Question about Zenith Televison & Video
Zenith Inteq My VCR stopped taping. When you hit record, after 10 - 15 seconds, it shuts off and the word "ALARM" appears on the screen in front. The number on the front is IQVB4231. 4 Head hi fi. Any suggestions?
    Genius:
  • Zenith Master
  • 1,689 Answers
This can be something mechanicaly binding in the mechanism. It is also possible that the power supply is starting to fail, and when under load it goes into protect. It is also possible that there are some circuits in the VCR that are pulling too much current due to some failures.
The VCR should be checked by an experienced service tech who knows VCR's.
Jerry G.
Posted on Jun 14, 2008
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
How do you record a VCR tape
If you mean record from one tape to another, you'll need two VCR -
outout from first with the tape you want to play to the input of the seocnd with a tape to record.
Hit play on the first one and record on the second and off you go.
Nov 22, 2009 | Emerson EWD2203 DVD Player/VCR
I have a Zenith DVD/VCR and I am recording a tape
unless the security camera has a setting for recording the date stamp you probably can't. The camera probably has a setup tab to enable embedding the date stamp on the video.
Nov 14, 2009 | Zenith XBS448 System
DVD stops recording after about 30 seconds
If the take up reel is not working properly the slack in tape drive will cause poor recordings and shut downs.
Sep 13, 2017 | Insignia IS-DVD1001 DVD Recorder/VCR
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
3-4 switch
1. Set tv to channel 4
2. insert a pre-recorded tape into vcr.
3.press play once to start playback.
4. after a few seconds press play on the vcr for 3 sec you will see a playback picture.
when a picture doesn't appear on the tv screen repeat step 4.
5. press stop to stop playback.
Mar 16, 2008 | Sanyo VWM-950 VHS VCR
Tape Speed
Most late VCRs of the last 10+ years had just basic operating functions with the VCR mounted buttons. Setup of timed recording, and other advanced functions require a remote box, either the manufacturer original, or a universal unit which specifically is able to do advanced. Not all universal units have that capability, so if you go to your local electronics store, check this out carefully. Manufacturer remotes are available: Look here- http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod&store_code=EA&product_code=6711R1N051A Zenith may offer their own universal remotes- again, check them out for the capabilities required.
Sep 26, 2007 | Zenith VRD4235 VCR
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
I can not turn off the proggressive scan!
Try this to disabel the progress scan mode: Pointing the remote at the player, press the STOP key to stop any disc that is playing. Next, press the STOP key again and hold it for five seconds before releasing it. This should turn the Progressive Scan off.
Oct 05, 2006 | Zenith XBV442 DVD Player/VCR
Televison & Video Logo
70 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
