JVC AM FM CD DET FACE CAR STEREO Logo
Anonymous Posted on Jun 08, 2008
JVC Car Stereo Very Noisy
I put a new JVC stereo in my extreme.It was working good, but I wanted to upgrade the speakers. I changed the speakers out and the sound is horrible. Alot of cracking noises. I put the old speakers back in and same thing. Real bad craking noises. Is it possible the stereo is messed up? It didn't make these noises before, but now I can't even use it. Also the stereo is getting way hot. It will burn you if you touch it. It is grounded so I don't know whats up.
  • pfitech Dec 16, 2008
    After 5 years of normal use, I was getting some crackling in one channel from my JVC car deck (HDR1), I rewired so the deck drives the speakers directly instead of using the line-outs to go through the stock car amp, and today I had an episode of really nasty noise, had to turn off and on a few times and it got better. Hope it doesn't come back. Has this happened to anybody else?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 09, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
980
Points
Bought new JVC stereo and installed it. No noise, no cracking. 1st stereo must have been bad.
1helpful
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Replacing Stereo in 99 Plymouth Neon
What for? All you need to do is hook up the power wire, a ground and the speaker connections and you are good to go.
Want some good stuff go to Crutchfield. Have everything and very helpful with installation Crutchfield Car Stereo Speakers Home Theater Pro Audio 4k TV
1helpful
No sound dual xhd6420 92 accord lx
my brother has a 1993 Honda accord and had the same issue, we put it different speakers and it worked fine, don't know what the problem was but it worked
I don't know how to connect the wires from my JVC car stereo
Radio wire colors:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
1991 Oldsmobile Cutlass Supreme Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
No output from speakers in car.
Sounds like a couple speakerwires could be crossed/shortcurciting somewhere...;)
My JVC car stereo shuts off after 2 - 3 minutes
Answer me this. I just had a new JVC KW-V840BT installed in my 06 dodge dually 3500 w/ infinity factory setup. They have even replaced the stereo once (all in a month) but my JVC refuses to play more then just a couple of minutes. All audio just stops, no matter what source. I am thinking that the JVC and infinity factory system are not shaking hands well at all. This was installed by the store and I have another appointment to just go upgrade to a totally different head unit completely.
5helpful
4answers
HELP STEREO CUTS OUT!
ok , ive found the problem with mine. I checked the voltage between the earth wire on the head unit and the battery in the car. I found that when i turned the headunit up to around 17-20 there was up to 3volts differance, which is when it would cut out. So ive run a new earth wire and she's all sweet . Even the cd player works now.
My car stereo won't store the radio stations.How do I fix this. It is a JVC KD-S71R model
i removed my car stereo and put a new one in, i didnt like the new one so i put the old one back in, but since i did this it wont store radio stations! why??? all the wireing is the same the fuses are all ok, so whats changed???
I just want to ask... thanks
May not be an issue with the unit itself. Any blown speakers? Any shorted wires? It would be awesome to see if it worked in another vehicle or on a test bench. Then you would isolate either the vehicle or the radio as the problem.
RS525 5 1/4
The infinity system is unique in that the amplifier for each speaker is built right onto the speaker. You will need to bypass it by looking at the wire colors as they go into the JVC stereo, then finding them at the speaker. My suggestion is to just put 2 new speaker wires in and wire the speakers directly to the radio. You will have to routhe them through the dashboard but it's pretty simple to do. BTW, i know that vehicle well as I used to own one and customized the whole van.
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
