Mica 311 dvd recorder
I hav brought USED MICA DVD RECORDER without user instructions, is there any way to downlod manual or instructions for this recorder. it plays dvds ok, but dont know how to tune it to reciove tv signals for recording. I have just uprgraded from VCR to this and am lost without any instructions
  • Anonymous Jul 30, 2008
    need to record a dvd from my tv
SOURCE: Toshiba DVR recorder incorrect disk message
You could try the factory initializing process I found on another webesite (AVS Forums): "Had this message pop up a few weeks ago. Tried the solutions in the manual, no go. Tried unplugging it for 7 days, no go. Called Toshiba customer service @1-800-631-3811, the tech told me: 1) turn on TV and set to receive your DVD signal 2) Turn on DVD player and remove any discs 3) put Dvd / VCR selector on DVD 4) at the same time, push channel selector button UP (^) along with the PLAY button 5) hold the buttons down until TV screen shows "Initializing" message, release buttons, let DVD player go thru it's reset cycle and shut down 6) turn DVD player on and watch your DVD movies now Works like a charm. Put this in your manual for the next time." My unit has not worked since December of last year, I only had it for one year and it conveniently stopped working right after the one year warranty. My unit was not functioning whatsoever past turning it on, but when I did the factory initialization I was able to operate my unit again....UNFORTUNATELY, it still does not read disks, I still get the "Incorrect Disk" message. I guess I could consider it progress. But still try it, it may work for you. My unit just seems to be fried beyond repair. If anyone has any suggestions on how to correct the incorrect disk problem, I would be greatly appreciative. I'm not ready to throw mine away yet!
Posted on Sep 08, 2007
SOURCE: vcr to dvd recording
As i recall, +r's will only format in dvd vr, the unit does not like high speed recording disks. switch to dvd drive - insert blank disk - if no format screen - goto (on remote) setup - onscreen menu - system setup - disc setup - new disk format - hit center button in ring on remote to change to vr or move up to reformat as vr. once disk is formatted, use record speed button on remote to set record speed 1,2,4,6 hr then switch to tape deck with tape in and stopped at begining, on remote hit dubbing, it will ask you confirm dubbing vhs-dvd .... toggle over to yes & hit center button... away you should go... c245 is a copyguarded tape.
Posted on Nov 08, 2007
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}To reset the Toshiba D-VRX4 DVD/VHSrecorder you turn it on and press and hold the "channel up" and"play" button until you get a message that says, "initializingto factory settings.". When done the machine turns off automatically, and you turn it onagain. Every time mine has stopped working this has fixed it. This might work with yours as well.
Posted on Oct 05, 2008
  • 40 Answers
SOURCE: how do i hook up dvd recorder/vcr to my tv?
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
Video output - yellow.
Audio output - left and right - red & white.
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
Posted on Feb 13, 2009
SOURCE: PioneerDVR-225 recorder
This is an old complaint. I hope you got the remote. You have to connect VCR output to line-1 input on DVR, and you must also select it with the remote. I've been using it for a while, and it seems to work well. Remember to FINALIZE.  jj
Posted on Feb 28, 2009
I hav just bought a Samsung NP-NP210 Laptop,
I hope this URL will help you
Mar 31, 2010 | Computers & Internet
Looking for a manual
ok, download from--
but before you need register on the site
thank for using FixYa.
Nov 14, 2008 | LG RH177 DVD Recorder/HDD Recorder
Remote control
You can obtain the User's Manual (Contains step by step instructions) with code list from the link below
Sep 06, 2008 | Zenith DBZN-311 Remote Control
im looking too what would u like to know tho about it
Mar 14, 2008 | Lite On LVW-5115GHC+ DVD Recorder
Philips dvdr 3380/05
Go to
After setting you language/country options, enter the model number and search.
From the list select the model with your country code after the "/"
EG dvdr3380/05
Click on "User Manuals", then select the relevant file to download from the right hand window.
The manual can be downloded
Jan 20, 2008 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
