Question about iRiver T10 MP3 Player
One channel not working on my iRiver t10 mp3 player
Like a lot of my dozen audio devices one of the channels went out probably due to bouncing around. Is there something I can fix myself since it happens so often?
  • Anonymous Aug 05, 2008
    I have the same problem. I opened it up but I can't get below the main board. How is that done? Also, how do I re-attach the spring latch when reassembling?
  • mark allen Aug 05, 2008
    I have the same problem. I opened it up but can't get pass the main board to the jack. How do I do this? Also, how do I reassemble the spring latch when closing up the T-10?
    Scholar:
  • 67 Answers
Most common cause is that the solder connection that holds the headphone jack to the board is broken. Usually can be fixed by taking the player apart and re-soldering the connection. Takes some effort and a pencil type soldering iron.
The T10 headphone jack is underneath the main board and you have to undo a solder connection in order to remove the board to gain access to the headphone jack. It's a lot of work but it can be done.
Posted on Jun 13, 2008
I bought a used iriver T10 mp3 player and cannot find the right software to install it on my computer. Where can I find this? I have XP
The iRiver T10 player is being sold with either MTP or MSC firmware,
depending on the country it originally comes from.
For MTP firmware, you'll need software Windows Media Player 10 or 11:
this software is installed when running XP SP2 or higher.
When not connecting with WMP you'll probably have the MSC version:
iRiver Plus3 software is needed for connecting this player (see below***).
Have a look in the player's System Info for knowing what firmware version is in the device: see the manual on page 55, page 29 in the pdf file. When not having the manual, go for a download to the Tech Support site:
http://www.iriverinc.com/lounge/loungeList.asp
In the bar [select a product], choose T10 from the list and click GO on the right, to get a view of all support for the T10.
Next select in the bar [select a category] Software&Driver and click GO
on the right. Updater for MTP devices and T series MSC drivers will show up: select the matching software and driver according to the previous check of firmware version.
When needing iRiver Plus3, click Plus3 in the page top of the support page or select next link:
http://www.iriverinc.com/plus3/overview.asp
Feb 21, 2010 | iRiver T10 MP3 Player
Is the iRiver T10 compatible with a Mac running OSX?
If it is MTP you can't...
Unless you plan on using on-line subscription services (PlaysForSure) you can just flash it the UMS firmware.
WARNING!!!
If you install the UMS firmware you will permanently LOSE Janus support (y'know, DRM subscriptions like Napster-to-Go) as you will NOT be able to go back to the MTP firmware (at least as of yet...)
Also do note that For the T10 there is a strange glitch. After you install the hacked firmware the player will not work at once. You will have to flash it again, this time using the ORIGINAL UMS firmware from iRiver.
If you are still willing to do it then go here
http://www.mtp-ums.net/
then here is the link to the official iRiver firmwares
http://nyaochi.sakura.ne.jp/iriverupdate/
You will probably want the EST (Australian) T10 UMS v1.62 (T10_EST_UM_OK) or the Kor (Korean) ones... (T10_KOR_UM_OK)
Aug 24, 2009 | iRiver T10 MP3 Player
Record reservation on Iriver T10 T60
check out the iriver h10 players
May 12, 2008 | iRiver T10 MP3 Player
T10 hard reset
Update the firmware - the description seems to indicate that this will resolve your issue:
http://iriverinc.com/support/ultra/t10_new.aspx
May 01, 2008 | iRiver T10 MP3 Player
Iriver t10
i would recommend that you use the device to format it...inside the device under setting there should be a format option..use that option and see what happen
Jan 26, 2008 | iRiver T10 MP3 Player
Broken t-10 earphone jack
try another headset to be sure its a problem of the player and not broken headphones. if its the player i hope its still under warranty, else you need to open it whats wrong. hot air soldering machine is an advantage..
Jun 16, 2007 | iRiver T10 MP3 Player
Iriver T10
Somehow the driver went missing. Click on "My Computer" and then click "view system information," then "hardware," then "device manager," then click on iRiver (it'll be there even without the driver) and then it will give you a yes/no option to look for driver software. Obviously, click "yes" but notice that you are also cued to put in a CD "if you have one." I still had the CD. It will search both the CD and online for a driver, but the computer found the driver software on the CD. Make sure you only put the CD in when cued to do so. If you don't have the CD, then contact iRiver about getting a driver download or having them send you a copy of the CD.
Mar 12, 2007 | iRiver T10 MP3 Player
Iriver T10 will not allow me to add songs
The updater that I could find directly via iRiver support did not work, but based on one of the other tips, I googled for the Version 2.7.0.0 updater ([MTP] iriver Firmware Updater for MTP devices).
http://www.iriver.com/flash/popup/flash_pop.asp?board=down&code=736
I recommend that you try the "normal" updater from the website (maybe yours is not an MTP version), and if that can't recognize your player, try the updater from the link above.
Note: The updater seemed to hang at 50% for over 5 minutes... I gave up and unplugged it. Then it asked me if I wanted to upgrade the firmware. "OK," I said. It took a few minutes. The screen went blank. I put in a fresh battery. Turned it on. It works. I was able to use Media player 11 to synch some songs to it.
BTW: It did blow away all the songs on the device, even though I chose "update" instead of "recover".
Dec 27, 2006 | iRiver T10 MP3 Player
My iriver T10 is not being detected
That happend to me and i found a solution. First go to my computer and on your left click on VIEW SYSTEM INFORMATION then go to HARDWARE now click in DEVICE MANAGER it should say T10 around there look for T10 or IRIVER T10 and click on it press in UPDATE THIS TIME ONLY or an option you like and click next then click on the RECOMENDED OPTION to install the iriver t10 after you do that a magnifying glass should appear and wait and it would install saying MTP.
If still need help send me a message at NOHEMYGIRALDO@SBCGLOBAL.NET
Nov 26, 2006 | iRiver T10 MP3 Player
iRiver T10 MP3 Player Logo
122 people viewed this question
Top iRiver Audio Players & Recorders Experts
aliasger yq
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
