Question about LG 42LC2D 42 in. LCD HDTV
Connections my brother has a 42" sylvania flat screen tv .....We do NOT know any longer how to watch any longer TV (cable) since he has purchased a SONY theater system (DVD) ......Because of this, All, he watches know is loads of MOVIES (whew)!!!!! So, I have a VCR But!! I do NOT know how to connect the, coxial (sp) ? cord (where it belongs) or the cable cord, let alone any other cord. The manual to the TV has pictures and tells what to do.....BUT!! I get an instant MIGRAINE .....PLEASE!!!!! can you help my brother, mainly because, he's paralysed....so, he NEEDS TV / MOVIES Thanks!! a concerned sister
    Sergeant:
  • 291 Answers
Without the manual !!
1)VCR INPUT:: [Cable_antenna In] the coxial screws on from "output" of cable box or ( airwave )antenna.
2) VCR output:: connect another coxial into input of TV. You should be able to keep all the other wires connected from SONY theater system.
note:: your VCR has a switch for VCR\TV. When u have a VHS tape playing a movie & switch from VCR to TV, you will see the channel that is on the VCR not the cable box\ antenna input.
example:Cable channel is on Ch.122, & your TV must be set to Ch.3 to view cable.If your VCR is set to Ch/5 you may not see that Ch.122.You will still be able to see your VHS tape when u place the VCR\TV switch back to VCR.
I am going to share wt.u a $100,000,000.00 trick:put any ch.on cable box.Switch VCR\TV to TV,change channel ON VHS tuner.When u come to the [picture] that the cable box is on,Then that is the Ch.u can see cable ON the VHS.
U owe me!!
Posted on Jun 16, 2008
I was just given a 6842PE sylvania tv. when i plugged it in and connected the satellite the screen is very fuzzy and has a black 1 in line straight down the middle of the screen. i can see the outline of...
the 1inch black line is either a buffer board gone bad or the ribbon cable from the plasma screen to the buffer board, the snowy picture could be many things, including y-sus, xsus or tuner boards
Mar 27, 2011 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Can i hook my computer to tv ?
Hello
You can connect your Sylvania LC320ss8 to a computer. There is a socket at the back of your TV to connect it with a PC via VGA cable. One end of that cable must be connected to TV, and the other end of the VGA cable must be connected to PC's monitor out jack.. You have to purchase on VGA cable for this purpose, and is available at most of the electronic spare part shops. A "mini-plug audio cable" also is needed to connect the audio from PC to TV. Its one end to be connected to PCs Audio Line Out jack and its other end to TVs PC in audio jack. Both Jacks can be located at the back side of the TV. After connecting it select the TV to receive PC signals according to its manual says. OK.
Jan 26, 2011 | Sylvania LC320SS8 32 in. LCD Television
My 42 inch sylvania plasma tv does not have a coax connection, so how do i hook up my cable to the audio/video connection? i know there is an rf converter to transfer audio/video to coax but i really...
Since your TV only has audio and video input jacks, you can connect those to audio and video output jacks on the VCR. Now connect the coax cable to the RF/ant input on the VCR and you'll have to change channels by using the VCR channel selector.
Let me know if you require further assistance.
Aug 08, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Sylvania Picture on and off
it could be the mainboard is causing the trouble.
Jun 11, 2009 | Sylvania LC420SS8 LCD TV
I cannot get close cation on the sylvania 42 plasma TV. I have gone through the menu to set it up but it.But I cannot get close caption to work
Most likely it is in the cable box settings accessed through the cable remote, not the tv settings which are set up through the tv remote.
Jun 04, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Trying to hook compaq presario laptop to philips lcd digital tv
hey fox,
sounds to me like a connection problem. If the compaqs output is vga, you need to convert the input (tv side ) to hdmi, component, s-vidio... what ever you can find. Typically when you hook up your computer to a flat screen or such, its best to try to use the hdmi ports or the rpg. But if thats not available you need to take the outout from your laptop ( whatever type that might be and input it into your flat screen tv. If you input laptop into tv under ( eg..HDMI) then when you VIEW it you need to select the correct source on your flat screen. Such as hdmi or pcmi or rpg.I know that the do sell alot of cables that adapt from one type of connection to another. Typically only one cable is required from the laptop to the flat screen. If you think about it you are only using the flat screen as a monitor.
Feb 14, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Sylvania 42" flat screen won't turn on
First you should check the fuse and the wiring in your tv by removing the back cover. Make sure no wires are bare or touching. If there are any, wrap them with electrical tape.
If you cannot see anything wrong by looking, then it is probably the set has a bad transformer (high voltage)
Jan 17, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
What cable to purchase to connect my computer to TV to use webcam
without knowing what connections you have available we can not assist you with the connection problem I suggest you try a local tv repair shop .
Nov 02, 2017 | Sylvania 6632LG 32 in. LCD HDTV
Sylvania 6842 PE 42 in...
You need an HDMI cable that runs from the cable box to your tv.
Oct 20, 2008 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Digital converter
if you do not have cable or satilite tv, you will have to purchase converter box. If you have either on of those services you will be in good shape.
May 03, 2008 | Sylvania 6427FB 27" TV
LG 42LC2D 42 in. LCD HDTV Logo
166 people viewed this question
Computer Repairing
Computer Repairing
