Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Flashing F and alarm
I have a kenmore H3t washing machine. It is 3 years old. I was washing a small load when we heard a beeping sound. The washer was flashing F, it has water in it, it was about 11 minutes from completion. I tried to restart without success, I tried rinse and drain without success. I can hear water being added and hear a humming sound but no aggitation or draining. I've unplugged the unit, hoping to reset it, but no success. Now I can't even get the door open.
  • 413 Answers
Based upon your description, the drain pump has either failed or become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.... Hope this helps
Posted on Jun 08, 2008
Door locks, but will not fill up with water. Alarm sounds and lights flash once every minute or so
There is a rectangular magnet attached on the inside of the drawer for the detergent. Located on the right hand side near the front of the drawer. This magnet had come loose. Some glue and caulking worked well and the washer is working fine now. Meant to post this weeks ago.
May 12, 2009 | Kenmore Front Load Washer
After I paused my Kenmore H3t washer to add clothes, it will not
sounds like you may have a bad door switch or the door latch on the door is broken
Apr 02, 2009 | Kenmore Washing Machines
Indicator flashing "H", "F".
ck drain hose first be sure end is at least 30-36 in from floor and fits loosely in standpipe ckd for water to both connections on back of washer ..remove top ck flowmeter on left side small round object with 2 small hoses and wires attached try taping it fixes problem replace it if not still suspect it and replace it
Dec 19, 2008 | Kenmore Elite 45986 Front Load Washer
Washer full and then stops and gives a beep while flashing F 51
On Kenmore F51 means Motor RPS Failure, the motor is not spinning or the motor sensor detects a fault.First unplug the power cord for one hour or so to check if it is a jammed sensor, and see if reset.
Dec 06, 2008 | Kenmore 24032\24036 Top Load Washer
Beeping sound
Problem was the alarm on the water dispenser next to the washer...................................duh
Sep 06, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
F2 and beeping
The F2 error is the user control board gone south on you, a new board will fix the machine, as always do you own your home and does the insurance cover appliances?
Sep 05, 2008 | Kenmore Oasis HE 27082 Top Load Washer
i have the same onebut fridgeair but mine would only wash and nothing else and it turned out to be the motor was weak
Apr 14, 2008 | Kenmore 44042 Front Load Washer
3 audible beeps every 20-25 seconds
Try unplugging the washer for about 20 minutes then plug back in and use. I have found that this actually works! The only thing I can figure out is that it takes time for the electronic control to clear. If that doesn't fix the problem I would call sears tech since it is less than a year old. They have a 1-2 year warranty.
Dec 21, 2007 | Kenmore Oasis HE 27062 Top Load Washer
Washing Machines Logo
109 people viewed this question
Sal De
 Brian Main
Brian Main
