Question about Medion Computers & Internet
Medion md6144AO monitor has no display on startup
Will the display come on after a while if so it is a problem with the backlight the problem is the electrolitic capacitors on the inverter board also check the electrolitics in the power supply section if the
tops of them are starting to bulge out replace them as well i take it this monitor is about 2 to 3 years old and it is a common problem for them
Posted on Jun 17, 2008
Emachines el120006w momitor quits displaying shortly after startup or won't even display after startup
Try another monitor, reseat ALL monitor cables .If you have a Graphics Card, shut down computer, unplug and reseat Graphics Card.
Dec 15, 2012 | eMachines EL1200 PC Desktop
Medion monitor won't come on
inverter has gone .cheaper to buy another monitor
Apr 26, 2010 | Medion MD 7317 17" Flat Panel LCD Monitor
Dvi cable does not work on my medion 19
sounds like the computer is thinking you are output on the rgb cable an you connect a rgb to the computer also and then see if you can switch them in the display settings.
Dec 09, 2008 | Computers & Internet
19 " laptop monitor drivers
On Notebook monitors it is reccomended that you set the monitor at the optimal resolution that is reccomended by the manufacturer (usually the highest) Based on my experience , it is normal for a laptop to display fonts kind of iffy at lower resolutions. This is because image stretching is taking place and things are out of proportion.
Aug 21, 2008 | Medion Computers & Internet
MONITOR MEDION MD7317 NOT WORKING
i have some 19 inch medion monitors that have the same problem .. they make a lot of noise and the screen might be jittery/fuzzy ... i found the following:
several capacitors in the power supply (inside the monitor) had their tops buldging .. that shows that internal pressure was high in the caps, usually caused by them being hot and thats caused by high internal leakage .. the caps may eventually blow out the tops (explosion vents) .. the caps are designed to do that instead of becoming a bomb ..
all the bad electrolytic capacitors i have seen so far on these monitors, motherboards and other electronics have been chinese made .. they made millions of bad caps over several years ..
almost all the bad caps had buldged tops but not always .. once in a while i see one thats open but not bulbged .. probably venting elsware ..
i changed the obviously bad caps and the monitors returned to like new performance ..
i dont know about the 17 inch but the 19 inch medion flat pro display is not too hard to take apart .. about 30 screws or so ... speakers have to be unscrewed and you have to be careful not to stress cables that go to the push buttons .. of course you have to know how to solder without bridging paths
Feb 02, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
Medion Motherboard
if you cannot reach the BIOS settings screen at power-up, then try another known-good keyboard...it is likely dead.
Jul 05, 2007 | Medion (MT8381) (40004683) Motherboard
Medion MD7317 17 inch Flat Panel Monitor
My MD7317 did the same thing until I actually installed the driver for it. My windows did not have the correct driver in it's driver base, so I found the driver online ( took a few minutes of searching) and within a few minutes of installation the monitor displayed a great colorful picture. Naturally, I had to use another monitor while I was searching. Driver is about 3.3 megs. It came in a zip format. I did not keep track of the link to driver, but it omly took a few minutes to locate it.
Jun 12, 2007 | Medion MD 7317 17" Flat Panel LCD Monitor
Computers & Internet Logo
323 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
