I have a mitusubishi tv. The other day the power went out and now it has a blue screen and no sound? I had this problem a few months ago and we guys helped me with it, but I can't remember what you told me to do??
It was not too hard, other posted a poor rating without speaking, you have a question, post your own question, not try get help this wayIt was not too hard, other posted a poor rating without speaking, you have a question, post your own question, not try get help this way
You can't post conmments that contain an email address.
Blue screen means either no signal (if unit has rear connections hook a DVD etc to one and go to that input and see if it works) Or the blue may mean set is in shutdown----5 months old and it should still have a warranty?
The blue tube might be leaking coolant in the high voltage area, that is the cause of the POP. This repair might not be a DIY because of the lethal high voltage surrounding the CRTs tubes.
The slow response from the remote could be because the coolant has affected the main board where the IR signal are going to the remote sensor.
Let me know if you require further assistance.
I had the same behavior, but not as a result of power outage. The TV is driven by windows CE software and it goes haywire every now and then. Usually pulling the plug for a few seconds takes care of any problems, but not this time (as you noticed). I had unplugged my ethernet connection on the TV a few weeks ago and thought I'd hook it up again to see if there was a new software release (not likely). I went to the menu and chose "Connections" and then chose "Ethernet Setup" and then chose "Reset All". After I closed the menu the TV rebooted itself (as it said it would). After my TV rebooted I had my analog channels back. There shouldn't be any connection between these two events, but it worked for me. Hopefully it will work for you as well. Good Luck!
If you are using Direct TV or Dish Network call their tech support.
If you are on cable TV, call for a service man.
I would say that your TV has lost its sync separater chip and it shouldn't cost more than $60 dollars to fix, if the repair guy is honest. It's a 30 minute job.
This message is from an electronics engineer, retired.
try tapping lightly on the tub that matches your color problem. do you see it come and go? if so then you have bad tubes. you can try to rejuvenate them but is not recomended.
The power supply may have failed. Also, it is possible that there is a failure in the HV section.
You will have to take the set in for an estimate. This is something that I doubt you can fix yourself at home. The set will require troubleshooting by an experienced tech.
The problem could be the power supply, the flyback trasformer or simply a bad connection. A repair cost for this TV set could run any where from 75 bucks all the way up to 225 or so, depending on the problem. Good Luck
