Question about GE Heating & Cooling
Air conditioner breaker on plug keeps tripping
    Problem Solver:
  • 9 Answers
The instruction manual says:
If the safety device incorporated in the plug trips and cuts off the power supply, check that the power cable and plug are not damaged. If the power cable is undamaged, to restore operation press the RESET button.   To verify the correct operation of the plug, press the TEST button periodically and make sure the appliance disconnects.  If this is not the case, contact the service center. To restore operation, press the RESET button.
Customer Service: 800-322-3848  US Customer Service: 888-335-6644  Canada
Hope this helps!
Posted on Jun 08, 2008
  • suebee88 Jun 08, 2008
    Addendum:  I had found your post under the Delonghi Pinguino PACL90 problem list.  I did not notice that your unit was not a Pinguino until AFTER I posted the solution.  I apologize for the misunderstanding.
Xt8000E was working fine now the cercuit breaker keeps tripping but the 120 plugs not effected
That's the problem. Ckt breaker trips but the internal short keeps the plugs hot. There's a big wiring problem there.
Sep 12, 2016 | Heating & Cooling
Could this keep the air conditioner running and trip the breaker
Air conditioner may draw high current. It may trip the cirucuit breaker. You may check the current rating of the air conditioner. If it is higher than the circuit breaker rating, it surely will trip. If it is close but lower, it may trip as there may be other appliances connected.
Sep 27, 2015 | Heating & Cooling
The breaker keep tripping
When you get a new air-conditioner it should be standard practice to call an electrician and have a designated plug installed with its own breaker that has been calculated with the correct wire size and amperage for the breaker. When you use a common plug that may already have 5 or 10 amps being used on that circuit and you add a 12 or 14 amp appliance to the system you are going to have troubles.
Nov 29, 2013 | LG Goldstar GWHD5000 wall/window Air...
Why does the reset button on my air conditioner keep popping out when i plug it in
You are tripping that outlet's breaker. Either too much is on that breaker and circuit or that circuit is not big enough, enough current to power that unit.
Aug 13, 2012 | Crosley Heating & Cooling
The breaker on my air condition unit keeps tripping as soon as it is plugged in thanks jeff
I ASSUME IT'S THE GFIC TYPE PLUG AND ITS WHATS TRIPPING ?. IT COULD BE BAD, SOO WHAT YOU CAN DO IS REPLACE THE PLUG WITH A STANDARD PLUG, JUST FOR TESTING ... YA KNOW .. HOPE I WAS OF HELP .. JAY
Jul 21, 2011 | Frigidaire FAX052P7 Compact Room Air...
Breaker keeps tripping on outside air conditioner unit
The compressor is probably drawing to many amps. Breaker could be weak also.. Need to check the amp draw on the compressor.
If the breaker is hot when it blows, the compressor is probably going bad.
Jul 27, 2010 | Ruud Central System Air Conditioner
CIRCUIT BREKER KEEPS TRIPPING
Your house wiring in not capable of powering the unit. Try a different location to plug in. Check the unit to make sure it is not faulty and will trip breakers because it is damaged.
Sep 29, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
My Amana heat pump model PHD60C02F1 Keeps tripping the circuit breaker
Is this kicking the ground fault on the cord or the breaker. If it trips breaker could be bad breaker. If it trips quickly it is a short in the unit. Russ
Aug 01, 2009 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
550 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
