Question about Garmin Nuvi 660 GPS Receiver
Won't turn on or off
I can get it on by pluging it in then unplug, then hit stay on. To turn it off have to do the same procedure. In other words it works fine but the main power switch does nothing.. it is one year old and just starting doing this.
Thanks
  • 1 more comment
  • weatherbydoo Jun 10, 2008
    i also have the same problem, unit will not turn off, unless connected to car charger.... i have had the unti about 3 months and it just started doing this. I have the garmin Nuvi 650
  • bcavan Jun 12, 2008
    My Nuvi 360 on/off button does not work. One year old.Another 360 I had the same problem.
  • Anonymous Dec 09, 2008
    I have the same problem with my Garmin 650
  • Garmin Master
  • 2,130 Answers
This is a common problem with the Nuvi series. The on/off switch is a surface mount switch that is mounted vertically off of the main PC board.
The problem is, that there is no support behind the switch, so when you press down the button, the solder leads of the switch are stressed and eventually break off the main PC board. This is a design flaw and could have been easily prevented by wedging a small piece of plastic between the rear of the switch and the SD card housing to give the switch support. Also, the solder pads for the mechanical connections of the switch could have been made bigger, allowing for more surface area and more solder application.
I have repaired many of these before and I'll be posting a step-by-step procedure on how to fix this and prevent it from happening again.
I must point out however, that in order to make this repair, you will need to have skills in dissassembly and soldering.
- Jim
Posted on Jun 19, 2008
  • 1 more comment
  • SHARCNET-USA
    SHARCNET-USA Jun 20, 2008
    Also, please only attempt this procedure if your unit is out of warranty.
    - Jim
  • SHARCNET-USA
    Please contact me if you would like for me to repair this problem on your unit.
    - Jim
  • SHARCNET-USA
    SHARCNET-USA Aug 09, 2008
    Note to all Garmin Nuvi Users with a Defective On/Off Switch:
    1. In order to repair this problem, you need to have surface mount desoldering/soldering skills as well as the appropriate soldering tools and case dissassembly tools. Without these things, you take the risk of further damaging your Nuvi, possibly making it impossible to repair.
    2. Resoldering the switch is not going to resolve the issue long-term. In some cases, the switch can not be resoldered and additional rework must be performed.
    3. In order to fix this problem once and for all, the switch needs to be mechanically secured better to the main PCB using pre-tinned buswire. In addition, a custom-fit piece of plastic needs to be glued behind the switch to give it additional support.
    FAILURE TO DO THE ABOVE WILL RESULT IN THE ON/OFF SWITCH BREAKING AGAIN.... GUARANTEED!
    For a reasonable price, I will repair youf Nuvi on/off switch and put in the modications so it doesn't happen again. Repair takes 1 day, units are sent back the next day. Please contact me at KS3R at sharc dot net if interested. I have references.
    - Jim
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
I have a deep freezer,the light is on but doesn't freeze. It's only 2 yrs old what could be the problem?I unpluged it and waited 10 mins pluged back in and nothing the red light stayed on but...
Well a freezer is easy to repair. The circuit goes from one side of the power cord to the cold control and down to the compressor then out to the other side of the power cord. Id the control or compressor relay is open then she won't freeze. All the parts to it are listed HERE.
From the list I see an overload for the compressor. If that one is open it won't freeze. Bypass the temp control wires to see if she runs.
Sep 13, 2011 | Magic Chef Chest Freezer MCCF5WBX
I have a Channel Master cm-7000. It won't turn on. The red light is on it won't turn on with the remote or by pushing the on button. I tried unpluging it and pluging it back in and all that happens...
This is a common problem. There are several capacitors on the power supply and logic board that are bad. Replacement of these parts has restore all units that I have looked at.
On the power supply I would replace at a minimum:
C14 - 4.7ufd 50v UPW1H4R7MDD
C4 - 1ufd 50v UPW1H010MDD
C8 - 100ufd 25v UHE1E101MED
C10 - 470ufd 16v UHE1C471MPD
C12 - 1000ufd 10v UHE1A102MPD
There are 4 others in the supply that were not grossly bad.
C1 - 22ufd 400v EEU-EE2G220
C7 - 220ufd 25v UHE1E221MPD
C11 - Same as C10
C13 - Same as C10
Logic board:
E5 - 33uf 35v EEU-FM1A471
E6 - Same as E5
Part Numbers of replacement caps are Nichicon or Panasonic.
Note: Caps on the logic board are extremely hard to replace due to the internal ground plane.
Contact me if this is beyond your skills for possible repair.
Sep 07, 2011 | Digi Channel Master/tal to Analog...
Will not switch on. At first,it would turn on if I unplugged it,waited a minute,then pluged back in. Now,it won,t go on at all.
Could be capacitors in the power supply leaking, they usually swell a little causing this sort of problem.
pete
Nov 17, 2010 | Akai LCT3285TA 32 in. LCD Television
I moved our computyer from downstairs to upstairs.
Power supply is bad,,
You can try to unplug the main motherboard plug, then plug back in,, It should last as long as it stays pluged into the wall.
Keep it pluged in when you do this,,
Nov 30, 2009 | HP Compaq Presario SR1410NX PC Desktop
Stays on for about 2 Hours then shuts off
the bulb might be getting old causing it to over heat and turn off.
Jan 22, 2009 | Televison & Video
Dryer drum won;t turn
you have a bad motor / sorry to tell you but thats what your looking at / larryyb
Nov 24, 2008 | Dryers
Garmin Nuvi 660 GPS Receiver Logo
56 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
