Question about Kenwood DNX7100 Car Video Player
How to connect a kenwood powered subwoofer to a 7.1 onkyo receiver
How would I connect these two components--the receiver has an rca subwoofer pre out--the subwoofer has rca left-right inputs as well as regular speaker type inputs and outputs
  • Anonymous Nov 03, 2008
    My Onkyo Receiver has a single Subwoofer pre out but the Atlantic powered subwoofer has only split powered and passive inputs.......when I connect the pre out to anything it only buzzes.....Help !!!!
  • 4 Answers
Easy.Get a 2 into 1 rca lead and plug the single end into the receiver and the other 2 into the amp
Posted on Jul 08, 2008
Can I connect a Kenwood sw-900 super woofer to a onkyo HT-R391 receiver home theatre sysyem
If your Kenwood super woofer is powered, look for an RCA subwoofer connector on the rear panel of your Onkyo and use that.
Dec 20, 2014 | Audio Players & Recorders
How can I hook up BIC F12 subwoofer to Onkyo TX-DS838 receiver? Will the receiver power the subwoofer and other speakers?
Get a RCA cable and connect from your amp where it said Sub Woofer in the Pre Out box in the back of the amplifier top left hand side and take it to the "Sub In" located in the back of your Sub woofer bottom right hand (White round connector).
Good Luck!
Aug 06, 2014 | Onkyo TX-DS838 Receiver
How to hook up my subwoofer
It sounds like you're doing everything right. Did you define the sub to the Onkyo (Subwoofer = Yes, page 22)?
Let's prove the sub works. Set its volume about half-way, cutoff= 170Hz. Temporarily connect an RCA cable from its Line Input to one of the Tape Out connectors on the Onkyo and play some FM through it. If it's alive you'll hear the low end of the music.
Don't buy into the hype that there are different pedigrees of RCA (or speaker) cables that will make an audible difference. Save your money.
May 04, 2010 | Onkyo TX-DS696 Receiver
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
Jan 01, 2010 | Onkyo M-282 2-Channel Amplifier
What is the best way to connect the infinity ps-12 to an onkyo receiver
best way is threw the LFE or subwoofer pre out on the back of the reciever. it uses a standard rca cable.
Jul 28, 2009 | Infinity PS-12 Subwoofer
Can't connect subwoofer to onkyo av receiver
you would need a y jack to connect those to the receiver
Feb 16, 2009 | Onkyo HTR500 Receiver
Need help hooking up a KRK powered subwoofer to an Onkyo 7.1 receiver
a single male rca spliting into 2 male rca's ....a signal splitter
Oct 30, 2008 | Onkyo TX-SR804 7.1 Channels Receiver
Hooking up my sub woofer
Hi ..
According to the manual there's a pre-out (phono style RCA) connector for the sub but it needs to be a powered subwoofer..Has its' own internal amp
Jul 26, 2008 | Kenwood VR-305
Connecting a passive subwoofer!
I believe the sub output that uses a RCA plug is not amplified and wouldn't work in your case.
Nov 14, 2017 | Onkyo TX-SR502 Receiver
Kenwood DNX7100 Car Video Player Logo
194 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
