Question about HP Officejet Pro L7680 All-In-One Printer
Wireless upgrade When attempting to install the wireless upgrade, I can't get past the step that asks you to turn on the printer, wireless adapter.
    Novelist:
  • 183 Answers
Resetting the All-in-One
  • Press the On (wireless upgrade - fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Posted on Aug 19, 2008
My internet connection keeps dropping every few minutes and asks me to sign in again. Any suggestions on how to overcome this annoying problem?
Hello
Following the steps to overcome this problem:
1. Reset the router and reconfigure it 2. Re-install wireless LAN drivers 3. Scan your computer with latest virus remover
Hope this helps, if so do rate the solution Good Luck
Jan 10, 2011 | BenQ AWL 300 802.11b (AWL300) Wireless...
I installed the driver and the utilities program that comes with the driver still thniks that i have no card plugged in
Due to the fact that you have attempted to install the drivers for the wireless adapter, the device manager might be holding multiple copies of the drivers which might be preventing the drivers from being loaded properly. In order to address the problem, please do the following:
Step 1 If the computer has a built-in ethernet adapter, please make sure that you disable it.
Step 2 Boot into safe mode (press F8 during bootup). Once in safe mode, access the device manager (right-click my computer, left-click properties, left-click on the hardware tab, left-click on device manager). Expand the network adapters category and determine if there are multiple copies of the driver. If so, please uninstall them one by one until they are removed completely.
Step 3 Go to Control Panel, Add/Remove programs, and uninstall the D_Link configuration utility.
Step 4 At this point, restart the laptop and eject the wireless card. If you have a PCI adapter, do not reboot or remove the adapter.
Step 5 Make sure that there are no background utilities running such as antivirus, crash guard, or firewall. If so, please disable them.
Step 6 Run the installation CD in order to install the drivers for the wireless adapter.
Step 7 If you have a laptop, shutdown the computer and install the adapter. Turn on computer and Windows should install the drivers.
If you have a PCI adapter, reboot the computer and Windows should install the drivers.
Nov 11, 2010 | D-Link AirPlus Xtreme G DWL-G650 108Mbps...
How to turn on wifi
Configuring the optional internal wireless print server
If you purchased the optional internal wireless print server after your printer was already set up, follow these steps:
1 Install the internal wireless print server into the printer. For more information, see "Installing an optional internal
wireless print server" in the "Setting up the printer" chapter.
2 Click Start Programs or All Programs Lexmark 3500-4500 Series.
3 Click Wireless Setup.
4 Click Start.
5 Follow the instructions on the computer screen.
6 Click Finish to complete the installation.
Also here is the link to the setup guide and user manual
click here
configuring the wireless is in the setup guide
Oct 18, 2010 | Lexmark X3550 All-In-One Printer
I need to get a wpa passphrase how do i get 1
Difficulty: Moderately Easy
Instructions
Things You'll Need: · Wireless print server
· USB printer
· Ethernet cable
· Computer
1. Step 1
Obtain a wireless print server that is compatible with both your wireless network and your printer. While the printer’s documentation may not explicitly say that it is compatible with a print sever, many are compatible, and this can be verified by checking the website of the print server’s manufacturer. If you have a multifunction printer, only the print function will work with most wireless print servers, though a few have recently added support for scanning and the printer’s other functions.
Step 2 Read all of the documentation that came with the wireless print server. The manual will detail the specifics of the installation routine.
Step 3 Connect the printer to the wireless print server via the USB cable. Connect the print server’s Ac adapter and turn the unit on.
Step 4 Connect an Ethernet cable between the wireless print server and your computer. This will be used for the initial setup only.
Step 5 Insert the CD supplied with the print server into your CD-Rom drive. Start the software if it does not start automatically. The application will walk you through the installation process, which includes setting the unit’s IP address, setting an access password, configuring it to connect to the wireless network, installing the drivers that allow the print server to use the printer and installing the print drivers on your computers.
Step 6 Choose how your print server will be addressed. Most units are set up to use dynamic addressing by default, which means that your wireless router will assign an IP address to it. This allows the server to be easily installed on the network, but it also means that the IP address of the printer may change over time. The other option is to assign a static IP address to your print server. This option is more reliable, because the print server will always use the same IP address, making it easier for the computers to find the printer and easier to access the print server’s online configuration application. If your router has the IP address of 192.168.0.1, for instance, set the print server to something like 192.168.0.2 or 192.168.0.3, as long as another device does not use that address.
Step 7
Set a password to be used to access the unit’s online configuration application.
Step 8 Configure the print server to access your wireless network. Give it the same SSID network name as your router and set it to use the same wireless channel. If encryption is used on the router, enable encryption on the print server, and enter the encryption key or password.
Step 9 Follow the instructions given by the print server’s software for installing printer drivers on the unit.
Step 10
Disconnect the Ethernet cable and allow the unit to connect via the wireless network.
Step 11 Install the printing drivers on each computer that will use the printer.
Step 12 Access the print server’s online configuration application to verify all settings by entering the IP address of the unit into a web browser, using the “http://192.168.0.2” format. Enter the administrator name and password.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
AMILO LI 2727 cannot attach to my (or any other) wifi network since upgrading to windows 7
First Try This
Right click on the Computer desktop icon > Manage > Device Manager > Network adapters > right click on your Wireless Network adapter > Update Drivers Software...
If the Windows was unable to find drivers: go to the manufacturer website of your netbook > find your netbook model > download and install drivers for Wireless adapter
OR
You can try this solution:
Copy and paste the below text in to a text editor, save it and give it any filename with the extension .vbs, eg wirelessstart.vbs and copy a shortcut to your startup folder:
Set WshShell = WScript.CreateObject("WScript.Shell")
Set oExec = WshShell.Exec("C:\Program Files\Launch Manager\WisWBSet.exe")
do while WshShell.AppActivate("Wireless Status Option")=False
WScript.Sleep 100
loop
WScript.Sleep 100
It would be better that you restart the system after doing that.
And Thanks.
Mar 31, 2010 | Fujitsu AMILO PC Laptops
When I try and connect the HP wireless upgrade printing kit it doesn't recognise the adapter and so won't procede. Any ideas?
you do not need an upgrade kit.....this printer is a wireless printer.....so can use it wirelessly without any upgrade kits.....just need to run the wireless setup wi\zard on the printer from the front panel menus and then nyou have to install the s/w using the disc that came along with the printer and you need to select the connctivity as wireless and then follow the on screen instructions...
Mar 27, 2009 | HP Photosmart C7280 Printer
Can't connect to Intel pro set wireless
download and run everest and it will give you the exact name and location of the driver. to obtain a copy of everest ask me if u need one
Mar 04, 2009 | Computers & Internet
Did you enable the wireless adapter.
Press FN + F2 on the keyboard to turn on the optional wireless Ethernet radio
Jan 07, 2009 | Gateway MX6920 Notebook
Cannot change page orientation.
Hey there PoBoy,
When you upgraded to Vista home premium, did you do an Upgrade? Or a fresh install. If you threw in the CD and did an upgrade, that will actually keep your current files but upgrade the OS. Reason why I'm asking, is because you may have driver conflicts going on.
Try removing the drivers you've installed for this product. You may find them in the Add/Remove software list.
Once removed, install the fresh driver you got from Samsung.
If this isn't the case, I would attempt to plug the printer directly into your Vista PC to double check that it's nothing to do with the LAN connections at all. It's just best to rule out every possibility when troubleshooting.
Dec 08, 2007 | Samsung ML 2010 Laser Printer
HP Officejet Pro L7680 All-In-One Printer Logo
50 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
