Question about HP Pavilion zd8000 Notebook
Laptop boots then shuts and continously does it
My laptop starts to boots and get all the way to the Windows XP page then a blue screen appears. I can't make out what is on the blue screen because the screen only appears for a second or two. Then it goes back to the the black screen asking me if I want option windows do I want to start from( Safe mode, last one that worked correctly ,etc etc) and it does the same thing once I pick an option. I don't currently have any recovery disks. what do I do to get my computer working again.
  • pip08 Jun 16, 2008
    I was having the same problem, but do have my recovery disk. However, I did everything the recovery disk said and now when I try to start it up it goes to a blue screen that says "setup is being restarted..." and nothing is happening. I left it on that screen for 30 minutes and nothing came of it. HELP!!!!
    Genius:
  • 1,019 Answers
you really need a recovery CD, or windows operating system.
try removing any external devices ( Printers/scanners/ USB devices et,c ) And start the computer up with bare minimum devices attached/connected. it may be one of the external devices causing your problem.
Mike @ Compurepair.
Posted on Jun 10, 2008
Laptop wont boot to windows, and flashing a blue error screen
Do a system restore/recovery to a date before this issue. Unplug, remove battery, leave battery out during this procedure, plug into AC, Start tapping the F key that will start the restore/recovery page. You didn't give OS or other info. Did you do updates? Add software/hardware? What preceded the issue?
Nov 29, 2012 | Computers & Internet
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
After installing an automatic update, upon re-starting, my computer will load the windows xp welcome screen, the blue bar, under the windows xp icon, scrolls as if the computer is booting up. The screen...
Sounds like the HAL.DLL problem that I have with my Aspire One.
Try booting off a genuine Windows XP disc and choosing the 'recovery console' option. At the command line, type 'CHKDSK C:' and press Enter. If you're lucky, that will do the trick.
Feb 07, 2010 | Acer Aspire 5050-3242 Notebook
Media drive not found my laptop is toshiba sat a45 s150. after turning it off unsuccessfully, a blue screen error was displayed. if long pressed the power button to shut it down. after opening it again,...
Most likely the boot sector is corrupt.Try to boot by starting the Computer and hitting F8, or F12 you need to get to your start windows splash screen.Then try Start Windows from Last Known Good Configuration.If that don't work try Safe Mode.If none work you will need to recreate your .boot file, or try recovery fron CD.It gets complicated explaining how to rebuild your boot sector,If you have access to internet search "how to rebuild boot sector Windows XP".There are programs you can download and then load/run to rebuild boot.This has happened to me or someone I know and it is a pain to fix.You need some knowledge of how boot loads and how to repair.Try to get someone you know to help you.The problem was caused by the shut down.I think you ment XP can't Boot.Good Luck
Sep 11, 2009 | Toshiba Satellite A45-S150 Notebook
Can't reload windows xp. Keeps shutting down???? Acer 2700 Laptop
this happens when you have errors with the hard drive not responding to the new boot or drivers not responding. is this a clean install or a restore? if you are not using the original xp disk the machine came with you may get these errors. the blue screen usually has a message in it. let me know what it says if you get a second.
Jul 18, 2009 | Computers & Internet
I want to install windows xp on my acer 4230
Hi shaikh_shaha
Can you get it to boot using any of the options it gives other than boot normally? If the blue screen is caused by hardware then installing xp will still present the problem. If the blue screen is an operating system crash then using the recovery disk or doing a repair install will solve the boot problem.
If you still rather install xp then you need to go into BIOS and set 1st boot device as CD. To go into BIOS you will need to press F10 or F2 (usually) as displayed on the splash screen when you power on
Does this help?
May 02, 2009 | Acer Extensa 4620 Notebook
Error window when starting windows xp
restart in setup or bios options
then choose to set to default
then f10 to save and exit
you may have had a virus
let me know
you may need to format
if you can't start in safemode
Feb 02, 2009 | Toshiba Satellite M50 Notebook
Blue Screen of Death
You'll need to setup the Acer laptop to boot from CD-ROM. Push either the F2 or F10 button when booting your laptop and it should bring-up the configuration management interface. Go through the options and confirm that Boot From CD-ROM is at the top of the list on bootable devices.
Next, you'll need your original Windows XP CD that came with the Laptop. Put it in the CD-ROM Drive and reboot your laptop. You will be given two options: 1) Re-install Windows or 2) Repair the existing Windows Installation. I recommend that you repair the existing Windows Installation as this will not destroy and data or device drivers that are install on the laptop.
Good Luck!
Dec 16, 2008 | Acer Aspire 5050-3242 Notebook
Turn on
I would do another clean install...Start the machine with the OS disk in tray/follow on screen instruction...if it does not works that way when you start the machine up go to setup and make cdrom your 1st boot/save and exit/then restart machine and follwo instructions
Jul 04, 2008 | Acer Aspire 3690-2196 Notebook
KDS Valiant no image on on screen
first of all try to start your laptop in safemode
1 start laptop
2 continously press F8 key
3 when you see menyu select "start windows in safe mode"
if your computer starts with same mode and you see the desktop
then you just have to restore your xp with earlier system restore check point
and if you dont see desktop in safe mode also then you must have to install win xp again
steps for restore windows xp
1 start
2 programs
3 accassories
4 system tools
5 system restore
6 chose restore system to earlier time
then select any earlier date in calender at which computer is working properly
and click restore
it restores your xp and restart your pc and your problem will be solved
if still having problem then you must reinstall windows xp
Mar 07, 2008 | KDS Valiant 671DP Notebook
HP Pavilion zd8000 Notebook Logo
164 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
