Question about LG 42LP1D 42 in. LCD HDTV
RGBPC input showing invalid format after move
I moved from one aprtment to another. When I was in my first place I was able to hook my RGB/PC up to the TV and use it as a monitor. After moving this function has become unavailable to me. I get a warning indicating Invalid Format. I am using the some connection set up I had previously. I do not know If when moving the TV I flickied a switch or someting. I have gone thru the input/menu settings on screen and have not been able to get the connection going.
Please advise
Thank you for your time,
David OLeary - Proud owner of LG products
  • Anonymous Aug 16, 2008
    when i turn the tv on all i get is "invalid format'
There is nothing wrong with the connection, your TV or computer. Just changw the resolution settings under the display properties. Start with the lowest setting 800X600 and move your way up. It will eventually appear.
Posted on Aug 01, 2008
THANK YOU FOR A SIMPLE FIX THAT WORKS!
Posted on Jul 23, 2012
LG HDTV Monitor Permenantly switched on but no display white screen with V.2.0.0 moving around the screen
sounds like you are possibly over resolution (setting resolution higher than the monitor can show. Try setting to low resolution and see if it shows up. Try VGA first and move up if it shows.
Jun 21, 2014 | LG Flatron N1910lzbf 19 Led Lcd Monitor 43...
Trying to hook my home PC into my LG TV gets me the message Invalid Format, what can I do to get the signal or can i use this tv for my monitor with a dell PC
Connect VGA (D-sub 15 pin) cable from PC to TV (RGB PC) input jack. Connect audio cable from PC to TV. Set screen resolution on PC to be compatible with TV, such as 800 X 600 or 1024 X 768 etc. Select on the TV, the PC INPUT using the TV remote when ready to use as monitor.
Under PICTURE on the TV select SCREEN (RGB-PC). You can AUTO-CONFIG or you can set resolution manually to the same you set PC to. Other adjustments can be done here as well to get optimum picture on TV from PC.
Mar 01, 2011 | LG 26LG30 26 in. LCD TV
Screen turns blue after Windows XP boot. It is
You cannot set your PC video resolution to 1920x1080 @60Hz?
Per user manual:
1. Set computer to a resolution supported by your HDTV (see Preset PC Resolutions). If your
computer supports it, we recommend 1920x1080 @60Hz.
2. Turn off the power to your HDTV and Computer.
3. Connect the VGA cable from your computer to the RGB PC jack on your HDTV.
4. Connect the 1/8-inch audio cable from your computer to the RGB PC Audio jack on your HDTV.
This step is optional and only needed to transmit audio from the computer through the TV.
5. Turn on the power to your HDTV and computer.
6. Select RGB using the INPUT button on the remote control or side of your HDTV.
Note: Refer to your PC computer user manual for more information about the video output requirements.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Sep 07, 2010 | Vizio VM230XVT 23 in. TV
I hooked up a compter to rgb-pc port and selected rgb-pc input and started computer the display comes up ok then it says invalid format how can i fix this russellwidmark@aol.com
CHECK YOUR GRAPHICS CARD DISPLAY PROPERTIES IE:
REFRESH RATE FREQUENCY 55HZ 75HZ ETC. YOUR TV MAY ONLY WORK WITH THE CORRECT REFRESH RATE AND COLOUR RATE CHECK YOUR USER TV MANUAL FOR SETTINGS
Aug 25, 2010 | LG 32LG30 32 in. LCD HDTV
I moved my tv and now I am getting message No RGB signal, power will be turned off
If you had something plugged into your component jacks that's the red, green, and blue That's what RGB stands for and they are usually accompanied with another red and white set of plug ins that is the audio. Sometimes people use them for hooking up their DVD players,Cable boxes, or Satellite receivers. When you moved the TV it might have come lose. If not you can go to input or input select on your TV and change the input to what you are using Composite,HDMI,etc.I hope I helped you.
Mar 03, 2010 | Vizio L32 32 in. LCD HDTV
I have an eMachines and when i hook up my 42in LG HD LCDTV says
You resolution on the eMachine is higher than what the 42inch LCD can support .. reduce is to size by check the LCD manual and make change in window display settings
Jul 18, 2009 | Computers & Internet
I put my rgb cable into my HD tv and when i put it to the inpute for RGB in it says invalid format and i have no idea what to do. I have played around with the graphic properties and such but no luck at...
Well you need HD calbes there Blue Green and Red not Red yellow and white so put these in the yellow red and white and use them as RGB because it is a invalid format!!
May 15, 2009 | Matrox PARHELIA 128MB 8XAGP TRIPLE RGB...
LG 37LC7D Connect to VGA from a PC
Your right. I just had the same "Invalid Input" issue as well and it completely relates to the resolution compatability with any VGA or HDMI connection. Check the LG website for the online manual if you don't have it and see the section on RGB-PC cable. There is a table that incdicates the Resolutions the LG product is capable of displaying.
Thanks for the help.
May 20, 2008 | Televison & Video
Connecting PC to TV
sorry guys sound is not ment to be transmited through a rgb cable its just for higher quality video you can use a the red and white RCA inputs to get sound to your tv but you need a headphone jack -rca cable or if you tv has a headphone jack just buy a cable with one headphone jack on both ends
hope this helps
May 17, 2008 | LG 32LC7D Television
CANT HOOK UP PLAYSTATION3 TO MY SURROUND SOUND SYSTEM
if you have your surround sound already hook up to tv already then yes (atgjohn) is right..But don't for get when you power on your ps3 to press and hold you ps3 power button until you hear two beeps and you'll ps3 will reset it self..some times if your ps3 is hook up to another tv the setting are stuck on to the other tv on your ps3,and you'll just get black screen with sound...
Mar 16, 2008 | Audio Players & Recorders
LG 42LP1D 42 in. LCD HDTV Logo
2,315 people viewed this question
Computer Repairing
Computer Repairing
