Question about Comtrend CT-507 Router
Comtrend ct507 no power
Unit was working fine, then lost internet connection, suddenly all lights went off on unit, power light went dim then off. Unit has no power. Tried differnet outlet, still no power. Unit will not turn on.
    Novelist:
  • 143 Answers
- try to use a known working power adapter with the same specs, it might be the power adapter is not supplying enough power, or
- try to press the reset button (if it has one) for like 30 secs, then turn the device off for another 30 secs. (Note: this might delete all the settings on the device)
- most probably the device is dead if same thing happens after pressing the reset button.
hope this'll help you
Posted on Jun 10, 2008
How do I ix my adsl2 comtrend modem when the internet light will not come on
If internet light is off, its not connected to the net. Check all connections. If OK try pressing and holding the rest button for 30 seconds.
Jan 25, 2015 | Comtrend Adsl2 Ethernet Router Model:...
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
I HAVE BT INFINITY BROADBAND - WORKING OK - I AM USING IT NOW VIA ETHERNET CABLE TO LAPTOP. HAD COMTREND POWERLINE 902 NETWORK SET UP AND WORKING. WAS ABLE TO ADD 2 MORE ADAPTERS - OK. BOUGHT 2 MORE AND...
The modem is probably still looking for the MAC address of your laptop at this point.
You need to unplug the modem AND the 902.
Power up the modem first and give it a minute to let the lights settle then power up the 902
Once the 902 is powered up and it's lights have settled down, start powering up devices that connect to the 902.
You may be surprised that this is all it takes!
Mar 12, 2011 | Comtrend Computers & Internet
I forgot my password and cant think of it how can i get a new one or reset it with out losing every thing on my computer i need the password so i can get the internet on my wii
the comtrend router password has nothing to do with the PC you can reset the router and then use the default username and password - ASSUMING you already tried the username and password and it did not let you log into the router setup screen
theres a few routers starting CT507 (1 , 1E etc ) see the download page here for a user manual http://www.comtrend.com/support.htm
Sep 28, 2010 | Comtrend CT-507 Router
Can not turn my comtrend powerline adapter of standby
i have the same problem,and i'm working on it,most probably a faulty capacitor in the power supply,i will let you know.
Feb 18, 2010 | Computers & Internet
SIR-PNP3
When mine goes time I squeeze the radio downward into the cradle and it lights back up.
Might be a weak connection. I'll have to hit it with contact cleaner sometime to see if it helps.
Aug 06, 2008 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
Bridge mode
Comtrend ModemLogin: root Password: 12345
May 18, 2007 | Comtrend CT-507 Router
Intermittent Power Problem when playing CDs
Hello db1964,
I have a cdf-e75 that had a similar problem, although the red power light was dim for all functions. (the radio, tape and cd)
After opening up the unit and inspecting, I found one of the pins on the printed circuit board for the power had broken away from the solder. (it is a tiny board where the AC connector is soldered to) Seems in my unit there is nothing securing the molded AC connecter to the plastic case except the the printed circuit board it is soldered to-It is a poor design; perhaps your is the same? I suspect over time pushing the AC cord into the back of the player may have broke the connection? Anyway, I soldered the connection and I have never had any additional problems as the unit has worked fine since.
Don't know if this helps, but my suggestion would be to open the unit and inspect the pin connections on the AC printed circuit board to see if any have a loose/broken connection. ( Mine was not noticible with the naked eye as I had to use a magnifying lens and a bright light. Hope this might help.
Dec 21, 2006 | Sony CFD-E95 Radio/Cassette/CD Boombox
Comtrend CT-507 Router Logo
595 people viewed this question
Top Comtrend Computers & Internet Experts
Julie Endres
mathur_1
cwradio73
Are you a Comtrend Computer and Internet Expert? Answer questions, earn points and help others
