SOURCE: Removing obstruction from vacuum motor
Most Eureka's, there are 2 or 3 screws on the top to remove, then the top cover will come off. If no screws on top. then they are on the bottom. After the top is off, the belt and brush are right there in the open. To get to the motor, that off the 2 screws on the clamp on wach side of the motor, screws that are around the motor housing and then the motor cover should pull off. If the smell is electrical, if could be a bad motor, which sells for around $75 to $90. If the smell is more like rubber, then look at the belt and brush roll. If you need more info, get the model # off of the tag.
SOURCE: Motor slows down and makes burning smell
If the noise is coming from the canister motor, you probably have bad motor bushings. I had the same problem, replaced the motor and all was fine - only for one year. The problem is back and is due to the fact the motor is very high speed (to get good suction) and should be made with bearings, not bushings. I will not be repairing a second time as a $70 motor annually is a bit pricey, and yes it will get VERY hot. I will buy a new vacuum - not another Kenmore.
SOURCE: the motor makes a weird sound and starts to heat
If the motor sounds scratchy and is making a burning smell, or sparking you will need to replace the motor or the entire vac. Carbon brushes will rarely fix this as it is a high RPM motor
SOURCE: Loud whistling noise from back of vacuum
On the back side of most kenmore vacuums, there is an air relief diaphragm that, when the motor is sucking but there is no air flow, will pop, causing the sound you heard. check your hose for blockage, check your bag and or filter for blockage,even your attachments/wands can become lodged with debris. Often, after a few, the motor will get hot and the machine will shut down. This is a thermostat on the motor that protects it from overheating. I am quite sure that this will solve your kenmore woes, fine choice in vacuum, kenmore, tried and true. hope to have helped! Have a super, and hopefully sucking(ha ha) Sunday
