Question about Polaroid i733LP Digital Camera
How do i fix my camera
Hi how do i fix my polaroid i733 camera
Well...i am currently goin through this process right now...see mai camera fell from about 5 feet on to racks...it still looks brand new...but don't know what to do...i suggest you find ur reciept and take it in to the place u bought it from or the company...
Posted on Jun 26, 2008
  • 3 Answers
SOURCE: i733 Polaroid camera will not turn on
If she dropped her camera, thats prob. why , because when I dropped my camera it did the same thing. I had to go back to target and buy a new one. sorry.
Posted on Feb 20, 2008
SOURCE: Polaroid i733
My pictures always come out very dark. I'm not sure if the settings need to be adjusted. I tried adjusting the color but, the pictures are still dark. What should I do?
Posted on Jul 01, 2008
SOURCE: I have a polaroid i733
My Son's camera had the same problem. 3 beeps and
it would turn off with the lens out. I think it must have
been dropped, he says no! Look carefully at your lens
and see if it looks crooked. If it is like his was, pull it out
a bit to straighten it out. His is working fine now!
Posted on Nov 12, 2008
  • 11967 Answers
SOURCE: Polaroid i733. Never had a problem connecting to
Use a card reader to download your pics.
Posted on Oct 26, 2009
  • 11967 Answers
SOURCE: polaroid i733 digital camera lens stuck open
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 29, 2010
Polaroid new camera
If its new, return it to point of sale for warranty repair, do not try it yourself it is faulty and there are no parts user can fix by opening
Jun 21, 2009 | Polaroid i733LP Digital Camera
Polaroid i733 card error
The i733 works with SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot, it won't work. You need to go with SD cards, 2GB and smaller.
Jun 13, 2009 | Polaroid i733LP Digital Camera
I do not have a cd to download my camera i733 7.0 megapixel to my computer can i download one from the internet
You can download the driver for the i733 at http://www.polaroid.com/service/software_download.jsp?PRODUCT%3C%3Eprd_id=845524441765978&FOLDER%3C%3Efolder_id=282574488338994&bmUID=1244334585671&bmLocale=en_US Please make sure to rate this solution.
Jun 07, 2009 | Polaroid i733LP Digital Camera
Countrybabe
transparent_v2_m56577569830469793.gif topnav_logo_sm_v2_m56577569830497019.gif print_icon_v2_m56577569830471789.gif Print back_arrow_v2_m56577569830474661.gif Back to previous page transparent_v2_m56577569830469793.gif i733 Driver
i733LP Digital Camera Driver
down_bt.gif Download Now
Information platform: PC size: 1.33 MB date: 02/27/2007
Documentation is provided in PDF. Demos and Tutorials are Flash files. flash_rune_v2_m56577569830542652.gif acrobat_v2_m56577569830542650.gif Get Flash Player Get Acrobat Reader Home | Shop | Products | Consumer | Business | Creative | Support | Company
Site Map | Store Locator Copyright © 2008 Polaroid Corporation | Polaroid Privacy Policy
Nov 11, 2008 | Polaroid i733LP Digital Camera
I733 Memory Full after 1 picture?
you need to buy an sd card that holds memory. most cameras don't have a lot of internal memory.
Oct 16, 2008 | Polaroid i532 Digital Camera
Polaroid i733
me too i need the software not the driver
May 06, 2008 | Polaroid i733LP Digital Camera
Lost USB cord to digital camera
Use a card reader. No battery drain while using the reader hooked to your computer.
You can find them bor between $8 and ????
Good luck.
Oct 24, 2007 | Polaroid i733LP Digital Camera
Polaroid i733LP Digital Camera Logo
47 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
