Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
1.
1 Switch off the printer and disconnect the power
supply. Allow any residual charge to fade away before putting your hands or
metal tools inside the chassis. 2.
Step 2 Pin down the exact location of the jam. The
three hot spots for a jam are the paper tray, anywhere between the feed tray
and the print carriage, or between the print carriage and the output tray. 3.
Step 3 Take off the front paper tray if the sheet got
stuck while it was still in the front area of the printer. If the sheet jammed
here, you should be able to see most of the paper. 4.
Step 4 Pull on the sheet with both hands and steady
pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper
in the machine. 5.
Step 5 Open the back panel to reach paper jammed
between the feed tray area and the print carriage of the all-in-one printer.
Carefully remove the jammed paper from the machine. 6.
Step 6 Use the carriage access door to reach a jam
further inside the all-in-one printer. You may need to move the print carriage
out of your way to clear the jam.
Step 7 Return any access panels to their closed and
locked positions. Plug your printer back in and flip the power switch
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
?· Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
?· When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
?· When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
?· Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
