Have Upgraded from windows ME to Windows Vista. When I try to add this BYTECC Drive, It crashs the system.. I think I need an Installation Disk.
  • knnthhmphry Jun 08, 2008
    My Hard drive is aME-320X and it is not in the solution!!
  • 1,342 Answers
Here's a link to BYTECC where you can download your drivers.
Posted on Jun 08, 2008
  • Georgia B
    Georgia B Jun 10, 2008
    You did not state your drives model number in the original question that is why I referred you to the manufacturer's web site.
    Apparently Vista is not supported. Too bad for you!
    I hardly find that my answer was inappropriate. I think that your attitude is inappropriate.
Can I use a Bytecc BT-144 usb external floppy disk drive with an iMac running OS 10.10.1?
I'm not a Mac tech, but I wouldn't see why not. Floppy drives are kinda old school now. You may need a driver for the floppy. Check online and see what you can find. Download and install it.
Or you may have to plug the floppy in, then reboot, to get the Mac to recognize it, especially with a USB port. Some old Windozz machines were like that...maybe your Mac too????
Mac OS is very close to Linux/Unix systems, which have awful support for floppy drives. That's another possibility.
If your windows machine can't read the disk, makes me think the floppy drive is bad or you have corrupted files on the disk. Try a couple known good floppy disks on the Windoz box and see what happens. Or another removable floppy drive. They cost $5 to $10 now.
Jan 22, 2015 | BYTECC (BT144) External Floppy Drive
Help me with my laptop being slow
This folder is there because your system was upgraded (Possibly from Windows XP) to Vista. If you're satisfied with using Windows Vista and don't think about changing it back to what you had before, it's safe to delete these files.
Aug 12, 2009 | Computers & Internet
Windows Vista - Right-Click causes Windows Explorer to Crash
this has happened to me once or twice the only things I did was to run disk cleanup then reboot the computer. It worked for me.
Jun 28, 2009 | Microsoft Windows Vista Ultimate Edition...
HP Pavilion laptop freezes daily and i force manual shutdown
It sound's like there could be a compatibility problem, maybe corrupt file's, or missing start up file's, have you tried doing a window's update, or doing a disc check on the hard drive, go to my computer right click the drive then go to propertie's, click on tool's then click check now for drive error's. if that do'es not work you may need to reformat back to the original xp os.
Apr 16, 2009 | HP Pavilion dv1000 Notebook
Laptop blue screens when trying to reinstall vista
The problem might be with the bad sectors on a hard drive. You should run Scan Disk on a partition where you were trying to install Windows Vista.
Jan 16, 2009 | Dell InspironTM 1501 Notebook
Burning problems when running windows xp
avoid multitasking while burning disc, since this process requires more computer resources like Hard disk space and RAM. you can also update the firmware driver of your Disc burner from the manufacturer's website to correct the problem.
Choose a partitionTo add Windows Vista to a system where an existing version of Windows is already installed, first make sure that you have an available partition (or unformatted disk space) separate from the partition that contains the system files for your current Windows version.
The target partition can be a separate partition on the same physical disk, or it can be on a different hard disk. If your system contains a single disk with a single partition used as drive C, you cannot create a multiboot system unless you add a new disk or use software tools to shrink the existing partition and create a new partition from the free space. (The Windows Vista Disk Management console, Diskmgmt.msc, includes this capability; to shrink partitions on a system running an older Windows version, you’ll need third-party software.) The new partition does not need to be empty; however, it should not contain system files for another Windows installation. Run Setup, choose the Custom (Advanced) option, and select the disk and partition you want to use for the new installation.
The Setup program automatically handles details of adding the newly installed operating system to the Boot Configuration Data store.
And how do you edit and configure the Boot Configuration Data store? Surprisingly, the only official tool is a command-line utility called Bcdedit. Bcdedit isn’t an interactive program; instead, you perform tasks by appending switches and parameters to the Bcdedit command line. To display the complete syntax for this tool, open an elevated Command Prompt window (using the Run as Administrator option) and enter the command Bcdedit –?
arrow_px_up.gifTop of page Rename entries in the boot menuFor everyday use, most Bcdedit options are esoteric and unnecessary. In fact, the only option that we remember using more than once during the entire development cycle for Windows Vista was the command to change the text for each entry in the boot menu. By default, Setup adds the generic entry “Microsoft Windows Vista” for each installation. If you set up a dual-boot system using Windows Vista Home Premium and Windows Vista Business, you’ll be unable to tell which is which, because the menu text will be the same for each. To make the menu more informative, follow these steps:
1. Start your computer and choose either entry from the boot menu. After startup completes, make a note of which installation is running.
2. Click the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, type cmd in the Search box, and press CTRL+SHIFT+ENTER. Click Continue in the User Account Control box to open an elevated Command Prompt window.
3. Type the following command: bcdedit /set description "Menu description goes here" (substitute your own description for the placeholder text, and be sure to include the quotation marks). Press ENTER.
4. Restart your computer and note that the menu description you just entered now appears on the menu. Select the other menu option.
5. Repeat steps 2 and 3, again adding a menu description to replace the generic text and distinguish this installation from the other one.
Control which drive letter your boot volume usesWhich drive letter will your clean installation of Windows Vista use? That depends on how you install it. If you currently have a working copy of any Windows version on drive C and you install a clean copy of Windows, drive letters are assigned using the following logic:
• If you begin the installation process by booting from the Windows Vista media and choose a partition other than the one containing your current copy of Windows, the new installation uses the drive letter C when you start up. The volume that contains the other Windows installation uses the next available drive letter. When you choose the previous Windows installation from the startup menu, it uses the drive letter C, and your new Windows Vista installation is assigned the next available drive letter. In this configuration, you can be certain that your current operating system is always on the C drive, but drive letters assigned to volumes you use for data may shift in unexpected ways.
• If you begin the installation process by running Setup from within your current version of Windows and use the Custom (Advanced) option to perform a clean install on a partition other than the one currently in use, the new installation uses the next available drive letter. The volumes containing each installation have the same drive letters regardless of which Windows version you select at startup.
Dec 01, 2008 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
Windows Vista
Look buddy
in this case you could only have the situation that to format ur disk drive from other OS and you cannot run your system restore utility without ur vista home edition. It is not yet provided by any other site.
You must contact with ur vendour.
Aug 21, 2008 | Microsoft Windows Vista Ultimate Edition
When I am trying to load OS XP it is not working, but the system is running well with Win98
i think the hard disk might have got crashed or the cd from which your installing may consists some error (or it is unreadable ) ...
just try with other cd ....
or you might have installed some upgraded version of windows than the XP just for example :vista or media center etc .....
or you might be trying to install the XP in the drive which consist of the upgraded version of windows than the XP ....
just check these things and reply me ...
and tell me the what exactly error message you are getting while you go to install the XP ...
any doubts you can reply me
i am always here to assist you..
thank you
bye ..
rate my solution
Jul 08, 2008 | Intel Motherboard
Computers & Internet Logo
David Payne
David Payne
