, 2012 | Computers & Internet
Was on the internet watching movies, I paused the movie and went to cook. When I returned, the screen was completely blue and wouldnt come out of it. I manually shut down and tried to reboot. My system...
my suggestion to you is that you try connecting to an external monitor and see whether it works or not then we can proceed basing on your feedback....please,let us know the outcome
Oct 28, 2010 | Dell InspironTM 1501 Notebook
How do you recover from the black screen of death?
You probably mean 'blue screen of death'. There are too many possibilities to list, but let's start with is it a blue screen with white lettering? If so there are several 'error stop codes' that "should" point you in the right direction. You can view these here. These can be anything as simple as a device driver problem to a bad motherboard.
If you are getting a completely black screen but can hear the computer running, I'd suspect a bad video cable, monitor, video card or video chipset (the latter is built into the motherboard and can usually be circumvented by adding a video card). Try a different cable or monitor if possible (always make sure your PC is turned completely off before removing any plug other than USB). If this doesn't work, you can buy a cheap 'PCI' video card for about $10-15.
If the computer just doesn't turn on I'd suspect (almost always) a bad power supply. You should be able to find a new one for under $25. Just make sure it has the all same connectors as the original.
Sep 28, 2010 | Computers & Internet
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
I just got a used syncmaster 203b monitor. I hooked it up and all I get is a black screen. I downloaded Driver whiz and hooked it up again. Still a black screen. Still get a black screen the blue light is...
Make sure that your computer unit is working. Sometimes we suspect that it is a monitor problem but usually, it is a frozen CPU set.
When you turn on the monitor, it should light the blue led and after a while, when it does not receive signal from the CPU, it will turn orange. If that is the case, the monitor is functioning well.
So what could be the problem?
Make sure that you hooked the monitor to the right VGA port. If you have an internal VGA port (built in with the motherboard) and you also have an external Video Card, you should hook it to the external VGA port and not the internal one since it is overridden by default.
Do you hear the "short beep" sound when you boot your PC? That signals a good video system. If you don't hear that beep sound (provided your PC's speakers are okay), you should open your CPU case and try to remove your memory modules (RAM). Clean the pins with an eraser and put it on.
Now, your computer should work fine and so with your monitor.
Aug 14, 2010 | Samsung SyncMaster 203B LCD Monitor
Hp pavilion elite m9357cthe tower starts up the blue light comes on i hear the hd run for a few seconds and stop and the screen stays black
Make sure monitor is plugged in and on correct. Try a different monitor otherwise to see if that is the problem
Jan 20, 2010 | HP Computers & Internet
Black monitor
Power light coming on and sound effects when you plug it in but no lighting of the screen is usually caused by the power inverter board having gone bad. Once in a while it is a bad bulb.
I repair these 90% of the time
bammbamm@ptd.net
Jul 03, 2008 | Gateway FPD2275W LCD Monitor
Gateway Monitor FPD1760
Power light coming on when you plug it in but no lighting of the screen is usually caused by the power inverter board having gone bad. Common on the 17s due to their age is a bad bulb or more.
bammbamm@ptd.net
Jun 27, 2008 | Gateway FPD2275W LCD Monitor
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Gateway FPD2275W LCD Monitor Logo
209 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
