Question about Philips Audio Players & Recorders
I have a philips gogear sa178, and i tried to update the firmware and now it doesn't work at all.. It won't come on or even do anything when I connect it to the USB. What can I do, other than consider it bricked and throw it away.
  • uknowibeme Jun 08, 2008
    how do i re-install it
  • 868 Answers
You erased the manufacturers program and now have to have it installed.
Posted on Jun 08, 2008
Philips GoGear 4gb
Connect ..... Format .... if still does not work ... reset ... if still not working please upgrade firmware from philips website
Oct 14, 2008 | Philips GoGear SA178 MP3 Player
Philips gogear sa 175
i had formated it in windows and it works normal
Oct 02, 2008 | Philips GoGear SA178 MP3 Player
Sa177/00 "recovery mode" problems in Philips Firmware Manager
Try to defrag the drive .... is not workd thn format it manually frm PC n reset the set hopefully it will get back to normal. i did this with mine go gear n its fine now.
Sep 03, 2008 | Philips GoGear SA178 MP3 Player
How can i installed
here are some ideas:
1. try to install the software again that came with the mp3 player.
2.get a firmware update by going to www.philips.com
Jul 05, 2008 | Philips GoGear SA178 MP3 Player
HELP HELP HELP!!!!
Sounds like the firmware has corrupted. Install and run the Firmware Update software from the product CD.
Select the repair option and follow the on-screen prompts. This will re-load the firmware and should get your player working again.
Feb 20, 2008 | Philips GoGear SA178 MP3 Player
Wont stay turned on.
1) Make sure the usb charger is in the lock position before trying to charge.
2) Open Philips Device Manager and try repairing the device. [connect your GoGear to the computer, open Philips Device Manager (Start-->All Programs-->Philips), and click on the repair tab. Now, disconnect your GoGear from computer. Turn the GoGear off if it is not already. Press and hold the volume + key and connect the GoGear to the computer (while still pressing the volume +). A window will pop up saying a repair is being performed. now you can let go of the Volume + button. The repair will get your device working normally again. WARNING: the repair process will delete any music/other media file from your GoGear.]
3) after repair, perform a firmware upgrade ("Update" tab in Philips Device Mgr while GoGear is connected to computer - see Philips website for more details)
Worst case scenario - Even rechargeable batteries have a limited number of charging cycles. The battery for the SA178 is an LI-Polymer 300mAh 12-hr battery. Philips won't fix it for you, but you might want to find a local repair service.
-Tha Mp3 Doctor
Feb 07, 2008 | Philips GoGear SA178 MP3 Player
Philips HDD1630 MP3 Player about 2 years old, no excessive use, won't charge any more or be seen by computer. Only shows low battery on screen then dies. I am a little technically incline, can anyone tell...
You may have to change the battery, but try Reset, Repair, and Update (firmware upgrade) first. Also, there is an FAQ on the Philips website for the computer does not recognize device issue (but only follow it AFTER you have tried reset, repair, and update).
After repair, perform a firmware upgrade ("Update" tab in Philips Device Mgr while GoGear is connected to computer - see Philips website for more details)
Feb 05, 2008 | Philips HDD1630 MP3 Player
MP3 keeps deleting everything
Here is something that might help from tha mp3 doctor which i have gotton, thogth I still need the deivce manger:
-Tha Mp3 Doctor
Hope that helps and I just toke this from what I was told.
Jan 25, 2008 | Philips GoGear SA178 MP3 Player
83 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
