Question about Samsung ML 2010 Laser Printer
LASER PRINTER Have changed the cartridge on my laser printer it is now sending out totally black sheets of paper
  • 81 Answers
Sounds like a faulty cartridge. DO NOT use it . Return for a replacement, otherwise you may damage the fuser in your printer
Posted on Aug 22, 2009
Samsung printer printing grey
The exit mirror of the laser-scanner unit is dirty. There is a gap above the toner cartrigdge, where the laser beam is comming from. Try to clean with dry soft lint-free cloth.
Apr 08, 2012 | Samsung SCX-4300 All-In-One Laser Printer
Upter refiling print paper is total black.why this probleme? printer --3119
Black pages are usually caused by a defective toner cartridge.
When filling this cartridge you must have dislodged a small metal contact that comes into contact with a metal contact in the printer. When they dont meet, black pages occur.
Jun 02, 2011 | Xerox WorkCentre 3119 Laser Printer
I am getting several black lines in scanned and copied documents of my DCP 7020 Thanks
Check the print document to see if the ink rub of easily,if so this mean the fuser cartridge need to be change.Turn off the printer and wait until it is cool before changing the fuser cartridge because the fuser get very hot when ever the printer is in use.
Open the fuser cartridge door. On most printers this door will be either on the left-hand side of the printer or in the back. Consult your owner's manual for the exact location. Flip down the clips that hold the cartridge in place, then grasp the handle and pull it out of the printer.
Push the new fuser cartridge in until it snaps into place, then flip the clips up to lock it in place. Close the fuser cover door.
Open the toner cartridge door and remove the toner cartridge. On most laser printers the toner cartridge is located either in the front of the printer or on the right-hand side.
Vacuum underneath the toner cartridge to remove all paper dust and toner residue. This debris has a tendency to build up and cause streaks and stains on the paper.
Wipe the interior of the printer with a soft cloth to remove any remaining debris that could cause problems with print quality. Continue cleaning the printer until all debris is removed.
Purchase a set of laser printer cleaning sheets, and load one or two in the paper tray. Print to those sheets of paper to clean the paper path. These sheets are slightly sticky, and they are designed to remove dirt and debris from the paper path.
You should also clean the print drum and the corona wires.
Aug 30, 2010 | Brother DCP-7020 All-In-One Laser Printer
Changed colour cartridges but it still says drum error
The "drum" is where the laser adds/subtracts an electrical charge to each spot on the drum.
The printer "throws" the powdered-ink at the drum.
The ink sticks to the "charged" spots, and does not stick to the "non-charged" spots.
Then, the printer puts a sheet of paper in contact with the drum, and the ink is transferred to the paper.
Then, the "fuser" heats the paper & ink, and "melts" the ink into the paper.
So, changing the ink-cartridges will _NOT_ fix any "drum" problem.
Jun 01, 2010 | Brother MFC-9440CN Laser Printer
How many pages per minute doe it print?
Black Print Speed:--------- 15 ppm***** Total Media Capacity:---- 250 Sheets****** Max Resolution (BW):---- 600 x 600 dpi*********
Being laser-based, the SCX-4100 is a more economical choice over bubble jet printer whose cartridges are expensive in comparison to their durability. But be mindful that the SCX-4100 is a black-and-white device – so no color printing/copying for you, although it obviously scans color documents. The toner cartridge is good for about 3,000 copies, a figure that can increase 40% with toner management software (included).
The device has a main paper tray that holds 250 sheets up to legal size. You can manually feed a sheet at time into a slot right above the front paper tray, and there’s also a rear slot for jam-prone material, like envelopes and transparencies. Unfortunately, the SCX-4100 lacks an automatic document feeder.
Thanks. you can rate this solution and show your appreciation.
May 18, 2010 | Samsung SCX-4100 All-In-One Laser Printer
I have HP 1008 laser printer.It prints wel but on entire sheet black strips is also printed on background.Does it has any relation with recommended page reached, HP says 1500 pages with a cartridge.There...
ahm its not the cartridge of your printer is the problem but its the printer head of your printer... printer head is the one that makes printed text...
Aug 29, 2009 | Office Equipment & Supplies
An inch wide streak appears on the right side of a laser printer printed page.
If you can rub the toner off the paper it is the fuser.
fuser, the part of a laser printer that melts the toner onto the
medium. It consists of a hot roller and a back-up roller. After toner
is transferred to the paper, the fuser applies heat and pressure to
ensure that the toner stays on the paper permanently. This is why
paper is warm when it comes out of a laser printer.
For toner problem:
Do a half test as follows -
Print one sheet from the fold down tray, just as the trailing edge of the paper
goes into the printer open the toner door to stop the printer. Remove the toner
cartridge, are the marks on the paper that you can see in the printer? If they
are there the cartridge needs replacing.
Jun 03, 2008 | GCC Technologies Elite 12/600 Laser...
Dark lines on printer paper
Possible.... other possible solution is a dirty drum... try changing the toner cartridge and cleaning the drum
Mar 11, 2008 | Samsung CLP 300 Laser Printer
Samsung ML 2010 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
