Question about AudioBahn A2301Q Car Audio Amplifier
Audiobahn A2301Q amp, charred RCA wires
I have a Audiobahn A2301Q amp and the internal RCA wires that go from the back side of the RCA jacks to a mini 3 pin connector and run to the opposite side of the amp were charred and shorted. The protect light is on and the amp dosen't work. If I replace those wires and connector's will the amp work again? Is there any other problems that might relate to this? Please let me know! Thanks.. Chris.
  • 631 Answers
If the amp goes into protect with the wires unplugged from the board, the amp likely has more serious problems. It may have a shorted power transformer and almost certainly has shorted output transistors. If you think you may want to try to repair it yourself, read through the following page (particularly the information in the yellow box). Respond to this post if you have more questions.
Basic Repair Primer
Posted on Jun 08, 2008
Audiobahn a1502dp amp only one channel is working. I need both to bridge it and get its full 1ohm potential. Where can I get this fixed? Preferably near kc
Audiobahn A1502DP True Digital Series 2-Channel Amplifier
www.sonicelectronix.com > ... > Car Amplifiers > Class-D Amplifiers
Rating: 4.5 - ‎4 reviews
Audiobahn A1502DP • True Digital Series 2-Channel Amplifier 1 ohm stereo stable 2 ohms bridged • True Digital Circuitry • Dual Cooling Fans • HP/LP ...
new amp, only one channel working?? help! [Archive ...
www.caraudioforum.com > ... > Car Audio: Installation Help
Apr 24, 2006 - 16 posts - ‎5 authors
the next step would be to try reversing the rca cables on the amp. ... unplug one wire, the one sub that is working, gets quieter, although it is still working. as ... It'saudiobahn, of course this could happen straight from the factory.Missing: a1502dp
[PDF]True Digital Full-Range Series - Audiobahn
audiobahn.com/.../Amplifiers/A752DP-A1502DP-A2502DP-A1004DP-...
A752DP/A1502DP/A2502DP ... Audiobahn was established in 1997 with one long-term goal in mind, ... Great products and proper installation are only a small piece of the puzzle when it ... from the smallest terminal, to power wires up to 0 gauge, and 4channel RCA cables. .... exceed the total value of fuses in the amp. 1 1 .
one channel not working [Solved] - Speakers - Audio
Jan 15, 2016 | AudioBahn Car Audio & Video
What size RCA jacks do i need for my Audiobahn A8005DN amp?
The standard Size will work great!! Preferably gold plated RCA cables sound the best.
Jun 04, 2010 | AudioBahn A6005DN Car Audio Amplifier
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Record on to mini disc
you can use optical cable / or mini plug to (Y) RCA jacks ...plug the optical cable to the back of a CD player or RCA jacks to your Reciever / Amp (output) to record
Aug 25, 2009 | Sony Net MD Walkman MZ-N505
No rcas inputs on amp
Hello sting_ya_sco,
The ACAP501Q has 2 sets of of RCA jacks. The first set is input and 2nd preamp outputs. The jacks are factory covered with plastic protectors. Just pull the protectors off and plug in the cables.
Hope this helps.
Jul 25, 2009 | AudioBahn A2002T Car Audio Amplifier
Audiobahn amp help...
You have a Direct Short in the System Between the Head Unit and the Amp. Check the Ground on the Amp and then Check all the Wires behind the Stereo and the Common Ground There. You could even have a Spot in the New RCA Cables that is Touching Metal Somewhere. Please Rate My Response! Thanks!
Feb 09, 2009 | AudioBahn A2002T Car Audio Amplifier
AudioBahn A2301Q
On the following page, go to the section labeled 'Checking Bipolar Transistors'. Under the two images, you will find a link to a form that will allow you to enter all of the values with the various lead configurations. Follow the instructions and send me the zipped file with the images. There's a link for my email address. Testing results are more definitive when the transistors are out of the board but initial testing in the board is reasonably reliable.
Checking Transistors
Jun 14, 2008 | AudioBahn A2301Q Car Audio Amplifier
For the most common problems, a schematic diagram isn't required. What does the amp do when you power it up?
If you're new to repair work, read through the following page. It will guide you through the most common types of repairs.
Basic Repair Primer
Let me know if you have any other questions.
AudioBahn A2301Q Car Audio Amplifier Logo
112 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Jerry Naidoo
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
