Question about Philips GOGEAR SA6045 MP3 Player
Help? ok.. if you didn't get the thread i put in the forums.. here's a new solution for ya.. the player works perfectly, yet, when i plug it into any computer it says that the usb device has a malfunction and is unrecognizable.. now.. i am not able to figure out what's wrong with it.. because i've installed everything required for it.. but it won't work
  • 1 more comment
  • jkudzin Aug 25, 2008
    Well, I've searched all the highs and lows and I can't find the cd, is there an update I can get from the Philips website? I mean a direct link because every time I attempt to find it, I can't.. Any help, I need the link, if anything
  • jkudzin Aug 26, 2008
    It works, but now I'm trying to delete songs and it shows as deleted from the computer but the files still show up on the player, but the song isn't as the title, for example instead of Nine inch nails "Closer" It would play Linkin park "Numb" But still show Nine inch nails title.. Is there any way you can help me with this?
  • aleja111 Aug 26, 2008
    at one point that I just try prenderlo philips appeared and was immediately extinguished and no longer prender.busco I turned to a solution because I was unable to give me as someone who arragle.
  • 8,596 Answers
You must run a repair using the Philips Device Manager that came with the CD. After you have done that, you must run the "update" with the Philips Device Manager.
Repair=1 time fix
Update=permanent fix
Posted on Jun 09, 2008
  • Corey Knoettgen
    Corey Knoettgen Aug 26, 2008
    jkudzin - for the software - just enter your model #, click on the right model#, and click on the software & drivers link
    As far as playing the wrong song - I'm surprised that "Repair" didn't delete all songs that were on your player. Playing the wrong song is usually a format issue. Make sure you do "update" and "repair" - if the problem persists when you reload the songs, then reformat the player.
Vizio blu ray player wont play new Hunger Games blu ray movie
I had the same problem -- we even returned the disc and got a new one. Go to the Vizio site and download the firmware for your player. Put it on a USB stick and plug it into the player. Follow the onscreen instructions (basically just press OK). The entire process takes less than 5 minutes from download to finish.
The Hunger Games works perfectly now.
Aug 21, 2012 | Vizio VBR210 Blu-Ray Player
How to get the shaft out of evinrude 1988-89 v4 outboard
We had some success suspending powerhead (if removed from lower) and first rattling the shaft with an air chisel (using blunt head) - worked best on dry rust. If that didn't work it was soaked for a few days in rust buster. and tried again. If that didn't work, we put a bearing splitter on the groove above the pinion splines and a perfectly cut threaded pipe with a threaded union on one end over the drive shaft in such a manner the pipe would apply pressure to the crank shaft when the union was unscrewed.
Now if that didn't work, you can cut the drive shaft off the engine at the crand shaft and drill a hole thru the stuck part. Then tap a thread into the hole and thread a bolt into the stuck part till it bottomed out in the crank shaft and continue to thread it in and it would walk the piece out -saving the crankshaft.
Hope it doesn't have to go that far.
Dec 19, 2010 | Clymer EvinrudeJohnson Outboard Shop...
The tension for embroidery is way off. The only thread visible is the bobbin thread. The top thread is almost invisible. Straight stitching tension is not perfect but OK
It sounds like the thread did not stay in the bobbin tension slot correctly. Try putting the bobbin in again and sure you have a suitable bobbin thread. If that does not work then a new bobbin case is what you probably need.
Aug 30, 2010 | Janome Memory Craft 9000 Computerized...
My HTS3400 DVD Home Theater stopped producing sound. It was working perfectly before and next time I used it, whithout having disconected any cable now I get a perfect image but no sound. The remote...
if you do a search on HTS3450 (same unit) you will find a thread with similar problems. My problem was similar and today I fixed it by changing 2 capacitors in the unit.
Nov 19, 2009 | Philips HTS3450 System
Creative zen mosaic is not being detected by either my laptop or PC.....a few weeks ago it was perfectly fine! Please help
This happened to me too! I found a very helpful thread online If the advice I'm about to give doesn't work, visit that link. I am running Windows Vista. I went to Control Panel>System and Maintainence>Device Manager>View hardware and devices>Portable Devices. When I did this I saw Creative Zen Mosaic listen with an !. I right clicked, uninstalled, and unplugged my Mosaic. I then plugged it back in and my computer automatically started in re-install. You may have to do it manually by clicking on a baloon that pops up when new device is inserted or something of that nature but this is what worked for me.
Mar 11, 2009 | Creative Labs Creative Technology Zen MP3...
Samsung yp-mt6
Try connecting it to your computer and go to "My Computer" and right-click on the drive and click "format".
Read this thread
Apr 04, 2008 | Samsung YP-MT6X MP3 Player
Creative Zen Vision M failure
my device isnt recognised on the computer and i hit reload firmware, so i cant add it on again, any suggestions?
Oct 05, 2007 | Creative Labs ZEN Vision:M Digital Media...
Il0 mp3
They may have Unplugged it B4 it was ready to be unplugged... this has probably "Corrupted" the Data... :( Unfortuantely ya probably going to have to reformat and put new music on it, ya may be able to get the data back with an un-erase program .. but I doubt that but worth a try here for the unerase proggy. As for the formatting look here Good luck
Jul 28, 2007 | iLO (2 GB) MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
83 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
