Question about Uniden EXP4241 (050633300466) Cordless Phone
Sanyo Fastext portable t.v.
I need to tune in the channels on this again, have lost the manual and cant seem to figure it out, any help would be much appreciated!
I have a MTV-680LCD TV and I cant get any channels to tune in. Does anyone know how to tune these or know where ti find a user manual?
I had a quick look around with no luck, if I found their website for your TV which again I am not sure of, it looked to me that their "world" ended around 2010 as that was the latest date I saw listed. They seemed more interested in a showcase of products plus carton size than any real help.
My only thought if its of any help is to find the factory reset in its menu system and start again and see if that works.
I have had a few sets of assorted brands that have "lost their tuners" which I have yet to figure out if its some software failure or a lump of IC that some use that has packed up, either way for most its their end as in todays world to repair is costly while exchange/upgrade (insurance wordings) is far cheaper.
Sorry I am unable to fully help you...........
May 12, 2016 | Televison & Video
Im trying to tune my sanyo lcd in ATV but cant work out how please help
The owner manual should have detailed instructions for hookup etc for this.
If manual is lost Google the model number with "manual" to try to locate a free copy.
Apr 10, 2012 | Sanyo Televison & Video
We just bought a Sanyo LED tv and channel ten is not found when auto tune is done someone please help!! :)
Test the signal strength using analogue tv mode and teletext page 284. If this shows no issue open up the TV tuning menu and use 'Manual Tume' until the missing channel shows on the screen and then Save.
Apr 03, 2012 | Sanyo Televison & Video
Accidentally set tv to display what appears to be closed captions during a program, not commercials - in Spanish, not my language - when searching for a way to have closed captioning. It displays on only...
You have a setting on the SETUP on your remote. You have the option to use English or Spanish. Somehow, you must have accidentally changed the language. I did this on one of my TV's.
Just go through the setup again.
Hopefully this will solve your problem.
Jan 09, 2011 | Sanyo Televison & Video
Can not change channel on my Sanyo LCD TV
I have not solved it but, when I play the dvd player it seems to make everything else work....
Feb 14, 2009 | Sanyo Televison & Video
I have no owners manula and need to retune the channels.
You can obtain a Sanyo version by visiting
The link is currently very slow but I have used it successfully on many occasions.
Nov 16, 2008 | Sanyo DS27820 27" TV
Sanyo tv no manual needs tunning ?
Hi I don't know what country you're in but there are websites that will supply direct replacement remotes. You could try here if you're in the uk:
If you can identify the exact model number of the appliance or remote you can also google for information, there may even be a picture of it somewhere or a source where you can obtain a manual.
Good luck...
Hope this helps
Feb 11, 2008 | Televison & Video
I Am Having Trouble Tuning My Channels On My VCR.
Hey is the VCR set for cable? even if it's not a local channel
could try to come in. turn the blue screen off on the VCR that
might solve your problem. If the channel is weak the blue screen will come on and block it. you can turn it off by going into
your VCR settings. Also If the cable is weak a splitter will
cause this you might have to hook the cable up directly to the
VCR to record it and watch it through the VCR. that's was may
problem once.
also you can tune channel 12 to your VCR manually if it is too
weak because of a nearby local channel it won't tune in automatically.
Nov 12, 2007 | Sanyo VWM-800 VHS VCR
Tuning Sanyo VCR
Press both channel buttons simultaineously for 3 seconds it will automatically tune your programmes press ok when ok flashes on vcr screen display
Nov 04, 2007 | Sanyo DS27910 27" TV
Uniden EXP4241 (050633300466) Cordless Phone Logo
123 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
