Question about Microsoft Zune JS8-00001 Digital Media Player
Zune Hi, Have a black screen on Zune,but can hear music. Any tips on what I could try to get the screen working? Already tried the troubleshooting suggestions at Zune.net. Thanks
  • behere Jun 08, 2008
    Thanks...how do we check the connections being loose? And to replace the screen would I have to mail it to microsoft?
  • Microsoft Master
  • 13,433 Answers
The screen may have failed or a connector is loose.
I can suggest replaceing the screen, but check the connections first allthought it may be a problem in the mainboard instead of the lcd not working.
Posted on Jun 08, 2008
  • Ekse Jun 08, 2008
    If you open the player you will void the warranty, so easyest fix for this is to contact microsoft if you have warranty that should be free.
Zune is completely dead when not plugged into my computer
the battery is not retaining any power. the only reason it works while it is plugged in is because there is power go directly to the battery
Jan 11, 2010 | Audio Players & Recorders
Cannot download music
If your computer is a Windows system, these Zune troubleshooting tips might be of help.
Jules
Jun 20, 2009 | Microsoft Zune JS8-00001 Digital Media...
New zune 8GB screen does not work
it seems as if something may have been attached badly on the inside that is a facttory problem is it still under warenty? if so i would send it back for a new one
Jan 08, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My 30 gb zune is frozen
There's a fix:
Your zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connecter. Your zune should start up immediately. Press the backing of the zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
It's an easy process but if you're unsure don't attempt it.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
goto step 4 only remove clip for battery wait ten seconds. It worked for me!
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
30gb zune only has black screen
Try these ideas first, except calling for service since it's out of the warranty: http://support.microsoft.com/kb/931912. If this doesn't work then, you'll have to erase all the content on your Zune through the buttons on it and use the Zune software to restore the firmware and getting it to boot again. If this doesn't work, then the hard drive may be bad in the Zune and will need to be replaced. If the hard drive is bad, you'll usually hear a lot of repetitive clicking. I hope this helps.
Dec 09, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Had a zune which malfunctioned. best buy replaced it .I charged it nad synced it with my music library but now all I get is a black screen....help
Sounds to me like either your PC configuration is causing major problems with any Zune, or that one of your individual songs is causing a corruption. Do you use Limewire music service? If so, you likely have one or more files that has a hexadecimal code in the comments section of the ID3 tag, and this is throwing your player out of whack. Limewire isn't the only music service that does this, but it certainly is a principal offender.
What is the model number of your zune, and what Windows OS do you have?
Reset your zune, and see if it functions normally, and also go to the Zune website for other troubleshooting methods.
Jul 08, 2008 | Audio Players & Recorders
Had a zune that malfunctioned. best buy replaced it. I charged it and synced it with my music library but now it qon't do anything...black screen....help
Zune
The songs are most likely in the wrong format, or do not have transfer right - see my "tips & tricks" in my profile on song formats (2-part article)
Jun 26, 2008 | Microsoft Zune 2nd Generation Digital...
Microsoft Zune JS8-00001 Digital Media Player Logo
63 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
Mister Danger
Will Mishler
Will Mishler
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
