I have a phonic powerpod 740plus and have connected it to 2 100volt line transformer to 12 toa 30watt speakers when i turn it on it make a humming noise and when i plug in xlr mic leads which i have made from on the wall sockets to plugs useing red black screen cable it makes a load scweeching noise please help to solve this problem for me thanks
  • 1,512 Answers
Hi, a couple of questions for you. What pin connections have you made for the cables in the wall. are you using 2 core plus braid mic cable?
Please let me know and we can go from there.
The loud screeching noise you are experiencing, may be too much gain. Start with everything turned down, and work your way back setting levels to about 5-6 from the master level first. The channel gain at the top of each input strip should be you last adjustment.
regards
robotek
Posted on Jun 09, 2008
I tried hooking up a laptop to powerpod mixer it shows music is playing but nothing comes out of the speakers
Which inputs are you using? If you are using the 2T RTN, you will need to engage the 2T RTN button under CONTROL ROOM SOURCE and engage ASSIGN TO MAIN.
Sep 27, 2011 | Phonic Powerpod 820 / S712 PA Package
Phonic Powerpod 1860 - One channel xlr input stopped working. What could cause that?
Several things could cause this... connecting it to a piecee of equipment powered from a different wall receptacle cound result in ground bounce on the building power that could destroy the input circuits. Another thing is if a static discharge hit it... There are bypass capcitors at the inout that could have shorted. Of course the fader could have failed...
Aug 12, 2011 | Phonic Powerpod 1860 Plus Powered Mixer
Why do i have echo when i play music on my phonic powerpod 820 mixer
Visit this link to download the manual if you don't have it already. https://phonic.box.net/shared/crqxhlhmmz
This mixer has a multi-effects processor onboard, but the key is understanding the audio signal chain. There is a chance that you have your input audio going through an undesired effect, but without knowing your setup (input source, connections, mixer settings), it would be difficult to pinpoint the problem.
Apr 04, 2011 | Phonic Powerpod 820 Mixer
I have the Phonic powerpod 820. I ordered a Kuston powered floor monitor to add too the system. I know not to hook it up too the speaker outputs on the back of the mixer. So where do I hook up the powered...
You will plug an UNBALANCED 1/4 inplug cable into the MONI jack on the front of the unit. The other end will probably need to be an XLR plug to connect to the Kustom POWERED monitor. Please note that the UNBALANCED output of the Phonic is NOT good engineering practice. The Phonic stuff is normally low-end and they don't do everything correctely, although for a small system it should work. IF you get excessive hum from using a long cable to the Kustom with a "Kludged" unbalanced to balanced cable, you MAY need to use a DI box at the Phonic end to convert the unbalanced Phonic MONI output to a balanced line (XLR to XLR) for a longer run to the Kustom monitor. You might get a 1/4 inch TS to XLR balanced plug that has a transformer in it and use an XLR to XLR cable to the Kustom. Please note that having this plug in the Phonic hangs out and is easily bent over so I would recommend using a right angle connector at the Phonic and plug the 1/4 inch TS to XLR adaoter into that so the yanking of the XLR cable won't break the 1/4 inch adapter off in the Phonic.
Feb 23, 2011 | Phonic Powerpod 820 / S712 PA Package
I have speakers plugged into my phonic powerpod 820 right now but I want also to have the output of the mixer to go through an instrument amp, is this possible? If so, where do I connect the instrument amp...
Yes it's possible. I'm assuming you'd like to use the keyboard amp as a "monitor". In which case, take a 1/4inch TS (instrument cable) jack out of "Aux Send" into the input of your keyboard amp. Make sure the keyboard amp is turned up to a good level and that the Master SEND is turned up on the Desk.
Now you can make your own "monitor mix" for on stage use without effecting the F.O.H mix by turning up the aux pot (knob) on each channel you use.
You can use the CTRL ROOM output also, but make sure it's not giving a "Powered Output" from the internal amplifier in the mixer as you will damage the keyboard amp.
Jan 16, 2011 | Phonic Powerpod 820 / S712 PA Package
What is the ideal speaker specification to match the 8 channel Phonic Powerpod 820. is it possible to play live gig using this set up ? what is the maximum possible set-up ?
to get the best from this mixer output wise, you need to use 4ohm speakers rated at 150watts each. The 200 wat rating is at 4ohms. You can use 8 ohm speakers, but they recomend speakers at 70watts.
Gig wise, you could do a small location that will cater for about 40 people, but that would be pushing your system to the max.
Maximum possible set up? well there is a way to work most scenarios you are given, but it is not best practice.
Ideally, you know what instruments and vocals you want to go through the system, a rough idea of the size of venues you wil play and then ask questions on a system to suit.
Jan 12, 2011 | Phonic Powerpod 820 / S712 PA Package
Connecting a guitar amp to a mixer amp
Hi cliff
Connect either of the XLR DI output of the Behringer directly to a MIC IN channel on the Powerpod using a standard Microphone cable. If you wish to push a stereo sound then connect both(L + R) of the XLR DI outputs from the amp... that's about all you need to do. The only reason you need to use stereo(both XLR Outs) from the Behringer is if you want a full stereo FX output from the amp, otherwise you can get away with 1 connected. You may need to back the gain off for those channels on the power pod. You can get a manual for the Powerpod from here
and user manual for the acx900 here
Hope this has helped you, If not, feel free to ask any questions. Cheers.
regards
robotek
Aug 08, 2008 | Phonic Audio Players & Recorders
115 people viewed this question
 Grubhead
Grubhead
