Very poor connection and sometimes gets disconnected. I am thinking of returning my
    Problem Solver:
  • 30 Answers
Run an anti virus for your desktop, i reccomend use mcafee anti vrus, if everything is ok, run an system optimization scan, try advance windows care. It is a freeware from iobit.com/downloads. hope this helps you
Posted on Jun 09, 2008
Why does my hotpoint, electric ignition gas stove beep -F1-
You are having connection issues, or a failing keypad. Disconnect the power. Pull down the control panel and disconnect the thin, flat ribbon connector that goes from the keypad to the control board, then re-connect the power and see if the F1 returns without the keypad attached. If it returns, get the computer board rebuilt at Corecentric Solutions. If the F1 doesn't return, buy a new keypad... Help Me Find My Model Number RepairClinic com
Jul 31, 2016 | Hotpoint Kitchen Ranges
Quick disconnect tool is not helpful on disconnecting fuel line from fuel filter on 92 F 150 w/4.9L
there are a few different tools and some work well and others just plain ****. Patience is the key sometimes with poor quality tools. If yo have the multi quick dis connect tool that is like the swiss army knife of quick disconnect tools, thats the worst one.
My neighbor had trouble with a quick disconnect fitting and came to get me. when I got in his garage he said "here's the tool." I threw it in the trash and came back to get my set of quick disconnects. It tool me longer to open the case, get the tool out and put it back than the time it took to undo the connection.
Jul 19, 2012 | Cars & Trucks
I cannot download anything on the android market.kept getting the download unsuccessful message
If market opens I think it is a poor signal problem.
If your signal is weak it takes a long time to download your app/game and the market may disconnect you thinking you have disconnected or are having problems.
Try in a better signal area or better still.
Connect to your wireless network. (That way you don't use your data allowance)
It could also be a memory issue but I should have thought a message would warn you that you are low on space.
Mar 10, 2011 | HTC Hero Smartphone
'91 Protege with automatic - not automatically shifting
there is a short harness that goes into the top of the transmission it goes into the transmission and is attatch to the solenoids on my car it is located under the battery and sometimes acid gets into the connection sometimes it can be clean but i had to replace mines and that solved the problem
Aug 14, 2009 | 1994 Mazda Protege
Does't connect to network - search Network
Hi
It sounds like you may have a poor 3G reception in your area. Even though other O2 phones are working better they may be running on the 2G masts in your area.
Try in setting/network menu turning off 3G reception, that way the device will only look for 2G masts. Your handset will give priority to 3G masts where available and sometimes will hold onto the weakest signal making poor call quality, and or dropping connection.
Advantages to using 2G only = better standby and talk time / better reception where 3G is poor.
Disadvantages = Slower web browsing / no video calls.
WEP / WPA will only apply if you are connecting using WI FI and have nothing to do with your mobile network connection.
Hope that helps?
Apr 27, 2009 | O2 XDA Flame Smartphone
Kenwood:1090VR Cracking sound from front speakers
There are poor solder connections somewhere on the board. Usually these are at the voltage regulators where there can be some heat. Look for 3-legged transistors attached to small metal heatsinks, If you can solder, resolder the pins on those parts. Also look for any connections that appear to be grasiny or have rings and resolder them too.
Keep us posted.
Dan
Feb 06, 2009 | Kenwood 1090VR Receiver
Misfires on cyclinders
crank shaft sencor cam shaft censor.02 sensor
Jan 15, 2009 | 2000 Honda Accord
Not running good--sometime it cuts out
This could be as simple as a loose connection to your battery. If one of the terminals is loose then you'll have erratic behavior and spells of running well and then poorly. I'd check the terminals and tighten them well. While you're there coat them with a battery terminal grease, or if that's not available use WD-40, to ward off corrosion and give you a better contact.
You don't state why you replaced the battery but there's the chance that the real fault was your alternator. If your alternator is going bad then you'll have symptoms like you describe and also may think your battery is at fault and replace it. The issues will return after the battery's charge dwindles and your alternator cannot maintain it. Most auto parts stores will do a free alternator test for you, but most will need it removed and brought to their counter to do this. Well worth the test, and if it tests bad, then you can get the discount for the returned bad core unit on the spot.
Hope this helps.
Dec 28, 2008 | 1997 Cadillac Eldorado
3800 cooling fans quit sometimes causing overheating
Sounds like a poor connection or loose connection, stasrt with the battery and clean and tighten cables. then check starter connections, Don't forget to disconnect the battery before you work on starter connections! There are some good contact cleaners available at your local auto store.
Oct 15, 2008 | 1997 Pontiac Grand Prix
F20 error on vaillant eco28 combi boiler
F20 is a flow sensor error. Can be due to a defective sensor/ not correctly fitted, or you may have poor circulation, a big difference in flow and return temperatures, can sometimes make the boiler think it has a defective sensor, check good circulation through system, or if you have thermostatic radaiators valves on every single radiator, take 1 head off, as if you dont have a bypass fitted, it needs a radiator as a bypass circuit
Aug 30, 2008 | Heating & Cooling
Computers & Internet Logo
David Payne
David Payne
