Toshiba HD-A30 HD-DVD Player
Problem for Toshiba HD-A30 HD-DVD Player
Frozen A30
By wingnutz on Jun 08, 2008
After an update on my HD-A3, there was a power surge and now my machine is frozen and only says "Welcome". It willnot do anything, but turn off and on. Please help.
Same Problem
Oct 26, 2008
-   I just bought an Toshiba HD-A30 from a friend and it's doing the same thing. It locks up on the WELCOME and wont let me do anything past that. HELP?!?-   LArtist
Aug 16, 2008
-   I got a toshiba HD-EP 10 dvd player as a present but as soon as I put it on the welcome sign comes on and can not do anything further try to reset by holding the power switch for a few second still the same . the toshiba customer service give me ref no to replace the unit but the dealer wants a receipt which I havent got . thanks for any suggestion.
ray -   ray vahidi
Aug 01, 2008
-   My HD-A30 is also frozen at the "Welcome" screen. The tray will not open. I tried using the remote to input a tray unlock code but this did not work.-   mjpawlak
Solution #1
posted on Jun 09, 2008
Somewhat Helpful)
Agent Aaron
Rank: Guru
Rating: 86%, 200 votes
Hey wingnutz,
If your HD-DVD player has been locking up after a recent firmware update, you may wish to attempt rebooting/resetting the unit before considering any kind of repair option.
First I would suggest seeing if you can enter the "Setup" menu from the "Welcome" screen. If you are able to do so, under the "Maintenance" option there should be a command called "Initialize." After selecting this command, you will need to turn the player off and unplug it for several minutes. This should cause the unit to reset.
If doing so does not resolve the problem, you may wish to then look for a pinhole reset button on the back or underside of the player. Typically players that have a reset button will return to their original factory settings when this button is depressed. Please keep in mind that not all HD-DVD player models will have such a feature, so you may wish to refer to your owner's manual documentation for more information.
Alternatively, many products (DVD players, computers, etc.) will have what is often referred to as a "soft reset." This is typically done by pressing and holding the power button down for 10 to 15 seconds.
Should your player still be stuck on the "Welcome" screen after trying all of these, you may need to contact Toshiba or a local repair technician for further assistance. Remember that if you are unsure where your local repair facility is, you may always obtain service and repairs by bringing your player into your local Best Buy™ store.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Was this helpful?
Yes
No
Popular Solutions for Toshiba HD-A30 HD-DVD Player
Questions and Unsolved Problems for Toshiba HD-A30 HD-DVD Player
Do you recommend Toshiba HD-A30 HD-DVD Player?
Answer
Answer
how to unlock toshiba dvd player HD A30 to region free?
Answer
Hi. Is there a hack that will make the US Toshiba A30 HD DVD player Region Free? Thanks.
Answer
i've lost my 5.1 s,s. on my tosh a30 hd dvd player,plays normal sound,perfectly but was very... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba HD-A30 HD-DVD Player:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
