Question about GE WBSE2090A Top Load Washer
Washer Clicks hello i own a GE WBSE2090A2WW (model #), i start the cycle and it goes through 1st couple of them then hits a certain point and starts clicking and not spinning ( when this "clicking" happens the power in the entire house flickers with it), any thoughts? any idea would help, at this point ive looked inside and everything looks sound, but theres still a problem, haha, thank you. I'm having the exact problem with the washer that Malletman33 is having. I don't know if it is a problem that is worth paying a repairman or not. The washer clicks, stops, lights flicker, etc.
    Genius:
  • 3,422 Answers
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Goodluck..
Posted on Jun 08, 2008
Washer goes half way through wash and starts clicking. Motor will go into overload. When turned to manual spinn will click but spin slow. Switching to another cycle will sometimes start it working. In...
Barings probably over heating and expanding due to either dampness, lack of lube, bent broken or misaligned coupling. Is a warranty issue either way unless it was dropped during transit or used exessively on uneven surface. If its out of warranty you might be better of with a new one, trade in if possible.
Oct 31, 2009 | GE WBSE2090A Top Load Washer
Need to reset washer it is stuck in mid cycle and wont continue nor start over
doesnt this model have the cancel button by the start button.......if so........switch on then hold cancel for 10 seconds...........
cheers
Jul 24, 2017 | GE WBVH6240F Front Load Washer
Water will not stop filling wash basket, even when off
Your water fill (mixer) valve is failed in the open position.
CLICK HERE for the part.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 20, 2009 | GE WBSE2090A Top Load Washer
GE-WBSE2090A2WW
your main control board is bad ( Electronic Timer) if you need one let me know I can sell you one at whole sale but i would need model number to get the right 1
May 22, 2008 | GE WBSE2090A Top Load Washer
Washer Clicks
The main drive motor has a relay switch on the side of it. The clicking and power flicker along with only the first couple of cycles are a good indication if a bad motor relay.
Feb 19, 2008 | GE WBSE2090A Top Load Washer
GE Model WBSE2090A2WW - shut off intermittenly
Does the machine drain on its own or do you drain it manually? The drain pump may be jammed or seized. Try giving the door a light bang with your hand on the handle. The door interlock could be faulty. If the machine starts up after you hit it with your hand on the door handle, the interlock is faulty. Good Luck!!
Sep 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
GE WBSE2090A Top Load Washer Logo
99 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
