Question about Coby MP-C951 Digital Media Player
Mpc951- coby the player comes on with hdd read error. the player is not registering on the computer when the usb plug is connected. the player is stuck on the raido selection and i can't move it.
  • 6 more comments
  • roo_bee_dee Jun 24, 2008
    exact same problem as in chyna's posting - hdd read error & goes to radio... thx 4 any help :)
  • jblades2000 Sep 19, 2008
    how do you get the hdd ribbon back in?
  • Anonymous Oct 09, 2008
    i don't what to do
  • KDONOHUE Oct 28, 2008
  • filhodojo Nov 18, 2008
    my coby have the some problem
    i turn it on and  it says HDD Error e always play the radio
    i try to reset a lot of times, nothing change.
    plz help
  • Anonymous Dec 29, 2008
    it sucks!
  • mrmagic4 Feb 09, 2009
    exact same thing as posted above
  • sweetvalerie Apr 14, 2009
    how to reload the firmware after reconnecting the ribbin cable in my coby mcp951 mp3 player
My mp3 wont turn on any more it use to say read HDD error every time i turn it on and it would just go to the radio.
Posted on Oct 29, 2008
The ribbon cable that connects the hard drive to the board came off due to shock impact.
A local repair facility will be able to reconnect the cable.
Posted on Feb 20, 2009
  • gunfall Feb 20, 2009
    Hope it helps....
  • 8,596 Answers
Reset the player first. Then reload the firmware from the website if resetting fails to resolve.
Posted on Jun 26, 2008
Lightwave hdd media player that disconnects & reconnects
It could be either because of loose connection or fluctuating current supply to HDD. So make sure there is no loose connection. For the second problem, connect both the USB pins for the cable, if provided with the HDD. Also try connecting the hdd to different USB ports as well as to different computers.
If nothing solves your issue, then the problem is internally in the HDD, you have to get it repaired.
Please come back and rate my solution if it turns to be helpful for you. Thnx
Mar 23, 2010 | Electronics - Others
I have a dell inspiron 6000 laptop and whenever it boots up i get a message that says, ''A disk read error occurred.'' I got a new laptop for christmas, but there are things i would really like to have...
Get yourself an eide/sta to usb adapter. This will let you take a removed HDD from the old computer, attach it to the adapter hub and plug the usb connection into your new computer. Your new computer will read the old one as an external HDD and you can take all the files you want. Most computer retailers and Ebay have them for around 15-20 bucks.
Jan 12, 2010 | Dell Inspiron 6000 Notebook
When i connect my device to the computer it doesn't register anym
your usb plug might have gotton broken and can not register or go to control pannel and check your usb connection manually
Jan 29, 2009 | Mach Speed Trio Portable MP3 Player
HP Real Estate Marketing Assistant
crc is READ errors.
what is this install media
you never said, what media, CD/DVD or USB stick
nor how it was made. by you, or media came from maker.
crc is error checking system for files.
it can happen 3 ways, one reading a bad CD
or writing your HDD. (bad hdd)
windows does the check both ways
and the actual HDD does it internally, and if Sectors in the HDD
are bad, it replaces them (unseen on the fly) until such day the HDD
runs out of spares and is DOOM.
we run SMART test on all suspected hDD
the more modern unstated windows by you, will tell you the HDD is failing early, W10 for example warns of HDD internal errors.
Simple answer
CRC is like dropping deck of cards to the floor
you pick them up , count 51, and now right away this deck is no good. no need to count suites. at all.
CRC is the big brother to Checksum (card deck answer)
MD5 is what we use to check large down loaded files for integrety
cheers !
Aug 04, 2017 | HP Real Estate Marketing Assistant...
Phillips HDD120/05
Repair the GoGear - warning: this will delete all files from your player.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
-Tha Mp3 Doctor
Feb 10, 2008 | Philips HDD120 MP3 Player
Replacement space for COBY MP-C951
i player reads hdd read error, when turned on. I cannot move it off of the radio selection and the palyer is not registering when plugged in the computer with the usb plug .
Jan 23, 2008 | Coby MP-C951 Digital Media Player
Broken rca h116a mp3 player
i formatted my rca h116a 6gb on a vista and i got the "fat error! plz connects ums device format hdd" then i used it on xp and formatted it then it reset then worked properly try xp not vista
Nov 11, 2007 | RCA H116 MP3 Player
Iriver 320 HDD Connection
suggestion only, open it up and check the hdd connection. failing that, your hard drive is probly naffed
Sep 01, 2007 | iRiver H340 MP3 Player
HDD read error
I had the same problem with my mp3 player. The problem seems to be that the charge had been depleted - even though the screen said the charging was complete when I plugged it in. Disregard the screen, charge your machine for two hours, and if your player is like mine, it will be functioning properly afterwards. Hope that helps.
Aug 15, 2007 | Coby MP-C941 MP3 Player
Coby MP-C951 Digital Media Player Logo
313 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
