Media center opens when any key is pressed
When computer is at the desktop stage, when any key is pressed the media center opens, can you help me fix it as i can't use the laptop now
  • natsem Jun 09, 2008
    I tried that option already with no success, any key still opens the media player, in addition to the keyboard issue, the touchpad is not responding, I am hoping it is related to the curerent problem :(
  • natsem Jun 16, 2008
    Acer has requested the laptop be sent in for repair, they are certain that there is problem with the keyboard's internal workings. We will keep our fingers crossed that they fix it asap. Thank you all for your help :)
CLICK ON ADD/REMOVE PROGRAMS
CLICK ON PROTECTOR SUITE 5.4
THEN CLICK ON CHANGE
THEN CLICK REPAIR
IT SHOULD FIX YOU UP
MARIN
Posted on Jun 16, 2008
  • 868 Answers
You must have used your "sticky keys" option.You can change this option in >go to 1.control panel >> go to 2.accesability option ,and make your adjustment there.
Posted on Jun 08, 2008
How do i connect my 360 to the computer
I had this same problem and found this great video on youtube.
go here:
http://www.youtube.com/watch?v=BaKgCYkSCjc
over 175,000 views
if you click the drop down on the info you'll see the step by step instructions.
STEP 1
If you were previously using your Xbox 360 with a Windows XP Media Center Based PC, you will need to remove existing connection. Otherwise skip to step 2.
At the Windows XP Media Center PC
Click Start, point to All Programs, point to Accessories, point to Media Center, and then click Media Center Extender Manager.
Select your Xbox 360 and click Properties.
Click Remove.
Click Yes to confirm removal.
At the Xbox 360
On the Xbox 360, go to My Xbox and then System Settings, then select Computers.
Select Windows Media Center, and then press the A button.
Select Disconnect.
Press the B button until you return back to the System Settings.
STEP 2 Gather Setup Key from Xbox 360
Press the Media Center Start button on the remote or go to My Xbox, then select Windows Media Center.
Advance through the on-screen instructions to obtain the 8 digit Media Center Setup Key. Write this key down.
STEP 3 Add Extender
At the Windows Vista-based Media Center PC, launch Windows Media Center. Select Start, Windows Media Center.
Select Tasks, Add Extender.
When prompted, provide the 8 digit setup key you received at the Xbox 360.
Complete the Extender setup.
STEP 4 Print the Media Center Quick Reference Guide
Dec 04, 2010 | Microsoft Xbox 360 Console
Computer wont startup but the processor continues to race..any ideas?
Before doing the below steps plz remove the harddrive's power n data cable...
First remove your RAM from the motherboard and notice any beeps from it and also press the num lock key continuous and find whether it off n on...
if above symptoms are ok then the prob is with your RAM...
Sep 17, 2010 | HP Pavilion Media Center a1330n - AMD...
Upon turning on my HP Pavilion Media Center it freezes at logo.
press F10 and format the pc with inbuild pc recovery and if it does not works then format your pc using the recovery discs given to you by HP.
Apr 15, 2010 | HP Pavilion Media Center TV m7360n...
HP Pavilion Media Center a1510 PC desktop, one long beep pause and one long beep keeps repeating, fans and lights working. Is it worth fixing?
One beep means a problem with your processor (CPU). You can try to reset it (there is(are) clip(s) on the side that hold it down to the socket). Unplug everything from your computer before opening. You may need to remove the heat sink on top of the CPU; get some thermal paste to put on the CPU before you replace it. Lift up the clip, make sure the CPU is correctly oriented (one corner is marked) and press it back down. Spread new thermal paste and replace the CPU cooler. Try rebooting the computer. If that doesn't work, you should try a new CPU - match to the socket on the motherboard. Unfortunately, if you use Windows, you will probably need to contact them to ensure that the OS key is valid.
I hope this helps.
(if your computer is really old or was cheap, replacing it with a new machine may be easier. Pull the old hard drive and either install it as a slave drive in the new machine or use a hard drive enclosure (IDE or SATA to USB or eSATA if that is on the new machine), a hard drive dock (SATA) or a IDE/SATA/USB dongle (that lets you connect a bare drive out in the open to the USB port) to get your data from the old computer.)
Jan 30, 2010 | HP Pavilion Media Center a1510n PC...
Dma scheduler
possible malware issue, try downloading free malware anti virus from this sight. download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html
Sep 11, 2009 | HP Pavilion Media Center a1330n - AMD...
I have windows xp media center. I go to control
I would try booting in to safe mode see what happens
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
If it works in safe mode you may have a permissions issue or infection of some type.
Run a virus scan.
Remove any devices connected to your computer.
Aug 18, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
Can't turn Computer on. Green light on back flashing
when you power up the computer check your smps fan is running then check key bord num lock key is it on and off when u press numlock key?
if it on and off then your computer is ok it should be screen resolution isssue.
For that when you power up the computer press F8 key then enter in enable vga mode then go to control panel and dispaly settings then change screen resolution to 1024*768 then apply and ok.
If it not works then open cpu cover and refix RAM.
also pull cmos cell from mother bord for 15 minute so all settings are reset to factory defaults.
then again put cmos cell in its position then check.
Jul 15, 2009 | HP Media Center m1080n (PC099A#ABA) PC...
Problem i fofrgot my login password
turn on your unit..press f8 so that you can go to safe mode..
if you are in in safe mode press enter.
go start menu click control panel..users account..
change your password or remove your pasword.
Jul 22, 2008 | HP Pavilion Media Center a1330n - AMD...
Start up problem
I've checked your media center model on the net and it appears to be a known BIOS problem. Keep in mind that this is most likely video card or motherboard failure. But we can try resetting it Try booting into the BIOS using the F10 key and then pressing F12 and pressing y. The system should reboot with the default BIOS settings. If there is any change you likely have a good chance at fixing it. Please post your results.
Jun 15, 2008 | HP Media Center m7060n PC Desktop
Hp media center pc 2002 remote stopped working. The ir lights up when any key is pressed on the remote, but computer won't respond to it. tried to roll back one day but didn't fix it. Tried to roll back...
If the menu button is on the remote and the unit is not responding to remote.....
try changing batteries and clean the remote and receiver lens.
Mar 16, 2008 | Computers & Internet
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
