Question about Whirlpool Calypso GVW9959K Top Load Washer
Washing Machine Repair
I had a pair of panty hose get sucked under the agitator on my Whirlpool calypso. What do I do to get it out?
  • 487 Answers
You will have to remove the agitator
There is no other way. Not to hard to remove it though.
good luck
Posted on Jun 08, 2008
  • Tracie Hentschell Nov 10, 2011
    Sooo- How do you remove it?
How do i fix my whirlpool washing machine that is not completing its spin cycle for modle#GVW9959KQ2 sherial #CS1192937
You may have the same problem I had: An item of clothing (in my case no pun intended there was a king sized silk pillowcase under the agitator and wrapped around the shaft. I removed the outter agitator and raised up the basket to wiggle out the pillowcase. She spins wonderfull now. I wrote 2 tips and included a manual and photos of the repair:
HERE
and HERE
I did 2 with the idea FY would remove one of them but I guess they like em both LOL
Oct 01, 2010 | Whirlpool Calypso GVM9959K Top Load Washer
I have a whirlpool washing machine and the red light for clean pump is on and i have no idea where or what to do have looked for my booklet but no joy please help. Thankyou Elle
HELLO THERE ELLI:
PLEASE READ CAREFULLY ,
when it's in pump-out (spin), the washer DOES make sounds, there is probably something clogging the hose going to the pump. Pair of panties, children's sock, anything relatively small. This will be BEFORE the pump. You'll have to remove the cabinet from the front (easy job), remove the hose going TO the pump, and check it out.
If, when it's in pump-out (spin), the washer just has a faint hum, the pump is probably locked down (pair of panties, children's sock, anything relatively small). Replace the pump.
If, when it's in pump-out (spin), the washer is quiet, the lid switch is broken. Very common problem. Replace the lid switch.
Don't automatically think 'clog'. These washers, while relatively loud machines, are very common-sense workhorses. Clogging is rare.
Jul 07, 2010 | Washing Machines
Whirlpool Calypso
This could be an out of balance condition. When its happened to my washer, I rearrange the load if its large enough, and if its not, I find other items of like weight and add them to the load and start over. Calypso's are sensitive to fabric weight, so If you're washing towels, wash only towels and wash cloths. Make sure you put small items, like bras, panties, nighties, etc., in mesh bags and combine them with other light weight fabrics.
Aug 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer ate a sheet
the wash plate has a rubber seal all the way around the bottom even the smallest gap can grab clothes and pull the under only solution is replace plate
Aug 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Clothes getting sucked under agitator
I was able to find information on another web site with a Whirlpool Calypso repair manual: https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
Check out steps 5 and 6 on page 36:
6. Using two (2) flat bladed screwdrivers, 90°
apart, in the notches provided, separate the
dome from the outer wash plate. (Fig. 3-11)
7. Remove the six (6) 3/8” bolts securing the
outer wash plate to the universal joint.
(Fig. 3-12) Remove the outer wash plate
from the basket.
That gave me enough room to lift the outer wash plate and remove three napkins and a wash rag.
P.S. Take precautions to keep the bolts from dropping under the outer wash plate.
Dec 01, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washer pulling clothes under agitator
The gap between the wash plate and inner basket has widened.
Part #WP285903 retail $65.75
Nov 05, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso
Have you checked the agitator? There may be sharp edges on the agitator blades. OR the towels may be getting stuck under the agitator and tub bottom. The agitator is supposed to suck the clothing down in the center and forcibly throw the clothing outwards against the tub. The cycle then repeats.
Sep 09, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
339 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
