Question about Cannon Office Equipment & Supplies
Printer color is off - Cannon Office Equipment & Supplies
    Scholar:
  • 107 Answers
Pls give details fo printer such as company ,model
with operating system.
Posted on Jun 10, 2008
My printer is not print same color my design printer r230
Buy Cheap printer ink from Peachtreeink.net They are Good Quality printer inks manufacturer with best quality.
Visit Cheap printer ink website at http://peachtreeink.net
Nov 17, 2013 | Epson STYLUS R230 InkJet Photo Printer
Printer has ink but wont print in color test page wont print in color, also aligned printer and it worked in color. cleaned printer head as well which printed all the colors. what else can i do? It seems...
Take color copy, test all colors are OK..Go to printer properties, printing preferences, finishing check is there any check mark on print in black cartridge only? mark on print color..apply..OK.. give print command..
Go to paint draw a color drawing, print it.> check colors if its not printing in color it might be drivers issue.. un install the drivers re install once again check..> if printed in color check the file which you are printed..take another file.. then test..
Oct 29, 2011 | HP Photosmart C6180 All-In-One InkJet...
Printer A10922 will only print in black. Color cartridge renewed 1 year ago and has been working well.
  1. Check that your color cartridge/toner is not empty or blocked.
    This is the least likely cause of the problem, but an important check to make. Most color printer drivers and/or software provide functions to verify alignment and color output. Consult your manual or open your printer driver by clicking Start : Settings : Printers and right-click on your printer's icon and select Properties. 'Browse' the Properties dialog for options that perform system checks.
  2. Look for a 'Print only Black and White' option.
    Open your printer driver's Properties dialog (see above) and look for a color option that uses black only. Uncheck it or select an option that enables color. Some color printers have different resolutions for color and black-and-white (usually higher resolution in black-and-white). Some applications (not Origin) will force a printer to use a quality mode that affects this option, and if the resolution is forced to its highest the color output may be disabled.
  3. Enable gray scale printing.
    Some combinations of printers and operating system versions can lead to a miscommunication between Origin and a printer driver. Under these circumstances, Origin may 'think' it is dealing with a black-and-white printer when it is actually using a color printer. Beginning with 6.1, the Origin Print dialog displayed one of two messages depending on the print capabilities read by Origin:
    1. Enable color as gray scale
      This check box displays for color printers
    2. Use simplified colors
      This check box displays for black-and-white printers
    If you are seeing the first checkbox and you are using a color printer, then checking the box should tell Origin to send all color information and let the printer handle any conversions that may come up. In earlier versions of Origin there was a rather cryptic "Print color on black and white printers" checkbox which did the same thing.
Apr 30, 2010 | Dell 922 All-In-One InkJet Printer
I have a Kodak Easy Share 5300. Just changed both
Apr 30, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer not printing in color
There is an option in the printer driver to print in color, B+W or greyscale - make sure it is set to color.
Apr 19, 2010 | HP LaserJet 2550n Printer
Dell color laserjet 5110 cn will not print color documents. This network printer was printing color fine until yesterday mid-day when it started printing in black & white only. I tested by printing a...
This has to do with the document printing properties. When you are ready to print a document, choose properties and make sure you go through the printer settings under that software.
The test page only verifies the cartridges. The printer properties of the software control the printer during printing.
Mar 17, 2010 | Dell 5100cn Laser Printer
Color feature is turned off. Need to turn it back on.
Go to Start Menu, Printers and Faxes and right click on the printer, select Printing Preferences, go to color tab, and uncheck print in grayscale
May 16, 2009 | HP DeskJet 5150 InkJet Printer
Color Printer Inks
No.  The answer I have found it to  hook up another printer also. I use a  B & W pin printer for most of my printing and leave the color printer turned off unless I wantto print a color document. Both are installed at all the times. Windows allows me to specify which printer I wish to use.
Apr 20, 2009 | HP Photosmart C5180 All-In-One InkJet...
Computer doesn't print color
Hi, the problem seems with the logic board inside the printer, are you in a position to open the printer and try some stunts, that is only if you have done it earlier.. let me know??
Dec 17, 2007 | HP PSC 750 All-In-One InkJet Printer
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
16 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Victorman
Victorman
Greg Cann
Greg Cann
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
