Question about Microsoft Xbox 360 Console
Black box problems.
Ok, my xbox has never encountered problems, untill I moved it to another room. I didnt figure it would make much of a difference but It may of, but I dont see how because there's no major differences between them. The black box which connects to the power and to the xbox, that has a large label on it saying something like 6 volts, is not working properly. The plug seems to be disconnecting a lot of the time or something as the light which should normally be yellow, keeps switching from yellow to black whenever I put it on a surface and move it. It worked once in the morning, but it was still being a bit funny, and switching of when i moved it just a little. Now its just impossible to get  started of anything. Any help, I would be extremely greatful, wanna get started playing A.S.A.P
  • 50 Answers
Is it just doing it on that outlet if so the outlet may be messed up.
Posted on Jun 08, 2008
Can a circuit breaker fail? There is no power in my daughters room, but the circuit breaker seems to be fine. It doesn't reset or fix the problem.
Make sure to click breaker completely over to one side and then click all the way back to reset.
Yes, breakers go bad.
You can check your breaker in a simple way.
Turn main breaker OFF.
Mark daughter's breaker.
Take cover off breaker box.
The main breaker will still have power on the lugs where big wires connect.
Rest of box will have no power.
Notice that each 120 volt breaker has a wire connected to end of breaker.
Use screwdriver and tighten this wire.
If screw is already tight, then loosen screw and pull wire out, and move wire to another breaker marked with same amperage. For example if daughter's breaker is 20, then move wire to another 20. Now there will be two wires connected to that breaker.
Turn power ON and see if daughter's room is restored.
This set up will work fine until you have time to replace breaker with same brand as marked on breaker box, usually available at home center (if available).
If power is not restored by moving wire, then there is a loose wire inside a junction box located in daughter's room.
Test each receptacle in room to confirm that nothing on that circuit has power.
If some receptacles have power, start opening other receptacle boxes looking for loose wire, especially at the quick-connects where wires stab into back of receptacle device.
If whole circuit is off, then to isolate location of loose wire, start at the ceiling box, and see if there is a loose black or white wire. Most electricians run wire from breaker to the ceiling box, and then other wires spread out from there and go box to box until each box has a black and white wire that connects back to original breaker.
Dec 29, 2010 | Electrical Supplies
3 red lights on
Step 1: Turn on the console, and check the light on your power supplyThe power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution 3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutions 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support
(source: www.microsoft.com)Kind Regards
Mar 23, 2010 | Microsoft Xbox 360 Console
Tree lights in red
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutionsuparrow.gifBack to the top 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support(source: www.microsoft.com)Regards
My console plays my games, but there is a full red ring? what does this mean?
OUCH! You have the red ring of death! Did you by chance have xbox on it's side for a long period of time instead of flat? If so, that's why. They say there made to do this, just like the old ps2's, It a load of ****. The laser lens circuit will need to be replaced. If you didn't have it on it's side, then you have a bad graphics chip, or cold solder joints, or the motherboard is shot.
Step 1: Turn on the console, and check the light on your power supply loadTOCNode(2, 'moreinformation'); The power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this image3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair request loadTOCNode(3, 'moreinformation'); Your console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: uparrow.gifBack to the top Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutions loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this image3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it on loadTOCNode(3, 'moreinformation'); This will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supply loadTOCNode(3, 'moreinformation'); If the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply.
Jan 30, 2010 | Microsoft Xbox 360 Console
Problems with picture quality
if it shows up on multiple games then there is a problem with either your cord or your tv. Trying cleaning the connectors that room from the xbox to the tv. Do you have an old tv or a newer one?
Feb 20, 2009 | Buck Legendary: The Box for Xbox 360
Bioshock Martin Finnegan Bug (on 360)
In order to make him apper you have to move close to where he was before he tele'd away, Move towads the end of the room try to use the healt station, and if that dose'nt work then reload a past save, Happy hunting :P
Dec 25, 2008 | Take 2 Interactive BioShock for Xbox 360
AC Adapter has a blinking orange light...
Try moving everything to a different room on a different electrical circuit (as in electric panel outside your house). You might have too much load on that circuit for the plugs in that room. You could try unplugging everything except tv and xbox too.
Oct 29, 2008 | Microsoft Xbox 360 Console
JBL encounter
HI! Red14 happy holidays
Well, may be a lot things, from bad cable, welding inside , or bad resistor is burn. but check the cable, and if you can open the panel on inside speakers, try to figure out if the cable is not loose, or bad.
Nov 27, 2007 | JBL Encounter 2.1 Computer Speakers
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
