Identifying left and right ear for sound
How can I determine which side of the headset is for the left ear?
Thanks
  • 1,512 Answers
Hi Jscreamer
Turn the balance control from left to right, The sound should fade from left to right in the same direction you turn the balance control. If it does not, then you got em on the wrong way about. They often fit better the right way around too.
regards
robotek
Posted on Jun 09, 2008
Right and left sounds are off
Have you pressed the plastic circle on the left ear? Hold it for 2-5 seconds until you hear a double or triple beeping sound and a colour of light should go on on both ears!!! Hope this helps! ;)
Feb 01, 2014 | PDP Afterglow Universal Prismatic Wireless...
Sennheister RS120 head phone left ear no sound
Dear friend ,
try to check wiring connection by opening tic tac locks of left side. If there is loose connection solder it .
Sep 30, 2013 | Sennheiser In-The-Ear PC Headset Headset
TV Ears -Light is green on base.Rest of lights are not on..Cannot hear sound emanating from earphones
When you have your head phone on your ears, there should be no Green light, unless you have another headset on the transmitter base in Front Slot.
Having Green or Orange light on the larger LED on the left side has nothing to do with the audio, that light is only for Charging indicator.
You should have ALL FIVE RED LED light on, if any one is out, you have a failed LED and would need to replace ALL small LED ( five of them on the right side) with LEDs from Radio Shack SKU# 276-143 High-Output Infrared LED or buy it from http://www.newark.com/optek-technology/op291a/ir-emitter-890nm-t-1-3-4-through/dp/08F2980.
Aug 24, 2011 | Dual TV Ears - Headset System Headset
In recent days my headset (590A) has only been transmitting sound on the right ear via bluetooth connection, when I use the 3.5mm jack (connected to left ear) both ears work. Is there a fix for...
Your headset can be used as stereo headphones or a wireless microphone for a bluetooth enabled device like a cell phone or a computer. When you plug the headphones into a device with the 3.5mm jack the headset automatically turns into stereo headphones and disables the microphone(headphone mode). It sounds like whatever device your headset is connected to via bluetooth is using the wireless microphone protocol where sound only comes through the one speaker and the microphone is on(microphone mode). The bluetooth protocol settings of your device may have been changed accidentally. You will need to go into the bluettoth settings of your device you are using with your headset and change the protocol. If it is a cell phone you will need to go into the bluetooth settings in the settings menu. If it is a computer your can adjust the bluetooth settings in the control panel.
You can download the pdf file of your instruction manual for your headset here
I hope this was helpful and let me know if you have any other questions. Thanks for using FixYa
Oct 15, 2010 | Plantronics Pulsar 590A Wireless Headset
Left ear doesn't pick up sound
sounds like you have a break in the cable or a bad solder joint on the product if new get a refund
Jun 13, 2009 | Logitech Precision PC Gaming Open Air...
I cant hear the gameplay in the right ear
Have you tried using your X1 with an iPod or MP3 player? Try that, and if you hear sound through both sides of the headset from the MP3 player, then the problem is in the "Stereo Splitter Cable", which can be replaced. But if you only hear sound out of the left ear from the MP3 player, then the headset is probably broken and you should contact Turtle Beach tech support at support@turtlebeach.com.
Jun 07, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Bose Aviation headset Series 2 has high-pitched squeal.
Try wearing the headset the "wrong way". The left side of the headset on your right ear & the right side of the headset on your left ear. I have the QC15 with the same problem and it worked for me. Good luck!
Jun 03, 2009 | Bose Aviation Headset X Headset
Motorola S9 headset plays music in one ear
I had the same problem with a Samsung phone. There are two ways of fixing this; First, you can remove the S9 profile from your phone's bluetooth list, and then add it again, going through pairing and entering 0000 on your phone when asked for the code.
Alternatively, you might try pressing the "play" button on the right earpiece on the Motorola S9. This is supposed to kick it into the A2DP stereo mode for music listening.
Good luck.
And get a copy of the manual from the Motorola web site at http://direct.motorola.com/ens/s9/Headset_Home.asp I found this very handy for checking what the little flashing lights mean. When you get stereo reception, the little LED in the middle of the headset flashes green, not the usual blue and red and purple for voice calls.
In case you didn't know, as a phone headset, with the microphone activated, you only get sound in your left ear, and the light flashes blue. For music, you get both ears, and it flashes green. So if it ain't green, you are in mono mode.
Feb 22, 2009 | Motorola Mobility S9 Headphones
77 people viewed this question
 Grubhead
Grubhead
