Question about GE Profile PDW8400J Built-in Dishwasher
Soil sensor/timer out of whack
My dishwasher has been installed for about a year. Just recently it does not seem to be drying completely and I've noticed the time for a normal cycle has increased significantly - it used to show 107 or 108 and now it shows 122 - even with an empty dishwasher. What might be causing this problem? Is there a sensor someplace that I need to clean?
  • Hoovermom Jun 09, 2008
    Nope, that's not it. Nothing had changed. No additional options had been selected (I can add even more time to normal if I do that! If I put it on one of the other options that is usually longer than normal (sani-heat or cookware), those don't show any additional time. The only one that shows additional time is the "normal" cycle. My water heater is all the way up - no different than it's been since the dishwasher was installed.
  • 54 Answers
Try cutting the breaker off for 5 min, this will reset the computer.
Posted on Jul 04, 2008
  • 868 Answers
NO SENSOR PROBLEM.TRY THIS , TURN UP THE HEAT AT THE WATER HEATER IF YOU ARENT USING A SANI HEAT CYCLE/EXTRA SCRUB CYCLE.........................THE ONLY WAY YOUR TIME HAS INCREASED IS THAT YOU HAVE A OPTION SELECTED ON YOUR PANEL THAT WASN'T SELECTED BEFORE.YOU WILL SEE BY TIMING THE DIFFERENCES IN THE OPTIONS. THATS IT!!! PLEASE RATE THIS SOLLUTION THANK YOU !!!
Posted on Jun 08, 2008
We have a 4 year old dishwasher.It is not washing as good as it should.The machine seems to rinsing the dishes etc in soiled water.I've checked the syphon and it doesn't appear to be blocked.I...
Hi wesalado,
Please follow my Tip below on some hints on how to keep your Dishwasher in tip-top shape:
DISHWASHER NOT CLEANING PROPERLY ANYMORE...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 08, 2011 | Zanussi Dishwashers
Glasses and frying pans not clean at end of cycle. Residue on glasses and cups,food particles on frying pans.
it's generally not a good idea to put really greasy items in a dishwasher along with relatively clean items such as glassware and plates and cutlery, as most recent good quality dishwashers come with a soil sensor that ends the wash cycle once the dishes appear clean, and all the grease from your frying pan will cause the soil sensor to take longer to detect clean water.
Jun 29, 2011 | Dishwashers
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Frigidaire dishwasher not completing cycle.
hi,
The cycle doesn't complete
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
On some units, the pause is timed and the unit continues after the allotted time.
On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
I see an error code
If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Good Luck
Thanks for using FixYa
Jan 03, 2009 | Dishwashers
Jennair dishwasher timer stops halfway thru wash cycle.
Try using a cycle that doesn't boost the heat. Usually a quick or china/delicate cycle. Any cycle that heats the water pauses the timer until it is done. Some machines even select this with heated dry. The sensor that controls this can go bad and stop the timer completely. If it operates for the complete cycle , look for the sensor and replace it. There is usually a wiring diagram somewhere in the machine sometimes in an envelope inside the door, control panel or behind the front bottom panel
Jul 04, 2008 | Dishwashers
Frigidaire Ultraquiet III
hi there,
can you supply me with the exact model # off your d/w please?
Mar 21, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Clean light flashs seven times, stops and then does the same over again.
bellman, on this model I believe you can clear the fault by pressing high temp scrub--air dry--high temp scrub--air dry in that order. Your normal cycle on this dishwasher is approx 97 minutes without the thermal holds, (pauses to heat the water to proper temps.) So of course it's going to go over 97 minutes. This is for heavy soil. Light soil, approx 89 minutes. Some models have a soil sensor, some don't. If the sensor is out of specs..it could add to long wash times. The heater may in fact be the problem, he needs to check it. The heater runs through the nuetral side of the door switch so you want to make sure the switch is closing and the dishwasher is level and secure. He also wants to check out the resistance of the thermistor, should read 48 to 52K ohms at aprox. 75 degrees. Catriver..post back.
Apr 14, 2007 | Kenmore 24 in. 16692 Built-in Dishwasher
Wash cycle starts up temporarily during initial fill
Joe, this is normal. Your model has a soil sensor and the updated board has a soil purge. So it will fill, purge the sensor and resume. Catriver..post back.
Oct 26, 2006 | KitchenAid 24 in. KUDP02CR Built-in...
GE Profile PDW8400J Built-in Dishwasher Logo
152 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
