Question about Frigidaire Dryers
I have a fridgeair front load stackable dryer. The dryer tub has problems getting started rotating. At times it also makes loud noises coming from the back center of tub. In order to get tub started turning I can manually move tub an inch or two then it will start working. Although sometimes it will stop. What will cause this?
  • 413 Answers
Frigidaire Dryers use a ball and socket in the rear to support the drum. The socket is made of a Teflon type of plastic that will wear out when the grease is no longer present. By now, the ball of the drum is probably grinding away at the metal support for the socket, thus the loud noise. At the same time the front seals are probably worn out. These two things combined is causing alot of friction keeping the drum from turning freely. The parts required to fix these issues are not that expensive. Getting the dryer apart to replace these items however is time consuming and easier with two people.
The top panel, control panel, front panel and the drum will all have to be removed.
Posted on Jun 08, 2008
Dryer was running but had a very large load. Dyer stopped and now there is a loud clicking sound. We are allowing the unit to cool down. But at this point it will not start have checked all the lint...
Sounds like a pulley wheel inside your dryer, that means tearing down, an some dryers tear down different, pry top with a flat screwdriver, to open top off, spin dryer tub, it should make the noise, if so u have to tear tub out, there's a belt Tincher next to the motor on bo
Oct 10, 2014 | Dryers
GLEH1642DS1 FRONT LOAD STACKABLE WASHER MAKING LOUD THUMPING NOISE IN SPIN CYCLE & SQEALS WHEN i STOP IT
Sounds like you have an unbalanced load. I know this sounds too easy but lots of times this is the issue. If it doesn't help then you could have a bearing issue where the belt goes around a pully under the tub itself. If so you will have to replace the pully itself and perhaps the belt if it's gotten worn too much.
Nov 15, 2013 | Washing Machines
Just bough a used frigidaire stackable unit model FEX831CS and washer makes extremely loud noise on spin cycle. and dryer takes over 2 hours to dry a regular load of clothes. Please help
Hello uucyc1 - From what you have described it sounds like you either have a problem with the washer tub bearing, belt, motor or trunnion (steel bar that secures the inner basket to the transmission shaft). As far as the dryer, long dry times typically are a result of poor air flow. Make sure that the dryer exhaust vent is completely clear and that the unit is not overloaded. I would suggest contacting an experiencing service technician to determine the precise cause to both units.
Mar 02, 2013 | Frigidaire FEX831CS Top Load Stacked...
Six-year-old Frigidaire stackable front-loading washing machine turns on, fills up with water, but makes a loud noise during the spin cycle?
If it is a banging or uneven sound, your tub and unit is not balanced any further. The tub could be off of the pulley/bearing supports and needs professional attention.
Aug 15, 2012 | Washing Machines
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Sears stackable one peice unit. washer top load on bottom and dryer front load on top. The proble is when the washer is in the spin cycle it make a teriable load noise. Like it is grinding becase of a...
Your brearings are possibly worn, when the machine is off open the door and grab a hold of the drum (metal part on the inside) lift this drum if your bearings are worn it will have some play within its housing, i.e. it will move before the inner tub does and mannually rotate it you should here the bearings rumble if so also. they wear over time. you may be able to get them replaced but check prices first as it may be cheaper to get a new one bearing changes can be labour intensive.
Sep 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Very loud spin cycle
It sounds like the bearings have gone out in the tub. The major cause of this is using powder soap. There is nothing you can do but replace the rear outer tub. This is a costly fix but maybe worth it for a stack unit.
Jun 26, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Noise
sounds like there's something inside the tub, can you do a visual inspection and maybe run your fingers around the agitator..stranger things have happened.
Mar 04, 2008 | Frigidaire FLGB8200DS Top Load Stacked...
Dryers Logo
146 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
