Question about Nintendo Wii Console
Zero audio and video
I just got a new HDTV a while back and the first few monthes it worked great with my Wii until i started using the TV in my room and then going into the living room to play a game against my family. After that it started a few times where it wouldn't start up at all, but I was able to get it to work. NOW, its acting like there is zero audio/video output at all. We called Wii tech support and they said they would fix it, but before I send it in I want to know is there is a solution to this without having to send it in. I have tried a new communication cord but that seemed not to work so I need help. I would greatly appreciate it very much. Thanks
  • 52 Answers
It might just be the hard ware within the system that it probably why they are taking it in so i wouldn't really mess with it as it would void the warranty.
Posted on Jun 11, 2008
My TV started smoking
nothing FIXYA can do for you , SORRY
Sep 21, 2017 | Samsung LN32A550 32-Inch 1080p LCD HDTV
I just bought a toshiba 50M2U 50' series TV. I also bought a audio/video switch to connect my bose 3,21, surround sound sytem which still uses the red, blue, green cables and I have a wii system w
i think your problem is with cabling your surround sound is audio only and you wii is video and audio. i would hook up wii first and get it working first. dont plug the surround into the yellow jack on your audio video switch
good luck
Sep 09, 2012 | Toshiba 50L2200U 50" 1080p LED-LCD TV -...
Had my playstation 3 hooked up to my old television in the living room, i recently got a new tv for my room so i unhooked it and took it upstairs and plugged it in and it isnt working. no audio or video....
If it works with your Wii and not with you PS3, chances are your audio / video cables were damaged in the move. Try hooking up your PS3 to another TV with the same cables. If you have audio and video on a different TV with the same cables, it may be a problem with your HD settings. If the cables for the Wii aren't HD component cables and the PS3 cables are (or vice versa) this could be causing the problem, as the HD component cables have a different plug in than the normal video / audio settings. If this is the case, search around your TV to find the alternate connections and try those (these will probably require a different channel). If none of this works, I suggest you contact Sony about the problem and perhaps even send in your Playstation for repair. If you need anything else, let me know!
May 19, 2011 | Video Game Consoles & Games
Screen is compressed both horizional and vertical
Hi Rod,
If you can still see/read what's happening on the screen, go back to the Wii Options screen, select "Wii Settings" on the right, click the Screen option, and make sure "Widescreen settings" match your TV (if in doubt, choose 4:3). Click confirm, then click "TV Resolution" and ensure it is on Standard 480i. With these settings, the Wii should be viewable on almost any TV.
May 02, 2010 | Nintendo Wii Console
No sound on wii
Hello :
1: Make sure you have the volume on the TV turned up and the audio-video connections plugged into the same-colour plugs. Sound only kicks-in once you are at the Wii menu. If this doesn't work, continue to step 2.
2. Test the Wii with another TV. If you have sound there, then it is possible that the HDTV's sound inputs plugs are damaged. Send your HDTV off for repairs.
3. If the Wii does not work with the other TV, then it is likely that the audio cables are damaged. Order a replacement from Nintendo (instructions are in the Wii user's guide)
good luck .
rate please !
Mar 26, 2010 | Nintendo Wii Console
Nintendo Wii works fine on standard tv but not on hdtv.
FOUND THE PROBLEM !!!!! The problem appears to be the Freeview somehow interfering with the Wii signal. When the aeriel lead is removed the Wii works fine, and the audio/visual signal is great. When the aeriel lead is in I have the problems. I hope this solution proves to be of use to anyone else having similar problems.
Dec 29, 2009 | Nintendo Wii Console
Wii console to Philips HDTV Connection not working
In order to use the 480p (HDTV/EDTV) resolution, you MUST be using the Wii Component Video Cable. Any other cable will not display the 480p resolution, you have use the 480i (Standard) instead. You can order the Wii Component Video Cable through Nintendo's Web site. Using that cable, you can select the 480p resolution. Hope this helps.
Jan 26, 2009 | Nintendo Wii Console
DVD/VCR hook up to HDTV. No audio on DVD or VCR, no video on VCR
When you use component audio, it may shut off the side a/v audio settings. Try restoring all defualts (any changes you have made will be lost by doing so) according to p. 32 of the manual:
Menu --> Setup --> Reset --> Yes
-Tha Mp3 Doctor
Dec 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Can't get Video onto Television..Can get Audio.
Thanks for getting back five months later. I ended up buying a new Monster cable that worked just fine for like $40.
Dec 31, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Nintendo Wii Console Logo
20 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
