Question about Jenn-Air JGD8130 Gas Cooktop
Jenn-Air 30 in. JGD8130 Gas Cooktop
Is it possible to make by 2 burner gas cooktop to a 4 burner cooktop. I have 2 burners and a grill and never use the grill.
  • Anonymous Apr 01, 2014
    Fan won't stay on or up.
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Posted on Jul 07, 2008
Burners will not light; there is no sound of the ignitor either
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 12, 2011 | Jenn-Air JGD8130 Gas Cooktop
When one burner knob is turned to ignite all four burners turn on.
What do you mean by "all four burners turn on"
Some electronic ignite systems turn on on all the burners, But just the SPARK not the gas part of the burner.
Is this what you are describing?.
Jan 11, 2011 | Jenn-Air JGD8130 Gas Cooktop
Bought a 35 year old house with a jenn air gas cooktop. When I turn on the burner it does not light, just lets the gas out. I have been using a match to light the individual burner, I do not know wher to...
Sorry to read about your problem, I hope this helps you out.
check to see if you have power to the unit, it has no pilot lite
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 12, 2010 | Jenn-Air JGD8130 Gas Cooktop
Is 8000 btu.burner enough heat for general use
Hi, 8000 btu is a medium size burner, simmer burners are around 4000 btu, The largest are around 12000.
Feb 03, 2010 | Jenn-Air JGD8130 Gas Cooktop
Ignitor click and sparks, but no flames
there are two small holes at the base of the burner where the pipe goes up to it but doesn't touch. i had the same problem and it turned out that these two holes were clogged. i just straightedend a paper clip and solved the problem
Aug 29, 2008 | Jenn-Air JGD8130 Gas Cooktop
Six burner gas cooktop
My husband figured it out.....when we took the knobs off, I, of course, washed the area they had been sitting on, thereby spilling some water into the open part which contained the wires leading to the igniters.  A short time with a hair dryer sorting things out.
May 06, 2008 | Jenn-Air JGD8130 Gas Cooktop
Jenn-Air 30in. Exaust problem
liquid spill and alarm won't go off.
Mar 21, 2008 | Jenn-Air 30 in. CVG4280 Gas Cooktop
grab hold of the installed burner cartridge at he top of unit and pry up slightly, should lift up without much effort, if not try lifting front side. they jsut lift up and slide back in no screws hold them in place
Feb 21, 2008 | Jenn-Air JGD8130 Gas Cooktop
Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
Jenn-Air JGD8130 Gas Cooktop Logo
305 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
