Question about MSI Computers & Internet
Mainboard startup my mainboard don't do nothing exept,the cpu fan,and the powerled. he is brand new als the cpu and mem inside cpu 76x2 4200+ and mem 2x1gb
  • Anonymous Sep 14, 2008
    DRIVERS
Aan my geven
Posted on Jul 31, 2008
DONT ENTER IN BIOS SETUP
Posted on Jun 09, 2008
Cpu fan stopped working
According to the specs, you have an Intel i7 CPU in a socket LGA 1366. You need a fan compatible with that socket and rated for that CPU. The fan has an electrical connector to the mainboard that must be unplugged, then there are four spring-loaded locking screws that must be undone to lift the fan off the CPU. The replacement fan, if new, should already have thermal transfer compound on it. Be careful not to mess that up. Before installing the new fan, clean all old thermal paste residue from the processor cover. Do not use anything other than a clean lint-free cloth for this. Install the new fan, oriented so that the electrical connector can reach the mainboard plugin. Lock down the four screws, ensuring that the fan is centered over the CPU and has full flat contact to the CPU cover. It is not a difficult process, but can be a bit scary for first timers. Be very careful not to let the screwdriver slip when pressing down. It could strike other mainboard components and damage the board. ALWAYS DO THIS KIND OF WORK WITH THE UNIT POWERED OFF AND UNPLUGGED.
Dec 02, 2013 | Acer Aspire Predator G7710 PC Desktop
Acer aspire g7710 cpu fan stopped working
Cpu fan too fast
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=476&CategoryID=1&MenuID=16&LanID=0
Maybe the fans temperature controller is broken, or the cpu fan wire is connected to the wrong connector.
The fan must be connected to the CPU_FAN connector, not to the SYS_FAN on the mainboard.
The solution is to either clean the fan and the cooling element for dust, with compressed air, or renew the fan and the cooling element with a new.
Remember to add new thermal grease.
This mainboard has socket lga 775, and a fan can still be bought online, or in a computer shop.
A better fan, like the brand thermaltake or northq, does not makes a lot of noise.
Take a lot of cautions, when working on the mainboard.
Hope this will help you
Feb 18, 2013 | EliteGroup 661FX-M7 (661FXM7V11)...
The green LED light on the board is lighted. When I push on/off button the CPU fan moves for 1/2 a second .I tried a different power supply, but that did not work. I replaced the CPU fan, but that did not...
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+3+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG31PR
Any abnormal beeps at startup ???
http://www.computerhope.com/beep.htm
The problem could be a ram module failing, or the graphic card if installed on the mainboard.
Or a short circuit somewhere.
Look also here:
http://www.tomshardware.co.uk/forum/243625-13-turns-wont-boot
Try starting with only 1 stick of Ram, the monitor and the keyboard connected, no other USBs to be connected.
Look also for bad caps on the mainboard:
If they look like this, the mainboard is dead.
It does not pay, to let them be changed.
Good luck
Jan 28, 2013 | Intel DG31PR Motherboard
I have got a system with an Aopen motherboard which having only a 20 pin connector for smps connectivity. the Atx smps i have is is 24 pinned. i can connect the main line by splitting up the 24pin...
The actual Processor fan connects to the CPU Fan header on the mainboard. It's 4 small pins. It plugs in right near the CPU socket on the mainboard. Check the user manual for exact placement, you may download it from the AOpen website if you don't have one already.
Plug in the 20Pin connector if that is the most Pins that the mainboard will allow. Cable tie the other 4Pins back onto the 20Pin connector.
Then if there is additional 4Pin connector required by the mainboard for CPU power and you don't have that connector on you power supply, you will need to purchase a Molex to 4Pin CPU power connector. When you go to the computer store check with them that all is correctly connected.
Take care!
damnor01
May 25, 2011 | AOpen MX4GER Motherboard
On board led indicators are red in motherboard TF7100P-M7 power supply works cpu fan works both fans of the CPU heat sink assembly and power supply fan spin It shows no display, No beep
remove all ram memory wait 5 min,make sure to unplug from a/c,reboot with no mem should hear beeping unplug reinstall mem should boot ok if mem good,good luck!
Jan 08, 2011 | Biostar TF7100P-M7 Motherboard
Computer does not boot (new Machine)
Swap the power supply since you got two systems?
Feb 23, 2008 | Pine Technology XFX NFORCE LT 680I SLI...
Is processor dead
Its good that it beeps without the memory that means the mainboard is trying to boot. Make sure to try each ram chip individually in both sockets (if you have 2). If that gets nowhere I would try another CPU next.
Dec 21, 2007 | Fujitsu LifeBook E7110 Notebook
New processor
Usually you can use Northwood-core CPU-s on mobos with Willamatte-core CPU. But is important (exept core) - FSB support of your new processor. Which model of your CPU? What the mainboard use (model)?
Nov 15, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
199 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
