Question about Haier HVF042 Wine Cooler
Wine Cooler Temperture Regulation
I have a 60 bottle IWA wine cooler that will no longer allow me set the correct temperature. In fact, the tempeature it likes is just a bit less than FREEZING. Yep, corks popped out and we had a lot of water condinsation that over flowed onto the floor.
Looking in the bottom section I see the compressor motor, a fan that runs, the coils, and a "Black Box".
It seems that if I replace whatever the thing is that controls temperature I could make it work. Can someone give me enough information to repair it? Oh, I called IWA and they said the no longer sell this unit - hummmm ... wonder why?
Thank you in advance for assistance.
I have selected the Haier unit in hopes that it is close to mine.
Ron
  • Northwest29 Jun 16, 2008
    Okay, I admit the info helped me locate the area that held the circuit board, but I decided to wait until I returned from being out of town to take it out.
    Anyway, now that it is out I need to locate a replacement. On the bottom of the board I find VT60dy(pe1).pcb. On the top there is a white paper label with CB47050142.
    I've used Google to find a replacement but no hits on those numbers. Can you please advise me of a source for these type of circuit boards.
    Thanks again for the help.
    Ron
  • castroneves Mar 25, 2009
    I have exaclty the same problem, but I have the 42 bottle Haier model HVDO42E. Woke up last morning and the wine cellar had condensation all over the door. And I saw the display show "LLL", which I found out means too low to measure.
    I called Haier and they said to leave it off for 24 hours. Did that, plugged it back in and the problem persists.
    Do I have to change the circuit board? Does anyone know the part number? I'm in Brazil! This sucks!
    Thanks!
  • 868 Answers
Replace the circuit board . Please Rate This !!!! Thank You!!
Posted on Jun 08, 2008
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
Other than temperature, is there any other reason not to store wines in a regular fridge? I don't mind my wines being slightly cooler and I can always leave them on the counter for 10 minutes bef
Aside from temperature, humidity is a major concern. The low humidity levels can cause the cork to dry/shrink allowing room for both air and other food odors to enter the bottle and tamper with the quality of the wine inside. Wine coolers offer an optimal humidity level of 50-80% needed to keep your wine in good condition.
Jul 31, 2012 | Furniture
What is a single zone wine cooler?
A single zone wine cooler allows you to store only red/white wine correctly. The cooler has only one temperature control and one space for storing your wines.
Chamber wc902 wine cooler which wont set temp
I have the same issue especially when there is a power outage. To reset it, press the preset until "1" appears, then adjust the temperature as low as it will go by repeatedly pressing the temperature "-" button. Usually works.
Oct 08, 2009 | Tower Chambrer WC601B 7 Bottle (6+1)...
Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Feb 21, 2009 | Avanti WC492D Wine Cooler
Wine cooler temperture
blown fuse in back panel, there are two of them, one you can see, one is in black shrink rap, this is probably problem fuse. It was on my unit and had to cut away the shrink rap and solder in new fuse. Found the problem fuse in top left of panel in back of unit, hope this helps.
Jan 19, 2009 | Oster 12-Bottle Wine Cellar - Black
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
I have a magic chef wine cooler (Model MCWC50DBT) and the labels keep falling off of the bottles. The temperature is set to red and we don't seem to have any other problems.
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
May 27, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Haier HVF042 Wine Cooler Logo
354 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
