Question about Navman iCN 520 GPS Receiver
No power to my ICN 520
Hello
I have been charging my unit. The green light has appeared showing that it is fully charged. I have ensured that switch on back of unit is switched to on, but am getting nothing when pressing on switch on front panel.
Any suggestions or thoughts?
Many Thanks
Gary
    Problem Solver:
  • 6 Answers
Have you tried the reset hole? make sure there is nothing stuck in there that could be pressing on the button. When you press and hold the reset button the screen stays blank.
If you press the reset button does the unit turn on? Mine turns on when I press the reset button even after I turn the battery off then back on.
Hope this suggestion might help you restore functionality.
Posted on Jul 09, 2008
How long to charge I only recieved it today
The initial charge will take the longest. I would give it 4 to 8 hours to fully charge.
Mar 07, 2016 | Audio Players & Recorders
When plugged into charger both lights show green but chair not fully charged
First measure the voltage of the batteries at the charging socket of the joystick.
Sep 28, 2014 | Pride Jazzy Select Elite
IS THERE ANYONE OUT THERE WHO COULD HELP ME????? I have had a Navman N20 but I have a problem. The power button at the top doesn't turn it on or off. When I charge it the light comes on amber but hasn't...
You need to hold the power button for about 5 seconds to turn it on. If that does not turn it on. Then you need to run a check on some of the components of the device. You start with the battery, then charger and the device seem to be working fine, because when you plug it in, the device amber lights come on. It is supposed to turn green when it is fully charged, but it seems like the battery is not holding a charge, that is why it is not turning green.
Test another well charged battery inside the device to see if it will power on and work properly, if it does, then it means all you have to do is to replace the battery, but if it does not power it on, then it means there is an internal problem with the unit.
Try to connect it to a computer to see if it will detect it. Once it detects it, try to charge in on there for some time to see if it will hold a charge there.
If it is properly charged, it will be able to power on fully. Also check the device on the computer to see if the software and files are still on the unit. That should also assist you in solving the problem.
Hope this information helped you.
Jan 05, 2011 | Navman iCN 520 GPS Receiver
My navman icn 320 keeps searching for gps signal
a few things to ensure
1) battery is fully charged
2) Thed correct BAUD rate and PORT are set ( see manual)
3) You are oiutside and there is a clear view of the sky.
Still failing? Then possible damaged SIIRF chip caused by starting engine while plugged into power socket
Please rate my help++++Thanks for using FIXYA
Jul 12, 2010 | Navman iCN 320 GPS Receiver
Unit does not power on
two things: It could have over heated and either cooked the battery or need to be fully charged before it will reboot.
Second there is a screen off mode, if you hold down the power button it will switch from light to lights off.
Jun 03, 2010 | Garmin nuvi 250W GPS Receiver
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
My psp has not turn on, but it was charging the orange light was appearing, but when i turn it on the green light hasnt appearing
Please make sure that the unit is fully charged. I am charging my unit for 2 hours. Also, please try to turn it on while the power adapter is connected to the unit.
Aug 04, 2009 | Sony PlayStation Portable (PSP) Console
Navman icn520
check the battery switch on the back. you will need a pen. Mine does the same thing. I believe this switch has to be set to ON for it to work. At least mine wont turn on unless the switch is turned on.
Apr 10, 2008 | Navman iCN 520 GPS Receiver
Mcx connector
Well I have done it with my magnifying glass dentists pick & my fine nosed wire cutting tweaser, and time... But more often it is easier to Disassemble the units & simply unsolder the Female Socket from the Board and replace with a new one, then ya can buy the connectors as a pair.. ensuring proper fit.
Sep 01, 2007 | Navman iCN 520 GPS Receiver
Navman iCN 520 GPS Receiver Logo
159 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
