Question about ASUS P5VD2-MX SE Motherboard
Asus update unable to decompress file
I just need to update the asus updater software so that ican update the BIOS
    President:
  • 2,351 Answers
Hi cranelegs, just click on this link & it will take you to Asus site for you're board. You can download the BIOS-Utilities & bios file.
http://support.asus.com/download/download.aspx?modelname=P5VD2-MX%20SE&SLanguage=en-us
Good Luck!
Mike
Posted on Jun 08, 2008
I NEED BIOS OF ASUS P5GC-MX/1333
Hello download the bios version here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5GC-MX%2f1333&p=1&s=22
By selecting your windows system.
Open bios folder, and click global for download, for the newest version.
Download also ASUS Update V7.15.04, In utilitys, and please unzip both files.
Install first asus update, select update bios from file, and select the bios version you have downloaded, the rom file, and click next.
Now the bios update process will begin.
DO NOT turn off the power, when the process is running, and you have to setup the whole bios, when the job is done.
Follow the instuctions on screen, when you have rebooted.
Good luck
Feb 21, 2013 | ASUS P5GC-MX/1333 Motherboard
What are the instructions for flashing BIOS?
Hello use auto detect here to find the right mainboard:
http://support.asus.com/download/options.aspx?SLanguage=en
Download asus update, this is the easyest program to upgrade the bios, while windows is running.
Install first asus update:
http://www.softpedia.com/get/Tweak/System-Tweak/ASUS-Update-Utility.shtml
When the mainboard is found, select download, and select your windows system.
Open the bios folder, and download the latest bios version.
Unzip the bios file.
Run asus update, and select update bios from file, and select the bios file, in the folder you just have downloaded ( the bin file )
Be very carefull when you upgrade the bios, because a power loss will damage the mainboard, while the upgrade process is running.
You also have to setup the bios settings, when the job is done.
You have to select F1 or F2 to enter the settings.
If any doubt download the manual.
Good luck
Feb 07, 2013 | ASUS Computers & Internet
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
Board: ASUSTeK Computer INC. P4SP-MX REV 1.xx
Hello here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P4SP-MX&p=1&s=15
Please select your windows system.
Open the bios folder, and click on global for download.
The file has to be unziped.
You also need the asus update utility:
With this you can update the bios, while windows is running
You just have to select the bios file, you have downloaded.
But you have to setup the bios, when the job is done.
Good luck
Jan 30, 2013 | AOpen (918EA10I6D) Motherboard
Cerna obrazovka nemam disketu bios
Hi, you can download the bios here:
http://www.asus.com/Motherboards/AMD_Socket_A/A7V600X/#download
Download the asus update utility from here:
The asus Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows environment.
The Asus Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
Aug 25, 2011 | ASUS A7V600-X (90M7A820G0EAYZ) Motherboard
Cmos bios bad asus p5ld2-x/1333 i945gc. how i fix?
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS
The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment.
The ASUS Update utility allows you to:
You need an Asus motherboard in your system.
Rules for Safe BIOS update:
1. For safety reasons, always use the most updated BIOS utility!
2. Do not overclock the system/CPU during BIOS update!
3. Load "Setup Default" in BIOS menu before BIOS Update.
4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP).
5. Close all application programs under Windows.
6. Disable any existing Anti-Virus applications in the system.
7. Reboot the PC after the BIOS update is complete.
8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
May 23, 2011 | ASUS P5LD2-X/1333 - motherboard - ATX -...
I have an asus pn5sli mobo with 8 gig ram, nvidia 9800gt gpu,running windows 7 and am having crash issues.can you update bios using a usb as I have no 1.44 floppy installed and can you increase ram voltage...
Hello download your files here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5NSLI/#download
Download asus update in the utility for 64 bit system
Next download the latest bios
Please unzip the files before you install.
Install asus update and select update bios from file.
This can be done while the system is running.
Select the bios file you have downloaded
and the program does the rest.
Remember to download the right bios.Flashing the bios with a wrong file will damage the mainboard !!!!!!!!!!!!
And you need to set up bios when the job is done (the boot sequence)
Good luck
Dec 17, 2010 | ASUS P5NSLI (0610839134670) Motherboard
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
Aug 22, 2010 | ASUS K8N-VM Motherboard
Bios Updater Dont work
well dint get ya point but i found dis bios updater for u http://drivers.softpedia.com/get/BIOS/Asus/ASUS-P5V-VM-DH-BIOS-0909.shtml check it out it myt b helpful to n another thing is that r u using 3 of ur pc's @ one time when u using internet
if yes then ur ip myt b conflicting 1st of all bring some technician to ur home so that he can fix ur wireless stuff it myt be the problem i guess its not configured correctly so do it!
Oct 19, 2007 | ASUS P5VD2-MX SE Motherboard
ASUS P5VD2-MX SE Motherboard Logo
890 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
