Question about Vivitek V37835 46 in. LCD Television
Tv will not go on
Our vivitek tv will not go on the lights keep flashing green to yellow., please help
  • BrtRal Jan 08, 2009
    Vivitek 32" HDTV. Blue Power lite comes on but then changes to Amber and NO-POWER?
    I did check and switch Aux.Output In/Outputs and was Only a Temp help.
  • BrtRal May 11, 2010
    This exact thing happened to us and it was the bulb. You need a new one. Luckly ours was under warrenty and it was replaced for free. Once replaced the problem was gone.
    Vivitek 32" Has no Manuel?..!! PLZE inform me as to WHAT BULB
    and how where may I get one? Thanks!! BrtRal
Posted on Jun 29, 2008
Vivitek d510 projector has the power button blinking 6 times then the lamp light blinks 3 times. What does that mean?
do the next test. God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Jul 31, 2013 | Vivitek Televison & Video
I replaced the lamp im my vivitek 56 inch dlp tv. But it still wont turn on. The light goes from green to red and it makes a sort of high pitch sound then stops
my vivitek RP56HD22A 56" dlp tv has a new lamp and will not turn on. when i push the on button is whines and wont come on
May 24, 2010 | Vivitek V37655 56" DLP TV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Vivitek 32 L32PL1A no picture, black screen
chek your power module.check your electrolytic capacitors both in the input & output side of the power module.
Oct 05, 2008 | Vivitek V37835 46 in. LCD Television
Vivitek 51 DLP HD HDMI
You should have checked the troubleshooting section of your manual!! Okay, enough scolding. You need a new lamp. I do enjoy my Vivitek, but this is a definite downside of a DLP, especially if you watch a lot of TV. I am on my third lamp already, and they are NOT inexpensive. If you have your TV less than a year, your lamp may still be covered under warranty and may be replaced by Vivitek for free. If you have to buy your lamp, it can easily cost you over $200. This is the new lamp in a whole new assembly, which makes installing it EXTREMELY EASY and will just take a few moments. If you are a little more adventurous and want to save some money, you can buy the lamp alone. You then remove the lamp assembly from the television, open it up (there's several screws to remove), disconnect the old lamp, and reverse the process by making the proper connections with the new lamp and putting the new assembly back together and back into the television. It sounds more complicated than it is.. Biggest rule.-- don't touuch the surface of the lamp with your bare hands. You don't want your oils on the lamp. . And once you put everything back together and restart the TV, reset the timer for the lamp (the manual explains how). The lamp timer is very important for warning you of when to replace the lamp under ordinary conditions, when it does make it through its entire expected life. I don't know if it's appropriate to actually recommend specific vendors for the lamp, but I can if that's okay. email me midlomiss at yahoo dot com
Mar 13, 2008 | Vivitek V37835 46 in. LCD Television
Vivitek tv
I have a 56" model that I have had a similar problem. My bulb burned out in <90 days. Warranty was 90 days on the bulb itself. When the TV picture goes out, the indicator LEDS blink on and off.
Here is what you have to determine:
1) First cover the left LED with a piece of paper so that you can't see it blinking. I don't know if your layout is the same as my TV. You may have to switch the paper blocking the LED.
2) Pay attention to the other LED and READ its' flashing code. In my case, the code was 2-3. It would flash 2 times, pause briefly, then flash 3 times. This meant code 23. That indicated the bulb was burned out.
3) If you look in the manual, It does have a code list of some sorts to tell you of the codes and their meanings. Hope this helps.
Nov 20, 2007 | Vivitek V37835 46 in. LCD Television
Vivitek V37835 46 in. LCD Television Logo
90 people viewed this question
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
