Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Nikon D40 Download Problems
I am running XP Home which won't recognize my 4GB SD card made by Dane Electric when using a direct access port or any of my USB ports with a USB cable and card reader. Is this a formatting problem?? It downloads from the camera satisfactorily.
Hi my name is alicia and i am really worried my new D40 is is not taking pictures Autommatically only manually. i do not no why and yes i did make sure that it is on Automatic. could mu lens be the problem or is there something in the menu that could fix it please help me.
Posted on Sep 26, 2008
Everytime I try to take a picture indoors it seems as though the pic is overexposed (white). I am only able to take pics outdoors, has anyone else had this problem?
Posted on Aug 30, 2008
    Problem Solver:
  • 8 Answers
It could be the card reader is unable to read the card not your pc. You might be able to get a firmware update from card readers web site.
Posted on Jun 12, 2008
Insert sd card camcorderst recognize any micro sdcard
If your SP1 camera cannot recognize the micro SD card, please be sure you are using a card between 4GB to 32GB, class 10 speed. If possible, please try another micro SD card to be sure that the card that is not recognized is not defective. If you are using a card with correct specifications and it is not recognized, then the micro SD card port on your camera may be defective. Please contact Intova directly via email: fatema@intova.net or call us at 808-837-0074 for customer service/warranty coverage. Thanks.
May 28, 2013 | Intova SP1 Sport Pro 12.0 Megapixel,140...
Pictures show up on memory card in camera, but computer won't recognize the card - either inserted directly or by USB
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Aug 11, 2012 | Nikon D40 Digital Camera with 18-135mm...
When I put into my camers Nikon D40 IT SAYS IT IS LOCKED?
I sure hope you mean an SD or an SDHC card, since the D40 doesn't take CF cards.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 17, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
I'm useing the pny optima sd/hc 60 hd 4gb scan disk! it has photos on it useing the camera,nikon coolpixl20. using nikon transfer does not load pictures on computer.
I had same problem. Neither computer nor printer would recognize the SDcard. I took the card to Walgreen's and the card was read just fine. I suspect that we are running XP and do not have the right driver; but I can't seem to find the right driver. Morgen
Dec 07, 2009 | Nikon COOLPIX L10 Digital Camera
My computer is not reading the memory card. Nikon D80
If you are using a 4GB or higher SD card, some computers cannot read it directly from their in-built SD reader. Buy an external card reader and plug it in. Your computer should now be able to read cards 4GB and larger
Oct 07, 2009 | Nikon D80 Digital Camera with 18-135mm...
SD Card in Nikon F10 not recognised by XP
It could be one of two problems. The most likely is that the card reader you are using cannot read SDHC cards, of which all 4GB and larger cards are. Try using the camera's cable to download to your computer directly to the USB port. I bet you'll find that it works that way. The other problem could be (but not likely) that you are shooting on the RAW file format, instead of the jpeg file format. Most software cannot recognize RAW files, but jpeg is pretty universal.
Mar 19, 2009 | Nikon Coolpix 8800 Digital Camera
Cannot transfer photos to XP from SDHC Ultra II Card
Took it to Jessops by the process of elimination "Integral reader faulty."
What a waste of many hours !
Feb 02, 2009 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
Will Sandisk yltra II 4gb card work with Nikon D40?
I assume you mean Sandisk Ultra..and the answer is Yes it will work fine.
A good choice card also..
Just beware that some computers will need the SDHC reader.
For example my SDHC cards can be read in XP without the reader but my Vista machines need the reader.
Good luck and happy shooting :-)
Nov 04, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Memory Card Error
Hello. Make sure the write-protect switch on the SD card is in the UP (nearer to the contacts) position. Try the card in an SDHC capable reader on your computer first. Note that the SD card can only be inserted one way - make sure you're not putting it in upside-down! If the computer recognizes the presence of inserted card (whether it can read it or not), format it at FAT32. When finished, remove properly (icon in system tray) and insert into your D40 slot, WITH THE CAMERA OFF!! Turn on the D40, and if it now recognizes the SD card, FORMAT it again, in the camera. Good luck.
May 26, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
64 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
