Question about Philips GOGEAR SA6045 MP3 Player
New problems ok.. so now it's completely dead.. i can't charge it because it has a "hardware malfunction" and i have already installed the software needed so there's nothing wrong with that.. but what is wrong with it now?
  • 8,596 Answers
You must run a repair using the Philips Device Manager that came with the CD. After you have done that, you must run the "update" with the Philips Device Manager.
Repair=1 time fix
Update=permanent fix
Posted on Jun 09, 2008
My Sony P1i just went dead one day. it won't power up. Battery is fine. when u plug power the light glows and steady. repair shop says software needs reload, is there i can do myself, itried firmware...
My P1i appears completly dead after running Update Service. I've tried removing the battery, fully charging the battery etc. When i run Update Service again it just says my phone is up-to-date.
any suggestions?
Update only says "No new software is available for your phone. Your phone already has the latest available software installed."
Then gives the option to Exit only
Sep 05, 2010 | Sony Ericsson P1i
Digital photo album - keychain
The message "No Photo Viewer Found, program termined" will happen unless you have the keychain plugged into the USB port in syncronization mode not charging mode. It's just saying it can't find a Photo Viewer plugged in to sync with. That should solve your problems. You can't update you image library unless it is plugged in
Regards
Balisonu79
Feb 16, 2008 | Digital Products Monaco Ezcolor Photo...
My phone is completly charged and when i pull it off charge about half an hour after depending on how much i use it, it turns itself off and then when i try turning it back on the Lg start up comes on then...
The happy news is there is no problem with phone,the hardware of your phone is in good condition.The problem is the battery.The battery of the phone is dead.This a step behind Stone dead stage.Next state of your battery is stone dead.You can't even use it more.Now the phone Battery will act like charging.Your battery can take small amount charge only because it is dead..Even though you charge your battery for 2 days continuously it will stay for 30 min or 10 min depending the charge usage.
Solution for this is you have to replace it soon..Go to nearest shop and check this with their battery and buy it.
Please do rate the solution if the issue is
resolved or post a comment for further
assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | LG KU990 Viewty
Completely dead iphone wont charge cant turn on itunes wont recognise. Help
just press the sleep button and home button at the same time until you see the small apple icon and then try charging it again.
Jul 03, 2010 | Apple iPhone Smartphone
Iphone is dead and and not doin anythin
Press and hold the sleep button (on top) and the home button, for about 10 seconds. The Apple logo should appear and your iphone rebooting.
You may need to connect to computer to recover using iTunes if the battery is completely drained.
Mar 07, 2010 | Apple iPhone Smartphone
Sansa Fuze went dead after charging; dropped about 18'' onto carpet earlier, but saw no problem until after charging.
sansa fuze mp3 players are notoriously pieces of ****. they malfunction randomly, and most of the time, unfortunately, cannot be fixed. i have experienced this first hand. even though it's actually a problem with their software, or the hardware in it. my advice is seek third party repair help.
Dec 29, 2009 | SanDisk Sansa Fuze MP3 Player
My new battery to my blackberry will not charge
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues, like charging issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Nov 04, 2009 | RIM BlackBerry Curve 8300 Smartphone
HP C81000 erroer code Oxc18a0001
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Pressand release the “CANCEL” button as many times as necessary, so that,either the “Welcome to Photosmart Express” screen appears, or, the “InkSystem Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THISSTAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait30 seconds for the power to get discharged and then plug the powercable into the wall outlet first and then into the back of the printer
12. Turnthe unit on. The printer may display message “USE POWER BUTTON TOSHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. Ifthe printer has already initialized, then go to the next step. If not,the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allowthis process to complete and do not interrupt. Once the initializationprocess is complete, the printer will print out a Diagnostic Page.
14. Toverify printer functionality print a SELF TEST PAGE. If SELF TESTprints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
source:http://fix-your-printer.blogspot.com/
Mar 19, 2009 | Office Equipment & Supplies
My ifoe p168 wont turn on when i charge it.
Either your battery is short (which means your battery is at a dead state of health and is unable to be recovered) or your device's software + hardware are completely malfunctioning.
First, try a new battery if all possible. This will determine if your problem is the handset or your current battery. If your unable to retrieve any new battery for tests, visit your nearest carrier for a quick diagnose. Ask them to try the device, using a new battery.
The phone will function correctly if the problem is the battery. However, handset can malfunction due to hardware issues and or software. It's important to try everything possible. Thanks.
Mar 16, 2009 | Dual Electronics CECT P168 Cellular Phone
Help! screen wxga LCD screen malfunctioning after ac.
It sounds like something came partially loose or was damaged. You can try that theory by taking it apart and looking. Or finding someone who can without charging you a lot. You'd be amazed what TV and video repair people can do. My guess is that it fell on its side, and a new LCD may be needed. But I agree that something may be done with it, as nothing is burnt or dead, as you said.
Mar 23, 2008 | Acer Aspire 5610 Notebook
Philips GOGEAR SA6045 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
