My altec lansing in motion 600 charges my ipod but when i touch the power button nothing happens--it wont turn on
  • Anonymous Jul 26, 2008
    having same trouble but i cant get the power button to work even after disc the power cord..what gives?
  • mizg70 Jul 29, 2008
    My Altec Lansion im 600 used to hold a charge of up to 8 hours with the l-ion battery.  Now, it won't charge at all.  (The display says that it's charged, but unless it is plugged into a power source, it won't come on)
    This is a major setback since I bought this model so it would be portable.
I have the same problem. i have to unplug the power from the back of the speaker and then plug it back in. that seems to work, annoying though. callin altec next week
Posted on Jun 22, 2008
My Altec Lansing Inmotion used to charge my Ipod Touch, but since yesterdag (after not using it for 3 weeks) it won't charge my Ipod anymore. The Altec charges itself, but somehow the Ipod doesn't. It is...
That is a tough one. Is your iPod fully seated -- will it play music in the im600? Have you tried a different iPod in the im600 to see if it charges? Does your iPod recharge normally in other players, in a wall charger and your computer? If not, your iPod could possibly need a new battery.
Also: since it was unplugged for 3 weeks, you may just need to run the im600 through a full cycle or two (let the FM radio play until the battery is dead, with no iPod in it), then recharge the im600 for 5 or 6 hours, and THEN mount your iPod into it and see if it charges it. Be sure to unplug/plug-in the adapter into the im600 to ensure it is getting full power from the wall outlet. One last thing: the im600 will only charge the iPod when it is plugged into AC power; it won't charge the iPod while it's running on its own battery power. Good luck!
Jan 16, 2011 | Altec Lansing Inmotion-IM600...
Keeps shutting off on its own
I am having the same problem. It appears to happen more on low volume does that happen to you as well? I just called Altec Lansing. Mine may be under warranty still.
Altec said it may be the pins are bent slightly. Not sure i agree. One way to test is to hook up via the auxillary port and see if it still cuts out.
Jul 10, 2010 | Altec Lansing Inmotion-IM600...
Hi, I just got the new altec lansing ipod sound dock and a new ipod touch 3rd generation. The dock is not playing sound off of the speakers. Can you help me fix it?
have you turned the volume up from the speakers and the ipod?
thats usualy a problem people get
they think they have to turn volume up from ipod not dock
Feb 17, 2010 | Altec Lansing Inmotion-IM600...
The altec lansing inmotion does not charge my new ipod nano.What I can do
Maybe this could be the solution...
Source: http://www.speakerstation.co.uk/ipod-speaker-docks-ct-87.html
Important Note: iPods released since Sept 2008 (e.g. Touch 2nd Gen, 4th Gen iPod Nano and iPod Classic 120 Gigabyte, iPhone 3g and onwards) have an updated dock connector that means older revisions of speaker dock may not be able to charge these newer models of iPod/iPhone. Older docks should play music from these newer models with no problem.
The problem with charging is due to Apple removing support for 12v (firewire) charging on these new models of iPod/iPhone. Only 5v (USB) charging is supported on these new models. ..."
Oct 30, 2009 | Altec Lansing inMotion® iM500 Docking...
My IM600 won't power up.
Did you accidentally get the unit wet? I've been touching the power and volume buttons with wet fingers, and my unit just died. Also found a bit of a sticky residue on the pin inside the power connector on the back. I believe the button design allows for water to leak in, resulting in a short circuit.
Jun 06, 2009 | Altec Lansing Inmotion-IM600...
Inmotion speeker dock wont charge new ipod touch
This is because you are using different generations.
If the dock was only meant for 1st generation, then itwill only charge 1st generation. It's how they make their money.
Apr 19, 2009 | Altec Lansing inMotion Speaker System for...
5th generation iPods hose up while using Altec Lansing IM600
Yes, the docking station is damaging the iPod. The vibration when used load is causing damage to the iPod. If you notice, the iPod will only freeze when it is playing load in the docking station. To avoid the problem, you'll need to play the music at a lower sound with less vibration. Once I began to play my music at more reasonable sound levels, I discontinued the problem. Very disappointing solution...but it is the answer. I too called Altec Lansing. They are not aware of this issue...I told them to search the internet - it's all out there.
Mar 21, 2009 | Altec Lansing Inmotion-IM600...
My ipod doc will not turn on My ipod doc will not turn on
hy altec lansing have big problem whit her power supply block so change it first bey and good lock
Dec 29, 2008 | Altec Lansing inMotion® iM500 Docking...
The hp altec lansing laptop wont turn on, you press the power button and you get this flashing electric looking icon that comes on and it's pluged into the wall. what could be the problem?
my hp altec lansing laptop doesn't opwer on, the button lights up for 1 second and then shuts down,nothing happens to the screen, it stays blank
Aug 27, 2008 | Sony VAIO R505JL Notebook
192 people viewed this question
 Grubhead
Grubhead
