Question about Acer Aspire 3000 Notebook
Acer Aspire 3000 wont load past acer splash screen
So my brother in law had a couple of laptops that he figured were just fried because he got nothing on the screen when he started them up and he gave them to me to see if I can do anything for them.
I was able to make the compaq work but am having trouble with the acer, but would like to give both back working if possible.
At first when attempting to power on the Acer Aspire 3000 the fan would start and lights would come on the front but nothing would happen.
I opened up the back and the memory was just hanging there not even connected. Once I got that installed properly, now I am getting the "Acer Screen" which will allow me to hit F2 to get into the bios, however if I dont go into the bios, the laptop reboots itself after this screen and seems to be stuck in this re-boot. acer screen, reboot pattern.
I thought that maybe the hard drive wasnt connected properly but tried to re-install that with no luck.
Does this sound like a problem with the board, is this laptop gone for good?
  • 7 more comments
  • Anonymous Jun 13, 2008
    WONT LOAD
  • theladebug Jun 14, 2008
    There are two cards in it.
    I thought it might be software, but it still will not boot off of the restore discs. It just powers down and re-starts after it leaves the acer screen.
    No luck. I've tried with each card and also in each slot and there is no change.
    Any other ideas?
    hmmm cant seem to find the Legacy USB support, but the boot device is set to HDD
  • theladebug Jun 16, 2008
    Hmmmm it could be that I have a bigger problem than I thought. It seems that I cannot get into any advanced settings through the bios on this machine.
    Actually I found the system cd which must be used before the restore cd and it seems to be working okay. I am going to continue restoring and see what happens.
    Looks like it might be a software issue after all.
    Fixed! Thanks for your help though, you rock! :)
  • Justasking Jul 25, 2008
    I have the same problem but I don't have the restore disks. Can anyone help? Brian
  • xCAUSALITYx
    xCAUSALITYx May 11, 2010
    How many memory cards do you have in it?
    Cheers
I have an acer aspire 3000 i change the video settings on the bios setup to both from auto and know im getting a black screen any help???both internal and external blank....
Posted on Jun 20, 2008
    Novelist:
    Champion:
  • 210 Answers
Thanks for the response, turn it off and remove the battery/power supply, now take one of the cards out, now put the battery/power supply back in and switch it on, if it still does not work, do the same again but put the other card back in and take the other one out, now switch on.
Let me know how it goes.
Cheers
Posted on Jun 14, 2008
  • xCAUSALITYx
    xCAUSALITYx Jun 14, 2008
    When it reboots press F2 and go into the bios and disable the "Legacy USB support", also make sure the boot device is set to HDD.
    Cheers
  • xCAUSALITYx
    xCAUSALITYx Jun 15, 2008
    Legacy USB support is usually located in the advaced tab in the bios, not to worry.
    At the bios screen keep tapping F8 until you get the options screen if it allows you and go in under safe mode.
    Cheers
  • 476 Answers
My understanding of the Acer 3000 set up....NOT A NuBEE
=========== VERY IMPORTANT ==================== Before you remove any compnents - Remove Power/Battery.
I have found best results with a Default Factory Settings reinstall from eManager ,to be quite reliable and their system is reinstalled within minutes.
Any missing components ie sound, vga, modem, usb,etc can be located on the recovery disks,also another important step is to do SP2 Windows Updates to give the devices the correct functionallity otherwise expecting them to function correctly without giving them the right tools and instructions would be premature and wasting your own time trying to make it work only to do your head-in in the process.
Other Acer Issues....
BATTERIES.
Replace when they die or use AC power pack.
VGA SIS 760G
Sorry not upgradable for video out,dedicated/shared memory type.
DEAD HARD DRIVES
mean a lengthy reinstall with recovery disks or reinstall OS from a separate machine then when Operating System is reloaded replace into Acer Hard Drive Bay now ready for Acer Reinstall.
HARD DRIVE RECOVERY
If its important === Leave it to the PRO's
RAM / Memory.
Ram slots x 2 . MAX 2GB = 1GB + 1GB
Readily available in many sizes 128mb,,256mb,512mb,1GB and many brands,Kingston,Transcend,etc....
RULE OF THUMB for RAM,
always put identical size ram ie 256mb+256mb... re sometimes the slowest ram is maximum speed so making them identical give double speed proformance instead of half ..re 256mb + 1gb registers 1.256mb but runs at 512mb.
WIRELESS/Axis Points & Blue Tooth Devices.
Works well if set up has correct Axis Point to Device Security Protocols Established and properly Encrypted too.
There are some clever people out there who can hack your wireless connections so I recommend a hard wired Cat 5e @ 100MBPS or Cat 6 @1GPS,(I think thats right)lol.
A closed network is more secure the an open one,
LCD Screen Replacements/Inverters
Can be done.Mostly Matt Finish or Ultra Bright Lcds.
CDRW or /DVD/RW
Replaceable and upgradable,
Note from The Author.
I have only touched briefly on the most common excerises and would like everyone to underestand some problems not covered here may require different solutions for the individuals specific problem/s.
Seek advise from trusted sources.
If in doubt try,
WWW.ACER.COM
or email me,lol
Thanks for reading my thoughts,I hope this helps the understandings and importance of these basic steps
Posted on Jul 10, 2008
  • Verne Koti Jul 10, 2008
    Ok for thisone,
    Load Bios default settings ,save and restart'
    DO NOT TOUCH BIOS ANYMORE...,
    Instead go to start menu,
    control panel,
    change resolution,
    Settings
    Click IDENTIFY>screen should come up with Screen Number 1
    Noting Screen 2 not present until you plug in Screen 2.
    When both screens are connected and powered up then you should be able activate the screens individually and save the settings.Don't forget shut down and reboot to save the new settings.
    If there is one picture only or bank,black 2nd screen try adjusting the pixel size to 800x600,unfortunatley this is the sacrifice for two screens of one vga card.Can't be helped.
    If you have acer grid vista installed then settings are accessible thru the right click on the desk top and select from properties drop down.
    About the Author.
    Currently Wholesale and Retail Electrical Sales.NZ.14yrs.
    CompTia ,A+,Network A+,Security A+,MSDTST.
    Sound & Lighting Technician,
    Laptop Systems Analyst.
    Experienced Electrician,25years
    Business Owner.
    General Nice Guy :]
Acer Aspire 7720-6155 wont boot
put cd in dvd writer then open the laptop and press f8 and after that if lap asked for esc/ or for enter press esc then it will work .
Sep 12, 2013 | Acer ASPIRE 7720-6155 LAPTOP LCD SCREEN...
I keep the message General Protection fault with a black screen when I turn my acer aspire 3000 on and it won't go past that screen/What can I do to fix it?
To repair corrupted system file/s, boot up with the Windows installation CD then -
Press R to repair when instructed.
Press 1 or Enter to repair the C:\Windows folder.
Then type chkdsk /r and then press Enter.
The repair process will take quite a long time.
Jun 16, 2012 | Acer Aspire 3000 Notebook
Acer Aspire 5720 Laptop problem. When turned on
Upon loading press F2 or del to enter bios setup and change the settings to display the acer welcome screen and the one you said about Microsoft logo and white box with green lines, you cant by pass it because it's windows loading screen
Dec 01, 2009 | Acer Aspire 5720-6661 Notebook PC
ACER Aspire 4730z laptop wont load into Windows
Sep 18, 2009 | Acer Aspire 4730-4947 Notebook
Acer aspire 3000
Could be a bad memory chip or a hard drive crash. Can you hear the hard drive engage? If so, is there any clicking or dull thunking sounds? Both of these are indicators of a hard drive failure.
Jun 21, 2008 | Acer Aspire 3000 Notebook
Acer aspire 3000 dropped on floor. Random startup events
theres a good chance that the hard drive platletes and parking head have been damaged, although this is not a huge problem to replace, as long as your screen is working ok, then it is worth replacing. you can access it on the underside of the casing, in the largest compartment, remove all screws and the hard drive will be held in with more screws.
Apr 14, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 5100
This is a duplicate posting, the main discussion can be found here: http://www.fixya.com/support/t133152-acer_aspire_5100
Feb 06, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
921 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
