Question about Sony HT-5100D System
Low sound sound drops very low. speakers test ok.
  • 1 more comment
  • stephend Jun 08, 2008
    i thought you would tell me which componet. i had my solder gun ready.
    str-k502 is the particular piece of equipment where the problem lies.
  • stephend Jun 09, 2008
    thanks!
  • 4,234 Answers
FIrst a couple of questions about the symptom:
1) Does the sound start out at the correct level and then drop off or is it always low?
2) If the sound level fluctuates, is there a pattern to when this occurs? Starts out OK, fails after a few hours? Starts out low, ends up OK after a while?
3) Do other inputs work OK with the receiver?
4) Is the output from the TV a "fixed" output or variable? (this should be marked at the output jacks.)
I'll look up the model in the meantime, but please respond to the above as it will make diagnosis much easier.
Thanks,
Dan
Posted on Jun 09, 2008
  • Sony Master
  • 19,396 Answers
Follow first all the indications provided by Ekse, probably you will fix it following the procedure in his post, this will make things much easier.
Also ensure that you checked speakers and cables properly.
If it is the home theater can be a lot of things, you need to put your hands on it.
You check most stupid first, like the touch buttons , when they are faulty sometimes the volume goes suddenly down like if you press the button.
If the volume instead cut off suddenly then you may have a problem with the amp, you need to follow the diagrams in service manual, as suggested and test the board, even a condenser gone can give you this kind of troubles.
In service manual you will find diagrams indicating which zone of the board (control, amp. preamp) you have to check when you have problems with sound going down or cutting off.
Posted on Jun 08, 2008
  • Sony Master
  • 13,433 Answers
Seems like a component level problem, I would contact your dealer incase you have warranty to get it replaced.
  • 1 more comment
  • Ekse Jun 08, 2008
    Got the service manual?
    http://smpcshop.com/STR-DE575-STR-K502-S...
    Lets see if I can find the cause, if not Il contact a collegue, expect him to respond within 24hours.
  • Ekse Jun 08, 2008
    heres what sony says about the problem
    IMPORTANT: If the stereo receiver is connected to an AUDIO OUT jack on a television, it may be necessary to disable the built-in speakers of the television before the audio signal can be passed to the stereo receiver. In addition, it may be necessary to increase the volume level of the TV if this connection method is used. Consult the instruction manual of the television for further information.
    1. Turn on the stereo receiver.
    2. Try increasing the volume level on the stereo receiver.
    3. Check to see if the sound on the stereo receiver has been muted.
    4. If the stereo receiver has a headphone jack, make sure no headphones are connected.
    5. Try a different audio setting on the stereo receiver.
    6. Check the speaker wires to make sure they are connected securely to the stereo receiver.
    7. Try connecting different speakers to the stereo receiver.
    The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required.
  • Ekse Jun 08, 2008
    I've contacted another expert. expect hes response within 24hours.
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
I got a 91 chevy pick up with a cilfford, the radio works but hardly any sound comes out of speakers. I got a new radio and its the same. All speakers play buy sound is very low. I was told it was do to...
posted 6 times.
run new wires from new radio to speakers
or bench test your radio (easy) with your speakers.
if still low the speakers are bad or just dirt cheap , car speakers.
try new speakers, if weak now the wires are bad, try new wires
id still weak the radio is bad. (or just a cheap radio)
and define weak, to me most radios are way too load.
but to others, all are weak until 1000watt amp is added.
weak is a relative term. as is hardly any.
do not quote persons guessing, its just a wild guess. they can see car either, do the tests your self and find TRUTH.
to bench test, (modern way)
1: 12vdc 1amp power pack, or battery 12v. and ground.
2: connect up USB mem,. with some mp3s. on stick.
3: connect one good speaker (KNOWN GOOD)
to one of 4 speaker lines. (2 wires)
4: push play, does it sound good, yes, move to next speaker port.
ok , the radio is good. so
try it in the car, is it now low volumn
yes, then move that test speaker to the car speaker that is low.
still low, yes, then the wiring is bad.
easy huh?,,, takes only , a test speaker.
if no usb use, cassette, if no that , use CDDA disk( store bought real)
if none of that us the radio to test. connect a test antenna.
tune in Am or fm. bam.
May 06, 2014 | Cars & Trucks
HOW can i increase the ring sound
Hi, if the speaker is runing ok, for calls and music just need to press the volumen up button till the top.
If this very low sound issue did not happend from the begining then you could check replacing the piece (speaker).
On Lumias runing Windows phone 7.5 (or 7.8) there is a code to run an aplication for testing most of the parts and sensors but there is nothing I know for HTC.
May 04, 2014 | HTC HD7 Cell Phone
Packard bell easynote speakers are very quiet
In instances of speaker damage, there may not always exist a drop-in replacement. ... Driver damage doesn't just consist of poked-in speakers, there's also blown ... You'll know if the driver began smoldering, if there's smoke to be seen on the ... Hook it up to the speaker, let it play at modest volume
Dec 01, 2012 | Computers & Internet
No sound coming out for my hartke amps?
Are the internal speakers properly connected via the rear-mounted 1/4 inch "Speaker Output" jack? If so and still no sound, try connecting a separate external speaker (floor monitor, pa cabinet) for a "low volume" test.
The OM says the internal speakers are 4 ohm so it's unlikely that a wiring problem with speaker connections would cause all four to stop working. With AC power disconnected from outlet check for an internal speaker protection fuse BUT be careful. Charged capacitors can hold a charge for weeks!!!
Oct 25, 2012 | Hartke VX3500 Bass Guitar Combo Amplifier
Peavey speakers making no sound
Try connecting them to another amplifier...you can use the speaker output of a guitar amp as a quick test. If the amp (and mixer) check OK, it sounds like you are about to become good friends with your local speaker reconing shop.
Remember...Distorted Audio Can Kill Speakers even at low volumes. It happens because sine waves become square waves. Google it for additional information.
Oct 24, 2012 | Peavey PR15 400w PA Speakers
4 out of my 5 jbl 125 sat home speakers have very very low sound, the speakers don't look blown
Before you blame the speaker one simple test needs to be made, if you have not done so already.
If one remaning speaker has full volume output, swap one of the 'defective" speakers to that same channel the "good" speaker was attached to, and see if the output drops.
Nov 22, 2010 | JBL SCS125A System
Monitor problem.
um.. im just gona say this it seems obvious but on mine one of the leads connecting the sub to the rest of the cabinet fell off and all i had to do was reconnect it and it was fine.
Aug 11, 2009 | Yamaha NS-A636 Speaker
Rear and center x-530 speakers won't work
Don't worry, to use a 6ch speaker like yours, first you need to configure your PC sound ports.
  • Go to
  • Control panel>sound and audio devices>press advanced button (the bottom one)
  • Now select 6 channel mode from the drop down list
  • Press ok
  • Now you are ready to go.
  • Now connect your speakers to the three pins on the back panel of your PC.
  • Test with some music now
  • You should here sound from all speakers.
Tell me what happened.
Mar 18, 2009 | Logitech Audio Players & Recorders
My computers sound not working.
try new sound drivers for your model pc ok
Feb 07, 2008 | Dell A215 Computer Speakers
Sony HT-5100D System Logo
156 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
